النتائج 1 إلى 6 من 7
    افتراضي محركات جديدة للجيل القادم من دودج رام في 2009
    The next generation of Dodge Ram 1500 pickups, are set to debut in the 2009 model year. I have been hearing some interesting things from different sources about the new Ram 1500 lineup. One of my sources said that Ralph Gilles and his team are getting away from the “big-rig” styling that we all love, and going towards a new design similar to the pattern of the newer Dodge truck lineup are fallowing. Styling that will be similar to the design theme used on the new Dodge Nitro, Dodge Hornet Concept, and Dodge Rampage Concept.
    Mr. Gilles told the press that the next generation of Ram will be more aerodynamic and have a more luxurious car-like interior. Using the aerodynamic theme, the Gilles’ gang is looking at making the pickup have more of a cab forward design. A design statement Chrysler Group created in the mid-1990s and is now trying to get away from. The bold fender flares of the Nitro, Hornet Concept, and Rampage Concept, allow for a wider track and make it possible to push the vehicle’s wheels out to the corners, making it possible to provide better handling.
    New engines will debut in the 2009 Dodge Ram 1500. The word is that the 3.7L V6 will be dropped and be replaced with the 4.0L V6 from the Nitro. The engine will produce 270 horsepower, putting it in from of the standard engine from the rest of the manufacturers. The 4.7L V8 will get huge updates for the 2008 model year. Power should be pushed up to 300 horsepower [current spec is 290 for 2008 Dakota, and that's what we now expect] for the new Ram 1500. [Another rumor has the 3.7 V6 being replaced by a four liter Phoenix engine.]
    A new version of the HEMI V8 in the Ram 1500 will debut in 2009. It will grow slightly in displacement, probably to a 5.9L or 6.1L configuration. The new engine will feature next generation MDS, a 3-valve per cylinder configuration, and variable valve timing. The new HEMI should put out best in class power (somewhere around the 400 horsepower mark). Towing capacity should be over 10,500 lb. Engines should be equipped with 6-speed automatics, as well as the two lesser engines with 6-speed manual transmissions
    الخبر يقول ان دودج تنوي انتاج جيل جديد من سيارتها المشهورة واضافة العديد من التعديلات على المحركات وجعلها شاحنة فخمة لاستعادة العرش من الفورد
    حيث ستزود بمحرك 4.0 لتر بقوة 270 حصان بدلا من القديم
    واما المحرك الاوسط فهو 4,7 ليتر بقوة 300 حصان بدلا من 235 للقديم
    والاهم هو محرك هيمي جديد سيجد طريقه لكل سيارة دودج وجيب وكرايسر
    وهو بسعة 5,9 ليتر بقوة تصل الى حوالى 400 حصان
    متصل بجير اوتو او عادي ب6 سرعات
    وسوف تكون ملامحها مقتبسة من دودج نيترو ورامبيج وهورنيت ...
    M.H.S غير متصل عضو نشيط جداً
    Sep 2006
    21 سنة
    491
    مشكور أخوي على الخبر ...
    الله يستر يشبة نيترو ... اذا راح يشبة النيترو اتوقع ما راح يستعيدون العرش من فورد ولا بالاحلام
    الصورة الرمزية aham_9305
    aham_9305 غير متصل عضو شرف
    UAE
    5,403
    يسلموو اخويه على الخبر
    ننتظر و نشوف صورها
    و تسلم أخوي على الخبر
    محركات جيدة
    في انتظار الشكل
    مشكور على المعلومات
    1,637
    ليش كل هاي القوه كرايسلر مدمنة قوه
