    Red face فولفو تقدم محرك T6 للفئة S80............
    Volvo has given its S80 saloon an engine upgrade with the addition of a 285hp turbo-six lifted from its recently revealed V70 wagon. Also joining the lineup is a new turbodiesel five-cylinder variant and both the new models are equipped with AWD running gear. This latest AWD system features an electronically controlled hydraulic clutch, distributing drive between the front and rear axles.
    The high-performance inline-six is based on Volvo’s existing 3.2L mill, which was introduced back in March last year. The latest version displaces just 3.0L and is constructed from aluminum and also gets a turbocharger for extra huff. The end result is 285hp (210kW) and 400Nm of torque coming on from a lowly 1,500rpm. Expect the 0-100km/h dash to take 7.2 seconds. Volvo’s turbocharger design takes in exhaust gases in two stages, with the inflow divided into two lots of three cylinders each, a system known as twin-scroll technology. Twin-scroll technology permits use of a more compact and uncomplicated turbocharger and provides extremely swift response, fully on a par with that from twin turbochargers.
    The new D5 oil-burner offers 185hp (136kW) and the same 400Nm of torque as the gasoline variant. It features an electronically controlled turbocharger, advanced multi-point injection technology and a complex engine management system. To keep emissions in check, Volvo has added a particle filter as standard, which requires no servicing.
    محرك شكل غريب من فولفو.
    6 تيربو 285 حصان
    5 سلندر وديزل تيربو 185 حصان
    تسلم اخوي عمر
    الصورة الرمزية aham_9305
    aham_9305 غير متصل عضو شرف
    UAE
    5,403
    مشكور اخويه على الخبر
  1. مرسيدس تقدم محرك 4 إسطوانات للفئة S.....(جديد باريس)
    آخر مشاركة: 18-03-2011, 05:13 PM
