النتائج 1 إلى 6 من 13
    Exclamation صور تجسسية لــ 2008 Mitsubishi Lancer
    When the current Mitsubishi Lancer debuted in 2002, nobody really noticed. With its 120-horsepower engine and innocuous styling, there was no reason to get excited. Then two years later the high-performance Lancer Evolution model finally made it to the States. It was stacked with more than double the power, all-wheel drive and a rear spoiler fit for duty at Le Mans. Suddenly everybody knew the name Lancer.
    Now there's a new generation of Lancer in the works and everybody is paying attention this time around. Mitsubishi threw us a bone last year when it unveiled the Concept-X show car at the Tokyo auto show. Now we have spy footage of actual prototypes testing in the California desert.
    Although these test mules aren't the high-powered Evolution models, they still had much of the Concept-X's distinctive shape. Even with the heavy camouflage up front, you can still make out the sweep of the headlights and pronounced nose. The air dam digs deep, with projector-beam foglights on each side and a sizable opening in between to feed an intercooler.
    Standard Lancers won't be turbocharged; instead they'll most likely use the 1.8-liter "world" engine Mitsubishi developed with Chrysler and Hyundai. Higher-line Ralliart models will have the 2.4-liter version of the same engine that generates around 175 horsepower. The top-of-the-line Evolution will get an upgraded version of its current 2.0-liter turbocharged engine, making roughly 300 hp. Although lesser models will use traditional transmissions, the Evo may offer a sequential manual with steering wheel paddle shifters similar to BMW's M cars.
    All Lancers will ride on a new front-wheel-drive platform shared with DaimlerChrysler. Already in use underneath the Dodge Caliber and Jeep Compass, the new chassis has already proven to be a fairly stiff and well-mannered setup. Of course, when it comes to the Evolution there will be all-wheel drive, stiffer suspension settings and heavy-duty brakes. Along with its already sophisticated Super All Wheel Control (S-AWC) drive system, the new Evo will also feature a new active braking system to further enhance stability in low-traction driving. We got a taste of how it works during a test-drive of an Evo X development mule and the results were impressive.
    Expect to see the Lancer in showrooms next spring, followed by the upgraded Ralliart model a few months later. The Evolution won't make it until the fall of 2007 at the earliest, but it's expected to be well worth the wait
    نص الترجمة
    ومع ميتسوبيشي الرماح بدايتها في عام 2002 ، لاحظ احد الحقيقه. مع المحرك 120 حصان بريءه والتصميم ، وليس هناك ما يستدعي حمل ملتهبه. ثم بعد ذلك بسنتين الرفيع الرماح تطور الاداء النموذجي في النهايه من الدول. وتتكدس اكثر من الضعف قوه ، ودفع بالعجلات الخلفيه والمخرب صالح المسءول في لومان. فجاه الكل يعرف باسم الرماح. الان ثمه جيل جديد من الرماح في العمل والاهتمام الجميع هذه المره. ميتسوبيشي رمي العظام لنا العام الماضي عندما كشف النقاب عن فكره المعرض العاشر السيارات في طوكيو للسيارات المعرض. الان لدينا افلام الجاسوسيه نماذج الاختبار الفعلي في صحراء كاليفورنيا.
    ورغم ان هذه التجربه ليست البغال بقدره عاليه التطور الموديلات ما زال لديه الكثير من مفهوم العاشر الشكل المميز. حتي الثقيل التمويه مقدما ، فانك تستطيع جعل التفتيش عن الاضواء العلويه من الانف وضوحا. الهواء المنجم العميق ، والسد مع الحزم فوغليغتس العارض من كل جانب وفتح كبير بين المبرد لتغذيه احد. مستوي المهن لن توربوشارغيد ؛ بل الارجح افضل استخدام 1.8 ليتر بين "العالم" تطوير محرك ميتسوبيشي وكرايسلر هيونداي. اعلي خط راليارت النماذج ستكون - الاصدار 2.4 ليتر من نفس المحرك الذي يولد حوالي 175 حصان. - مقدمه - الخطوط تطور سيحصل علي ترقيه النسخه الحاليه 2.0 ليتر للمحرك - توربوشارغيد مما يقارب 300 شركه هولت باكرد. رغم ان اقل النماذج التقليديه التي تستخدم البث يفو ، قد توفر ادله متعاقبه المقود المجذاف المغيرون مماثله في سياره بي ام دبليو م. الجوله ستكون جميع المهن علي جبهه جديده ذات الدفع بالعجلات برنامج مشترك مع شركه.
    تستخدم بالفعل تحت ودودج والمقدره الجيب البوصله ، الهيكل الجديد قد تمثل نوعا الجثه وذو تربيه صالحه مترا. وبالطبع ، عندما يتعلق الامر تطور لن يدفع عجله كل تعليق ، وتشديد ظروف الخدمه الشاقه والفرامل. ومع التطور الذي سوبر جميع العجلات التحكم (ق - الافغاني) لدفع النظام الجديد يفو مكانا جديدا النشطه الكابح نظام تعزيز الاستقرار في المنخفضه يقود المسيره. وحصل طعم كيف تعمل خلال اختبار الدافع الي يفو العاشر للتنميه بغال ونتاءج مذهله. نتوقع ان نري عرض الرماح في الربيع المقبل ، ثم رفع راليارت نموذج بضعه اشهر. تطور لن يجعل حتي خريف 2007 علي الاقل ، وهو يتوقع يستحق الانتظار
    loolicpolic غير متصل عضو نشيط جداً
    قطر
    283
    شكلها بيكون جميل.. أعتقد إنها مشابهة للجالنت..
    مشكور أخوي محمد..
    تحياتي..
    انا اوافق الراي مع اخوي انه شكلها بيكون جميل
    مشكور اخوي جراند على الصور
    Legacy غير متصل عضو نشيط
    87
    شكلها صحيح وقريب من الايفوا إلي ظهرت صورة ^_^
    الصورة الرمزية Mr_CoRvEtTe
    Mr_CoRvEtTe غير متصل مشرف سابق
    5,952
    تسلم اخوي على الموضوع
    الصورة الرمزية BMW M8
    BMW M8 غير متصل عضو فعّال
    دبي - الامارات العربية المتحدة
    580
    اخي مشكور على الموضوع ... بس الترجمة ... اي مكتب ترجمة مترجمها....
  1. صور تجسسية شفروليه ماليبو 2012
    بواسطة GTO في المنتدى أخبار السيارات
    آخر مشاركة: 01-10-2010, 02:56 AM
  2. برنامج صيانة سيارات ميتسوبيشى Mitsubishi (Lancer X Sportback,ASX,Grandis,Pajero)
    بواسطة hossam moustafa في المنتدى قسم السيارات العام
    آخر مشاركة: 25-08-2010, 03:43 AM
