النتائج 1 إلى 6 من 11
    الصورة الرمزية MKM
    MKM
    MKM غير متصل مشرف سابق
    Aug 2006
    1,822
    Talking تقرير كامل ومفصل عن المبرجيني قلاردوا سبايدر ... (( من تصويري ))
    هلا شباب ..
    شخباركم .. ؟
    ان شاء الله بخير .. ؟
    FRAME
    Structural aluminium space frame based on extruded aluminium parts welded to cast aluminium joint elements
    BODY
    Aluminium with thermoplastic “hang-on” parts
    SUSPENSIONS
    Aluminium double-wishbone front and rear suspension system, anti-roll bar, anti-dive and anti-squat
    ESP
    Full ESP system with ABS, ASR and ABD
    BRAKES
    Power vacuum, aluminium alloy callipers: 8-cylinder front callipers and 4-cylinder rear callipers
    VENTILATED DISCS (front–rear)
    Ø 365 x 34 mm – Ø 335 x 32 mm
    STEERING
    Power-assisted rack and pinion
    TYRES (front–rear)
    Pirelli P ZERO 235/35 ZR 19 – 295/30 ZR 19
    WHEELS
    Aluminium alloy: 8.5" x Ø 19" – 11" x Ø 19"
    KERB-TO-KERB TURNING CIRCLE
    11.5 m
    MIRRORS
    External mirror with electrical folding system
    REAR SPOILER
    Electronically controlled
    AIRBAGS
    Front “dual-stage” driver and passenger airbags, side “head-thorax” airbags
    SOFT TOP
    Fully electronic-hydraulic soft top, electronic folding rear window/wind protector
    TYPE
    10 cylinders V 90°, DOHC 4 valves, 18° crankpin offset
    DISPLACEMENT
    4961 cc
    BORE AND STROKE
    Ø 82.5 mm x 92.8 mm
    INTAKE SYSTEM
    Variable geometry
    VALVE GEAR
    Chain-driven, intake and exhaust continuously variable valve timing, electronically controlled
    COMPRESSION RATIO
    11 : 1
    MAXIMUM POWER
    368 kW (525 HP) at 7800 rpm
    MAXIMUM TORQUE
    510 Nm at 4500 rpm
    EMISSION CONTROL SYSTEM
    Catalytic converters with lambda sensors
    COOLING SYSTEM
    Two water radiators + gearbox oil cooler + engine oil cooler
    ENGINE MANAGEMENT SYSTEM
    Electronic Lamborghini L.I.E., with individual static ignition, multipoint sequential fuel injection, drive-by-wire system, OBD system
    LUBRICATION SYSTEM
    Dry sump
    TYPE OF TRANSMISSION
    Permanent 4-wheel drive with viscous traction system
    GEARBOX
    6-speed + reverse
    Optional: robotized sequential e gear system with actuation by paddles on the steering column
    CLUTCH
    Double plate, Ø 215 mm
    REAR DIFFERENTIAL
    45 % limited slip
    FRONT DIFFERENTIAL
    Slip limitation by ABD function
    TOP SPEED
    309 km/h
    WHEELBASE 2560 mm
    OVERALL LENGTH 4300 mm
    OVERALL WIDTH 1900 mm
    OVERALL HEIGHT 1184 mm
    TRACK (front–rear) 1622 mm – 1592 mm
    WEIGHT (“dry” – no fuel) 1430 kg
    WEIGHT DISTRIBUTION (front-rear) Front 42 % – rear 58%
    FUEL TANK 90 litres
    ENGINE OIL 10 litres
    ENGINE COOLANT 20 litres
    واخيراَ سعر السياره : ( 850.000 ) الف ريال قطري
    ارجوا ان ينال الموضوع اعجابكم يا شباب
    اخوكم : محمد
    تحياتي .. :D
    مشكور الغالي على هذي التحفة الرائعة
    الصورة الرمزية K H A L E D
    K H A L E D غير متصل مشرف عام
    KSA-buraydah
    6,508
    محمد عااااجز عن شكركـ ع التقرير الرااائع والمميز من رجل مميز...
    تسلم يالغاااالي...
    الصورة الرمزية Nas1
    Nas1 غير متصل مشرف سابق
    عجمان -دار الأمان-
    471
    الله يعطيك العافية عزيزي
    و تسلم على المعلومات و الصور الجميلة
    CARS COOL غير متصل عضو جديد
    Jun 2007
    السعودية
    49
    موضوع جبار ومميز
    للأسف الوكيل لدينا الغسان للسيارات لايسمح بتصوير السيارة!!
    مشكور أخوي على التغطية المميزة
    هذه غلاردو الجديدة.
    وشو فرقت عن قلاردو العادي اخوي محمد.
    ونتظر جديدك اخوي
