    Exclamation AM General Humvee تحت الاختبارات
    Not for highway use
    While AM General's Humvee is a legendary military vehicle, the company has found themselves shut out of the Army's Tank and Automotive Command prototype competition for the FTTS (Future Tactical Truck System) that will replace the aging Humvee. However, this development vehicle clearly shows AM General will still be making bid to replace the roughly 140,000 Humvees already in service in the U.S. Military. AM General will face stiff competition for the FTTS contracts from companies such as Lockheed Martin, Force Protection Inc. and Navistar's military business division.
    The first noticeable change is the revised hood, which may or may not be the final design. The new hood is designed to accommodate the repackaging of the air intake system as well as the cooling system being moved from above the motor to in front of the motor. We believe that's the radiator showing through the grill openings.
    The "GEP No. 7" painted under the door is a reference to General Engine Products (a subsidiary of AM General.) We believe the motor underneath the ungainly hood is a revised version of the 6.5-litre diesel motor made by GEP. It's rumored that this motor has seen a significant increase in power due to improvements in the injection system as well as an improved combustion chamber design. Additionally, we believe a hybrid electric powertrain has been added to the big diesel motor to help with fuel economy and electricity generation.
    The cab has clearly been revised and armoured with a heavier construction. AM General is likely utilizing a "blast tub" design where the vehicle as a whole might not survive a blast, but the occupants inside the armoured "tub" would survive. The use of reactive armour panels are also possible with the new vehicle. When hit with a projectile, reactive panels explode outward, deflecting the projectile. These panels are significantly lighter than conventional steel and are particularly effective against rocket propelled grenades.
    According to our tape measure, the ground clearance has increased to an astonishing number. While the current Humvee sports a 16-inch ground clearance, we measured this prototype's clearance at 22.5 inches. Another impressive number on this vehicle shows up on the tires. A massive set of Goodyear 335/65R 22.5 tires adorns this test vehicle. The 22.5 inch wheels are held together with no less than 18 bolts and then attached to the vehicle with 8 more lugs. We weren't able to tell if a central tire inflation system was in place.
    The last change we noticed were the larger, beefier air drop rings peeking through the hood. This seems to indicate the new vehicle will weigh more. The ballast weight we saw in the back of this test car also seem to indicate that this new military vehicle will be set-up to traverse the battlefield with heavier loads.
    شكله قريب من همر H1 القديمة
    نص الترجمة
    لاستخدام الطريق السريع بينما اشعر العام هو المدخل اسطوريه مركبة عسكرية ، وكانت الشركة قد وجدوا انفسهم في معزل عن الجيش الدبابات وسيارات القيادة نموذج المنافسة لفتس (مستقبل النظام التكتيكي الشاحنه) التي ستحل محل الشيخوخة سيارة. بيد ان هذا التطور مركبة تظهر بوضوح صباحا العام ستظل محاولة لجعل محل تقريبا 140،000 أميركية فعلا في خدمة الجيش الامريكى. الساعة الجمعية ستواجه منافسة شديدة لفتس عقود من شركات مثل لوكهيد مارتن وشركة لحمايه القوة العسكرية نافيستار الشعبه التجارية. الاولى هي تغيير ملحوظ المنقحه هود ، الذي قد يكون أو لا يكون التصميم النهائي. هود الجديد يهدف الى استيعاب اعادة كمية من الهواء وكذلك نظام التبريد نظام انتقل من فوق المحرك للامام السيارات. ونعتقد انه في المشعاع تظهر من خلال فتحات شوايه. "جيب رقم 7" يرسم تحت الباب اشارة الى قرار محرك المنتجات (هيئة فرعية للجمعية الساعة). نعتقد المحرك تحت المتداول هود هو نسخة منقحه من 6.5 لتر ديزل موتور ادلى به جيب. انه تردد ان هذه المحركات قد شهد زيادة كبيرة فى الطاقة بسبب التحسينات في نظام الحقن ، فضلا عن تحسين تصميم غرفة الإحتراق. وبالاضافة الى ذلك ، نعتقد الهجينه الكهرباءيه بوويرتراين اضيفت الى محرك الديزل الكبيرة للمساعدة الاقتصاد في الوقود وتوليد الكهرباء. في سيارة الاجره بوضوح تم تنقيحه والمدرعات مع ثقل البناء. الساعة يرجح العام باستخدام "الانفجار حوض" عند تصميم السياره ككل قد لا تصمد أمام الانفجار ، ولكن شاغلي داخل المدرعه "حوض" البقاء. استخدام الدروع التفاعلية الافرقه الممكن ايضا مع الوسيلة الجديدة. عندما وصل مع مقذوف والتفاعل ريقي الخارج ، الذي ينحرف تنفجر القذيفه. هذه اللجان هي أخف كثيرا من التقليدي الصلب وبشكل خاص فعال ضد القذائف الصاروخيه. على طريقتنا شريط قياس ، وتطهير الارض ارتفع الى عدد مذهل. فوائض سيارة رياضية من 16 بوصة وتطهير الارض ، فاننا يقاس هذا النموذج للتطهير في 22.5 بوصة. آخر عدد هائل على هذه المركبه تظهر على الاطارات. مجموعة ضخمة من جود يير 335/65ر 22.5 يزين هذا الاختبار اطارات السياره. إلى 22.5 بوصة العجلات تقام جنبا الى جنب مع ما لا يقل عن 18 الترابيس ثم يعلقها على سيارة تحمل اكثر عروات 8. لم نتمكن من ان نقول اذا مل التضخم الوسطي هو النظام القائم. التغيير الاخير لاحظنا كانت اكبر ، بيفيير الجو تطل من خلال حلقات هود. ويبدو ان هذا يدل على السياره الجديدة تزن اكثر. الصابوره الوزن رأيناه في مؤخرة السياره ايضا في هذا الاختبار تشير الى ان هذه المركبات العسكرية الجديدة سيتم تجهيز تجتاز ساحة المعركه مع اثقل الاحمال.
    ra3y_v6 غير متصل عضو فعّال جداً
    1,790
    ياخي السياره WILD بزياده !
    مشكور أخوي على الخبر
  1. سيارات تحت الاختبارات............(اكتوبر 2010)
    مشاركات: 25
    آخر مشاركة: 21-10-2010, 12:23 PM
  2. سيارات تحت الاختبارات............(سبتمبر 2010)
    مشاركات: 47
    آخر مشاركة: 24-09-2010, 01:29 PM
  3. لانسيا ستراتوس تحت الاختبارات
    آخر مشاركة: 11-09-2010, 04:36 PM
