النتائج 1 إلى 6 من 9
الموضوع: 2009 Infiniti FX37 and FX50
    Wink 2009 Infiniti FX37 and FX50
    The 2009 FX will be available in two different choices: the FX37 and the FX50. As you suspect already one will be powered by a 3.7 liter and the other by a 5.0 liter engine.
    The FX37 wil be powered by the same 3.7 liter VQ-series V6 engine engine used in the G37 Coupe and will deliver 300 hp. The FX50 will be powered by a 5.0 liter engine with an output of 390 hp and 369 lbs-ft.
    The new VQ37VHR, first used in the G37 Coupe is based on the award-winning VQ engine series, named one of the "Ten Best Engines" by Ward’s Auto World magazine for 13 consecutive years. next to a bigger output, the FX37 will also use the new VVEL system which combines hydraulic-controlled variable valve timing and electronically controlled variable valve lift on the intake side to help improve performance and response. The VVEL system is also expected to improve emissions and fuel efficiency.
    The 2009 FX will have the same dimensions as the current FX. Infiniti will use materials that will reduce weight, this is why the up-coming FX will be faster compared to the current model.
    The biggest changes will be made to the front of the car. The exterior will be more sporty and modern.
    The exterior highlights will include flowing front fender curves, expressive front fascia with Infiniti’s signature double-arch grille and L-shaped High-Intensity Discharge (HID) bi-xenon headlights with integrated fog lamps. Also the rear will feature large LED taillights – an Infiniti trademark, refined rear bumper and an integrated RearView Monitor camera. The camera will help you to have a 360 degree view of what was around you.
    Two of the most modern features included in the upcoming FX are: Slow moving traffic cruise control, meaning that the car will slow down and speed up based on the car in front of you and mirrors that will auto adjust when you move in the seat.
    نص الترجمة
    2009 ك ستكون متاحة في بلدين مختلفين خيارات : فك37 وفك50. انتم احد المشتبه فعلا ستكون الطاقة من 3.7 لتر وغيرها من محرك 5.0 لتر. فك37 ان يكون فيل بالطاقه نفسها 3.7 لتر فك السلاسل ف6 المحرك المستخدم في محرك غ37 بتصريح وسيلقي 300 حصان. في فك50 ستكون الطاقة من 5.0 لتر محرك بناتج 390 حصان و 369 رطل - قدم. فك37فهر الجديدة ، واستخدم للمرة الأولى في غ37 بتصريح تقوم على جائزة فك محرك سلسلة يدعي احد "افضل عشرة محركات" وارد في مجلة عالم السيارات لمدة 13 سنوات متتالية. القادم الى انتاج اكبر ، فك37 ستستخدم ايضا ففيل الجديد الذي يجمع بين نظام هيدروليكي تسيطر متغير ، وصمام توقيت صمام متغير الكترونيا يسيطر على رفع الكميه الى جانب مساعدة على تحسين الأداء والاستجابة. ان نظام ففيل ومن المتوقع ايضا ان الانبعاثات وتحسين كفاءه الوقود. 2009 ك سيكون بنفس أبعادها الحالية ك. ينفينيتي ستستخدم المواد التي من شأنها تقليل الوزن ، وهذا هو السبب وشيك ك سيكون اسرع بالمقارنة مع النموذج الحالي. اكبر ستجرى تغييرات على واجهة السياره. الخارج ستكون أكثر سبورتي والحديثة. الخارج يبرز ستشمل المتدفقه الجبهة درء المنحنيات ، فآسيا التعبيريه الجبهة مع ينفينيتي توقيع مزدوج قوس الحاجز ول شكل التفريغ عالية الكثافة (إخفاء) مرتين على الاطلاق الاضواء العلويه متكاملة مع مصابيح الضباب. كما ستبرز المءخره كبيرة ادت الاضواء الخلفية - ينفينيتي التجارية ، والمصد الخلفي المكرره متكاملة ريارفييو كاميرا مراقبة. الكاميرا يساعدكم ان يكون لها 360 درجة ترى ما حولك. وهما من اهم المعالم الحديثة في استونيا القادمة هي : البطيءه الحركة السياحيه ، وهذا يعني ان السياره سيتباطا وتسريع بناء على السياره امامكم ومرايا السيارات التي تتكيف وانت تتحرك في المقعد.
    الامبراطور غير متصل عضو نشيط
    Jun 2007
    80
    الف شكر على التغطية ياصديقي
    عاد انا منهبل على fx45 كيف عاااااااااااااااااااااااا ااااااااااااااااااااااااا ااااااااااااااااااااااااا اااااااد fx50
    شكلي ابنهبل علية من جد
    مب معقولة قوة المحرك 3.7 لتر الجديد 300 حصان بس!
    المفروض يكون أقوى لأن المحرك الحالي قوته 327 حصان.
    الإمــارات
    7,079
    اقتباس المشاركة الأصلية كتبت بواسطة uae speed مشاهدة المشاركة
    هذي القوه الصافيه للسوق الامريكيه
    يعني القوه الخام تطلع اكثر ولاتنسى بعض السيارات تجهز بعادم مضاد للتلوث ينزل من قوة السياره بعد
    الصورة الرمزية 760
    760
    760 غير متصل عضو فعّال
    929
    اتمنى يعدلون تصميم الداخلي الكئيب
