النتائج 1 إلى 6 من 15
    Red face لكزس تختبر الجيل الجديد من RX
    At first glance, this undisguised prototype might look like a normal Lexus RX350 sport utility vehicle. However, after close examination, it becomes apparent that there are some significant differences. The light colored vertical stripe just forward of the front doors indicates that the front end has been lengthened an inch or two. The ends of the front bumpers are modified and covered with tape, as are the lower parts of the rear doors. The rear bumper has also been cut away slightly just aft of the rear wheels. All these changes indicate the body has been modified to make the vehicle slightly longer, and to adapt to a slight relocation of both front and rear axles.
    Now notice that the tail lights don’t fit flush with the outer fenders, and are not wide enough to reach the side of the vehicle. Similarly, the rear glass hatch is too narrow to reach the full distance between the vehicle’s sides. So the body panels on this vehicle have also been relocated to make it wider than the current model RX350. So this vehicle is really a mule, using the body panels of the normal RX350, but very cleverly modified for extra length, wheelbase, and greater width. Under this modified body lies the new platform of the next generation RX350 which the test engineers are putting through its paces.
    The one part of the vehicle that really is new – the side mirrors. Note the reshaped mirrors which include the turn signal lights, a feature used by many rival vehicles, but so far not seen on the RX350.
    Based on this information, one can expect the next RX350 to be slightly longer, wider, and to have a greater wheelbase than it does now. With a vehicle as popular as the current RX350, however, Lexus is unlikely to make any radical changes. Styling will likely keep a shape that is quickly recognizable and evolutionary rather than all new.
    The new RX will also likely stay with its current 5-passenger capacity, since customers wanting three rows of seats can get that in the bigger Lexus SUV’s, the GX470 and the LX 570. Base engine will probably continue to be shared with the Toyota Highlander, that now being (for 2008) a 3.5 liter DOHC V-6 making 270 hp. The Lexus will likely also continue to offer a hybrid engine, the 3.3 liter V-6 which combined with its electric motors also makes 270 hp.
    Lexus will be introducing an all new LX570 for the 2008 model year, so it is likely that a new RX350 won’t be scheduled until 2009.
    The photo set includes 5 photos of the prototype mule, plus an artist’s concept of what the next generation RX350 will probably look like.
    Question
    ماجوف تعديل شي فيه والصورة تحت يعني حلوة طالعه، ماادري شكل هذا طول وايد مع لكزس
    نص الترجمة
    لأول وهلة ان هذا النموذج قد ينكشف تبدو طبيعية lexus rx350 الرياضة فائدة مركبة. ولكن بعد إمعان النظر ، يتضح ان هناك بعض الاختلافات الهامة. ضوء ملونة الراسي شريط عادل الامام من الابواب الاماميه تشير الى ان الواجهة الاماميه تم تمديد مدة بوصة أو اثنين. نهايات الجبهة مصدات تعدل ومغطاة الشريط ، وكذلك الأجزاء السفلى من الأبواب الخلفية. المصد الخلفي كما تم قطع مؤخرة السفينة بعيدا قليلا فقط للعجلات الخلفية. كل هذه التغيرات تدل على جثة تم تعديلها لتصبح السياره اطول قليلا ، والتكيف مع طفيفة نقل كل المحاور الاماميه والخلفية. الآن نلاحظ ان الذيل الاضواء لا يتناسب مع الاحمرار الخارجي حواجز ، ولا تتسع لتصل إلى جانب السياره. وبالمثل ، فان الزجاج الخلفي فتحة ضيقة جدا للوصول الى كامل المسافة بين السياره من الجانبين. حتى الجسد فريقي هذه السياره كما تم نقل جعله أوسع من النموذج الحالي rx350. حتى هذه المركبه هو حقا بغل ، وذلك باستخدام جهاز فريقي rx350 العادي ، ولكن معدلة بشكل ذكي جدا لمدة اضافية ، كروزر ، وزيادة العرض. تحت هذا المعدل الهيءه تكمن المنهاج الجديد من الجيل الجديد الذي rx350 الاختبار المهندسين من خلال وضع الاختبار. من جانب السياره التي هي حقا جديدة - المرايا الجانبية. ملاحظه تشكيل المرايا التي تشمل بدورها اشارة الاضواء ، وهذه سمة يستخدم كثير من السيارات المنافسة ، ولكن حتى الآن لم نشهد على rx350. واستنادا الى هذه المعلومات ، يمكن للمرء ان يتوقع المقبل rx350 يكون اطول قليلا ، أوسع ، وتزيد كروزر مما يفعل الآن. مع مركبة شعبية الراهنة rx350 لكن lexus المستبعد اجراء اي تغييرات جذريه. التصميم من المرجح ان تبقى على شكل التعرف بسرعة والتطوري وليس كل جديد. الجديد يقتضي ايضا احتمال البقاء الحالي 5 ركاب والقدرة ، لأن الزبائن الراغبين في ثلاثة صفوف من المقاعد التي يمكن أن تحصل في اكبر lexus للجيب ، وgx470 د - 60 570 - قاعدة محرك ربما سيستمر لاقتسامها مع تويوتا الجبال ، ويجري الآن (2008) 3.5 لتر 6 - DOHC في صنع 270 حصان. لدى lexus المحتمل ايضا مواصلة تقديم محركات هجينة ، 3.3 - 6 لتر في تجمع مع المحركات الكهرباءيه ايضا 270 حصان. Lexus سيتم ادخال جميع lx570 الجديدة لعام 2008 نموذجا ، لذا فمن المرجح ان rx350 الجديدة لن تعقد حتى عام 2009. الصورة تضم المجموعة 5 صور النموذج البغل ، بالاضافة الى الفنان مفهوم ما الجيل القادم rx350 ربما تبدو.
    الصورة الرمزية 2k2
    2k2
    2k2 غير متصل عضو نشيط جداً
    سلطنة عُمـــــان
    480
    not bad
    الصورة الرمزية فديت الامارات
    فديت الامارات غير متصل عضو نشيط جداً
    456
    اقتباس المشاركة الأصلية كتبت بواسطة 2k2 مشاهدة المشاركة
    not bad
    انا بعد قول not bad
    جاسم الدوحة غير متصل عضو نشيط
    Jul 2007
    149
    افتراضي الموتر (ذكر) .. والسيارة (أنثى)
    ليش يسمون هالسيارة عندنا سيارة (الحريم) .. هل لأن شكلها مقوس من الأعلى .. والتصميم ناعم ؟ معظم ( وما آقول الكل ) اللي يشترونها ويسوقونها .. حريم ، فهل هناك سيارة رجالية .. وأخرى نسائية؟ .. المهم أن الموديل القادم حلو إذا كان هذا شكله فعلا .. أسعد الله أوقاتكم
    Thumbs up
    اقتباس المشاركة الأصلية كتبت بواسطة جاسم الدوحة مشاهدة المشاركة
    أتفق معاك، أغلب اللي يسوقون هالموتر حريم!
    عندك بعد المرسدس C class و نيسان مورانو.
    التصميم الجديد كما هو واضح في الصورة الثالثه مشابه للبريفيا تقريبا ً، بس لو يغيرون الرنقات
    ويركبون تواير اكبر واعرض شوي بتطلع أحلى، مثل الانفنتي FX تقريبا ً تلقاه نازل وشكله سبورتي.
  1. لكزس تطرح في المنطقة LS 600hL أول سيارة هجينة بالكامل فاخرة
  2. الاختبارية شيناري.. اتجاه التصميم الجديد لسيارات مازدا
    بواسطة CRX في المنتدى أخبار السيارات
    آخر مشاركة: 10-09-2010, 11:11 PM
  3. لكزس تحافظ على مكانتها كأكثر الماركات الفاخرة بيعا للسيارات
    آخر مشاركة: 09-09-2010, 01:46 PM
  4. هيونداي تستعد لافتراس نيسان
    مشاركات: 18
    آخر مشاركة: 06-09-2010, 10:07 AM
  5. شبكة الجيل الرابع تدخل الدولة بداية 2011
    بواسطة روح زايد في المنتدى استراحة شباب الخليج
    آخر مشاركة: 06-09-2010, 12:25 AM
