الموضوع: Saab 9-7X Aero
    Wink Saab 9-7X Aero
    PRESS RELEASE
    Saab takes SUV-performance to a new altitude as it announces the Aero performance version of the Saab 9-7X today. The limited edition 9-7X Aero will make its way to dealer showrooms early this autumn.
    The Saab 9-7X brings unique Saab brand characteristics to the midsize SUV segment, including sophisticated styling inside and out, premium design features, and the sporty and spirited performance inherent to Saab vehicles. Since its debut two years ago, more than 12,000 have been sold in the U.S. and Canada. For 2008, Saab adds the Aero model - the symbol of serious Saab performance - to the 9-7X lineup. The limited edition 9-7X Aero takes Saab’s interpretation on the midsize SUV to an entirely new level accelerating the performance aspect of the sophisticated vehicle with a 6.0L V-8, 20-inch wheels and tires, unique paint and custom interior accouterments.
    “The 9-7X Aero is one great SUV to pilot,” Shannon said. “We are excited to offer enthusiastic drivers an increased level of performance with the Aero, a symbol of Saab performance, in the midsize SUV segment.”
    The new 9-7X Aero features a powerful, 6.0L small-block V-8 delivering 390 horsepower (295 kW) and 395 lb.-ft. (542 Nm) of torque. With 0-60 mph acceleration under six seconds, the 9-7X Aero is a treat for those who are actively passionate about the driving experience.
    The 9-7X Aero will be easy to spot as it wears a paint color all its own: Carbon Flash Metallic. The charcoal metallic paint nicely enhances the SUV’s clean lines. Specific to the 9-7X Aero are 20-inch polished, aluminum wheels wrapped with P255/50R20 V-speed-rated performance tires that provide the optimum balance between ride and handling. Complementing the refined and driver-oriented cockpit-inspired interior are “Aero” embroidered leather seats and embossed floor mats.
    Under the hood of the 9-7X Aero is the LS2 6.0L V-8 with a cold air induction package, rated at 390 horsepower (295 kW)* at 6,000 rpm and 395 lb.-ft. of torque (542 Nm)* at 4,000 rpm. The LS2 6.0L is based on the small-block V-8 architecture and delivers excellent down-low torque for strong off-the-line performance. Torque is inherent to the engine’s cam-in-block design, which features large 4.00-inch-diameter (101,6 mm) bores and a 3.62-inch (92 mm) stroke. Response is crisp and immediate, thanks to the electronically controlled throttle.
    Unique to the 9-7X Aero’s version of the engine is a composite intake manifold adapted to the LS2 engine to help produce balanced torque and horsepower. Maximum towing capacity on 9-7X Aero model is 6,600 pounds (2994 kg).
    Like all Saabs, the new Saab 9-7X Aero is driver-focused, with a lowered chassis tuned and tested to deliver responsive, balanced handling. Corner control and body roll control are improved with front stabilizer bars that are approximately 10 percent larger in diameter. Additional strength is provided by a heavy-duty rear axle with limited-slip differential.
    With a four-wheel disc braking system enhanced with larger, 12.8-inch (325 mm) front disc rotors and iron twin-piston calipers, it’s not difficult to put a stop to things in the more powerful 9-7X Aero. The heavy-duty iron calipers are stiff and retain their shape under high-pressure/high-heat braking conditions, providing a more linear feel and reduced pedal travel in high-energy stops. The brake pads use high-performance linings for strong fade resistance.
    ABS and automatic all-wheel-drive are standard on all 9-7X models as well as the StabiliTrak electronic stability control system that provides confident, sure-footed travel. The performance-oriented all-wheel-drive system delivers impressive on-road grip and enhanced “launch” feel. The always-engaged system uses a Torsen center differential to split torque between the front and rear wheels. It is a torque-bias system that detects low traction at one axle and directs more torque to the other when needed.
    Like all 9-7X models, the Aero model represents a terrific value with a high-level of standard equipment. In fact, the 9-7X boasts the most standard features in its class while offering a very competitive starting price at $39,935. The limited edition 9-7X Aero will start at $45,690, which includes a $745 destination fee and will begin arriving at dealerships this fall.
    جاسم الدوحة غير متصل عضو نشيط
    Jul 2007
    149
    Angry الطيب أحسن
    إبعد عن الشر وغني له .. وبس
    نص الترجمة
    صحفى صعب يأخذ جيب الاداء الى ارتفاعات جديدة حيث يعلن ايرو اداء النسخه ساب 9 - 7ك اليوم. الطبعه المحدوده 9 - ايرو 7ك سيجعل طريقها الى تاجر صالات العرض في بداية هذا الخريف. ساب 9 - 7ك تجمع فريد صعب خصائص العلامه التجارية الى ميدسيزي جيب جزء منها متطوره التصميم من الداخل والخارج ، وقسط المعالم التصميميه ، وأداء رياضي وحماسي متاصله صعب المركبات. منذ ظهوره قبل عامين اكثر من 12،000 بيعت في الولايات المتحدة وكندا. ل2008 ، صعب يضيف ايرو نموذج رمز خطيرة صعب الإداء الى 9 7ك التراصف. الطبعه المحدوده 9 - ايرو 7ك يأخذ صعب تفسيره على ميدسيزي جيب الى مستوى جديد تماما تسريع أداء الجانب من سيارة متطوره مع 6.0ل في 8 و 20 بوصة والعجلات والاطارات والدهانات والعادات الفريده التجهيزات الداخلية. "9 - ايرو 7ك احدة كبيرة الى جيب الطيار" شانون. "نحن ملتهبه حماسا لتقديم السائقين زيادة مستوى الاداء مع آيرو ، رمزا صعب الإداء ، في الجزء ميدسيزي جيب". الجديد 9 - ايرو 7ك ملامح قوية 6.0ل الصغيرة في الكتلة 8 - تسليم 390 حصانا (295 كيلووات) و395 لب.-فت. (542 نانومتر) من عزم دوران. 0 ميل بالساعه مع تسارع تحت ست ثوان ، 9 - ايرو 7ك هو متعة للذين بنشاط عاطفي عن قيادة التجربه. 9 - ايرو 7ك سيكون سهل البقعه حيث يلبس لون الطلاء جميع بنفسه : الكربون فلاش المعدني. الفحم الطلاء المعدني جيد يعزز جيب للخطوط نظيفة. تخص 9 7ك ايرو 20 بوصة ملمع الالومنيوم ملفوفه مع عجلات ب255/50ر20 السرعه في الاداء المرتفع للإطارات التي توفر التوازن الأمثل بين الركوب والتعامل معها. تكملة المكرره والسائق المنحى مستوحي من داخل مقصوره القيادة "آيرو" مطرز المقاعد الجلديه ومنقوش الكلمه ماتس. تحت غطاء المحرك لل9 - ايرو 7ك هو لس2 6.0ل الخامس - 8 مع الهواء البارد التعريفي صفقة صنفت في 390 حصانا (295 كيلووات) * عند 6،000 دورة في الدقيقة و 395 لب.-فت. من عزم دوران (542 نانومتر) * عند 4،000 دورة في الدقيقة. لدى لس2 6.0ل يستند الصغيرة في الكتلة 8 - الهندسه المعماريه ويسلم ممتازة تصغير عزم دوران منخفض قوية من خارج خط ال - الاداء. عزم دوران ملازم لمحرك للكام - لبنة في التصميم ، والسمات الكبيرة 4.00 بوصة وقطرها (101،6 مم) مملون و3.62 بوصة (92 ملم) بضربه. الرد الفوري وحديثة ، والفضل يعود الى خنق السيطرة الالكترونيه. فريد ل9 - ايرو 7ك رواية للمحرك المركب كمية متعددة مكيفة للس2 محرك مساعدة تنتج توازنا حصانا وعزم دوران. سحب اقصى قدره 9 - ايرو 7ك النموذج 6،600 جنيه (2994 كلغ). مثل جميع ساابس الجديد ، صعب 9 - ايرو 7ك هو سائق المركزه ، مع خفض الهيكل منغم واختبارها على تقديم استجابة متوازنه المناوله. ركن اندرول هيئة الرقابة والسيطرة تتحسن مع الجبهة مثبت الحانات ان ما يقرب من 10 فى المائة فى قطر. قوة اضافية يقدمها الثقيلة المحور الخلفي مع تفاضليه محدودة الإنزلاق. مع الرباعي قرص النظام الكابح معززه اكبر ، 12.8 بوصة (325 مم) امام القرص الدوار والحديد المزدوج الفرجار مكبس ، فإنه ليس من الصعب وضع حد لأمور في اقوى 7ك 9 - ايرو. الثقيلة واجب الحديد الفرجار هي قاسيه والاحتفاظ بها تحت شكل هيغ-بريسوري/هيغ-هيات الفرمله الظروف ، وتوفير المزيد من خطي يشعر دواسه السفر وانخفاض في الطاقة العالية تتوقف. الفرامل استخدام منصات عالية الاداء بطانات لقوى المقاومة تتلاشى. مكتب الاحصاء الاسترالي والتلقائي كل الدفع بالعجلات هي المعيار على جميع 7ك 9 - نماذج فضلا ستابيليتراك الالكتروني استقرار نظام مراقبة يوفر ثقة ، ثقة القدمين السفر. اداء المنحى جميع الدفع بالعجلات نظام يسلم راءعه على الطريق ، وتعزيز قبضة "اطلاق" الذي تشعر به. لدي دائما منشغلا يلجأ النظام تورسين مركز التفاضليه تقسيم عزم دوران بين العجلات الاماميه والخلفية. ومن عزم دوران التحيز ان يكتشف نظام الجر المنخفض في محور واحد وتوجه اكثر عزم دوران الى اخرى عند الحاجة. 9 - مثل جميع 7ك النماذج ، ايرو نموذج رائع يمثل قيمة رفيعة المستوى من المعدات القياسيه. وفي الواقع ، 9 - 7ك تفتخر اكثر السمات الثابتة في الطبقة حين طرح منافسة جدا ابتداء السعر 39،935 دولار. الطبعه المحدوده 9 - ايرو 7ك يبدأ بمبلغ 45،690 ، الذي يضم 745 المقصد الرسم وسيبدأ وصول وكالات في هذا الخريف
  1. SSC Ultimate Aero II
    بواسطة العراب في المنتدى أخبار السيارات
    آخر مشاركة: 13-09-2010, 12:12 PM
  2. شيلبي Ultimate Aero.........(قريبا)
    آخر مشاركة: 07-09-2010, 02:45 PM
