    Cool مرسيدس SLK 55 AMG Black Series
    The new Black Series from Mercedes-Benz is an even more driver-focused variant of the V8-powered SLK 55 AMG Roadster, using motorsport-inspired technology to deliver scintillating performance and enhanced driving dynamics. Output from the 5.5-litre AMG engine is boosted from 360 hp to 400 hp and 45 kg has been shaved off the kerbweight through the use of lightweight components including a new fixed hard top. As a result, the 0 to 62 mph dash drops from 4.9 to 4.5 seconds, while 125 mph is, where permitted, clocked up in just 15.5 seconds – a full two seconds quicker. Top speed is no longer restricted to 155 mph, and the car can reach 173 mph.
    The exclusive nature of the SLK 55 AMG Black Series is signalled by even more muscular front wings made from ultra-light carbon fibre-reinforced plastic (CRP) and a restyled AMG front skirt with carbon fibre inlays. Large air intakes and side air outlets ensure a sufficient flow of air to the enlarged engine oil cooler and new transmission and steering oil coolers.
    The SLK’s standard vario roof with its hydraulic closing mechanism has been replaced with a purposeful fixed hard top which has a central section in black carbon-fibre CRP. It means that not only is the car’s centre of gravity lower, there is also a significant weight loss – it now tips the scales over seven stones lighter than the standard car, at 1,495 kg, and the power/weight ratio improves from 234 hp/tonne to 268 hp/tonne.
    The motorsport theme continues inside: two specially developed AMG sports bucket seats without side airbags offer superb lateral support and are trimmed in a black pearl velour complete with silver AMG logos. They are complemented by a leather and Alcantara trimmed steering wheel derived from that used in the FIA Formula One World Championship Official Safety Car, and lightweight AMG carbon fibre internal door centre panels.
    The V8’s power output of 400 hp at 5,750 rpm compares with the standard AMG model’s 360 hp, produced at the same engine speed. It develops an even more muscular 520 Nm of torque at 3,750 rpm, up from 510 Nm at 4,000 rpm. Key enhancements include a modified air intake, an AMG sports air filter and a newly-developed exhaust system. Power continues to be fed through an AMG Speedshift 7G-TRONIC transmission with a manual drive programme and steering wheel-mounted aluminium shift paddles.
    Naturally the chassis has been modified to match the increased performance capability of this special series SLK 55 AMG. Racetrack-optimised, AMG height-adjustable torsion suspension, including adjustable dampers permits even more impressive cornering ability. 19 inch ultra-light AMG forged alloy wheels with 235/35 ZR 19 (front) and 265/30 ZR 19 (rear) Pirelli P Zero Nero tyres replace the 18 inch items of the standard car. Greater body rigidity is provided by a brace across the engine bay, and for those looking for even sportier handling, there’s a limited slip differential available, priced at €3,475.
    There is stopping power to match the performance and the front wheels continue to feature composite technology to minimise braking distances, optimise sensitivity and ensure high resistance to fading. The composite brake discs are now 360 mm in diameter, up from 340 mm. The 330 mm internally ventilated and perforated brake discs at the rear are retained.
    The SLK 55 AMG Black Series may possess a level of driving dynamics orientated towards track use, but it is also a car eminently suited to everyday driving and provides the safety, durability and quality that come as standard across the Mercedes-Benz range. The Black Series is also offered with three additional AMG packages for even greater exclusivity: an AMG Leather package includes leather seats, dash, centre console, centre armrest, door panels and doorbags, and anti-roll bars for €6,310. An AMG Interior Carbon Fibre package includes carbon fibre instrument cluster covers, steering wheel multi-function button covers, gearshift lever and door sill panels for €£2,630. An AMG Exterior Carbon Fibre package has carbon fibre front grille inserts, external mirror covers and rear boot spoiler trim, for €4,325.
    The SLK 55 AMG Black Series is priced at €92,500 euros and is available by special order from Mercedes-Benz Retailers now. The euro price is converted to Sterling at the point of ordering.
    Source: Mercedes-Benz
    Thumbs up
    نص الترجمة
    الجديد من السلسله السوداء مرسيدس هو اكثر سائق تركز على البديل للطاقة ف8 55 سلك حشد السياره باستخدام موتورسبورت بوحي التكنولوجيا لايصال الايماض الأداء وتعزيز الديناميه المحركه. الناتج من 5.5 لتر محرك حشد زاد من 360 حصان الى 400 حصان و 45 كلغ وقد محلوق قبالة كيربوييغت من خلال استخدام عناصر خفيفة بما جديدة ثابتة يصعب عليا. وكنتيجه لذلك ، 0 الى 62 ميل بالساعه داش قطرات من 4.9 الى 4.5 ثانية ، بينما هي 125 ميل في الساعة ، حيث يسمح فقط سجل وقت في 15.5 ثانية وهو اسرع الكامل اثنين ثوان. قمة السرعه لم يعد يقتصر على 155 ميل في الساعة ، ويمكن ان تصل السياره 173 ميل في الساعة.
    الطابع الحصري للسلك 55 يؤكدون السلسله السوداء التي تدل أكثر العضلات امام الاجنحه المصنوعه من غلاه ضوء الألياف الكربونيه - عزز البلاستيكيه (و) وأعيد تصفيف حشد جبهة تنورة مع الألياف الكربونيه البطانات. كبير مآخذ الهواء والجانب منافذ الهواء ضمان كاف تدفق الهواء الى المحرك الموسع النفط تبريد وارسال جديد وتوجيه مبردات الزيت.
    لدى سلك مستوى سطح فاريو مع هيدروليكي اقفال اليه بعباره هادفه الثابتة التي يصعب عليا مركزية قسم أسود الكربون الألياف crp.7 وهو لا يعني فقط ان السياره هي مركز الجاذبية أقل ، كما أن هناك خسائر كبيرة الوزن الآن نصائح جداول اكثر من سبع الحجارة أخف من مستوى السياره في 495 1 كغم ، والقوة / الوزن يحسن من 234 حصان / طن الى 268 حصان / طن.
    لدى موتورسبورت يزال داخل الموضوع : اثنان وضعت خصيصا لحشد الرياضية دلو المقاعد دون جانب أكياس الهواء الجانبية الدعم عرض رائع وتشذيبها في القطيفه اللءلء الأسود الكامل مع الفضه حشد الشعارات. انما تكملها الجلود وتشذيبها الكانتارا المقود مستمد من تلك المستخدمة في وكالة الاستخبارات الاتحادية بطولة العالم الفورمولا واحد مسؤول السلامة سيارة خفيفة وحشد من الالياف الكربونيه الباب الداخلي لمركز الفريقين.
    ف8 لدى السلطة الناتج 400 حصان عند 5،750 دورة في الدقيقة مقارنة مع مستوى حشد النموذج 360 حصان ، انتجت في نفس المحرك بسرعة. وهي تتطور العضلات أكثر من 520 نانومتر في عزم دوران 3،750 دورة في الدقيقة ، صعودا من 510 نانومتر فى 4،000 دورة في الدقيقة. تتضمن التحسينات الرئيسية معدلة كمية الهواء ، وحشد الرياضية فلتر الهواء وحديثة متطوره نظام العادم. السلطة تواصل يتعين اطعامهم من خلال حشد سبيدشيفت زاي - ترونيك مع ارسال كتيب البرنامج وحمله التوجيهيه عجلات ألومنيوم التحول المجاذيف.
    ومن الطبيعي ان الهيكل قد تم تعديلها لتتناسب مع زيادة القدرة على أداء هذه السلسله الخاصة سلك 55 بوسنة. - الحلبه الامثل ، وحشد الطول الالتواء تعليق قابل للتعديل ، قابل للتعديل بما يسمح الموهنات اكثر قدرة راءعه تحرجها. 19 بوصة غلاه ضوء يؤكدون تزوير مع عجلات سبيكه 235/35 عنصر الزركون 19 (الجبهة) و 265/30 عنصر الزركون 19 (العمق) pirelli ع الصفر نيرو استبدال الاطارات 18 بوصة بنود مستوى السياره. اكبر هيئة جمود فتقدمه يعدوا عبر محرك باي ، وبالنسبة لهؤلاء الذين يريدون معالجة حتى رياضية ، وهناك فارق محدود الإنزلاق متاحة بسعر 3،475 يورو.
    هناك سلطة ايقاف المباراة اداء والجبهة لا تزال سمة عجلات المركبه التكنولوجيا لتقليل المسافات وقوعها ، وضمان استفادة من حساسيه عالية مقاومه يتلاشى. أقراص الفرامل المركب حاليا في قطر 360 ملم ، مرتفعا من 340 ملم. 330 ملم داخليا التهويه ومثقب أقراص الفرامل في العمق هي الابقاء عليها.
    لدى 55 سلك حشد السلسله السوداء قد تمتلك مستوى القيادة ديناميات موجه نحو استخدام المسار ، وانما هو ايضا سيارة مناسبة تماما لقيادة اليوميه ويوفر الامان والمتانه والجوده القياسيه التي تأتي عبر مجموعة مرسيدس. السلسله السوداء كما عرضت مع ثلاث مجموعات اضافية من اجل حشد أكبر التفرد : حشد الجلديه وتشمل المجموعة المقاعد الجلديه ، داش ، مركز تعزية ، مركز سنده الذراع ، ودوورباغس وحة الباب ، ومكافحة اندرول القضبان ل6،310 يورو. وهو حشد الداخلية الألياف الكربونيه وتتضمن هذه المجموعة من الالياف الكربونيه صك المجموعة يغطي المقود متعدد الوظيفة زر يغطي ذراع التروس ورافعه عتبة الباب لفريقي يورو 2،630 جنيه استرلينى. وهو حشد خارج الألياف الكربونيه حزمة الألياف الكربونيه الجبهة الشبكه الملاحق الخارجية والعمق مرأة يغطي الحذاء المخرب تقليم ، 325 4 دولارا لليورو.
    لدى 55 سلك حشد السلسله السوداء بسعر يورو 005 29 يورو وفرتها امر خاص من مرسيدس التجزءه الآن. اليورو بسعر تحويله الى الاسترليني عند نقطة الطلب.
    المصدر : مرسيدس
    حلوة التعديلات عليها، وأهم شي أنهم زادوا قوتها شوي!
    أتوقع مرسيدس تحاول تصريف الكميات الزايده من الـ SLK بإضافة تعديلات متفرقه عليها، تمهيدا ً لنزول الـ SLK 63 AMG.
  1. هولدن تقدم كومودور (شيفرولية لومينا) 2011
    آخر مشاركة: 14-09-2010, 09:35 AM
  2. مرسيدس CL65 AMG بتعديل Anderson Germany
    آخر مشاركة: 05-09-2010, 05:08 PM
  3. مرسيدس SLS AMG Brabus
    آخر مشاركة: 26-08-2010, 03:55 PM
