    Talking ميتسوبيشي Concept-cX
    MITSUBISHI Concept-cX product features
    - The MITSUBISHI Concept-cX is a compact car that creates a new SUV/sports hatchback crossover category; a crossover that stirs a sense of adventure to "cut a swathe" through the hustle and bustle of urban life. The design gives the exterior a purposeful and functional form using a dynamic wedge shape and large tires. The front visage combines the inverted-slant nose with trapezoidal grille that defines the new Mitsubishi Motors design identity and tailors this to the car's crossover pedigree to project an appearance that is aggressive and powerful. The interior uses a modern and sporty design that engenders a sense of expectation about the car's performance and melds this with a high level of comfort. By visually accenting the strength of the underlying frame structure and through the contrasting use of soft padding, the design creates an interior space that wraps its occupants in a protective and comfortable cocoon.
    - The concept car uses a new high-output, high-efficiency 1.8-liter clean diesel engine, featuring a variable geometry (VG) turbocharger for optimum boost control and a diesel oxidation catalyst (DOC) with diesel particulate filter (DPF) in the exhaust system for compliance with Europe's Euro 5 emission standards. The power unit is mated to Mitsubishi's new Twin Clutch SST (Sport Shift Transmission) which delivers superior power transmission efficiency in a powertrain that realizes zippy performance with excellent fuel economy and low emissions.
    - MITSUBISHI Concept-cX employs interior trim materials made from Mitsubishi's own Green Plastic — made from plant-based resins — in a step to stop global warming and slow the depletion of oil reserves.
    - In its packaging MITSUBISHI Concept-cX 's 4100 mm compact body makes for easy maneuverability around town and the high driving position improves visibility and brings the easy drivability expected of a SUV. Utility is enhanced with the split tailgate already well received on the Outlander for the way it facilitates loading and unloading of luggage. In the performance department, Concept-cX also uses Mitsubishi's electronically-controlled 4WD system and large 225/45R19 tires to deliver outstanding handling performance and stability both on tarmac and off-road.
    Source: Mitsubishi
    معقوله متسوبيشي تفكر بسياره اصغر من اوتلاندر
    حلوه ها السياره و هي تشبه لفليوشن اليديده
    الصورة الرمزية Jaguar R
    Jaguar R غير متصل مشرف سابق
    U-A-E
    6,304
    تصميم حلو ومرتب.....
    الصورة الرمزية Mr_CoRvEtTe
    Mr_CoRvEtTe غير متصل مشرف سابق
    5,952
    مشكور اخوي ... من قدام تصميمها قريب من تصميم اللنسر اليديد ..
    رفجة عرب غير متصل عضو نشيط جداً
    QATAR
    323
    جميل وتصميم عصري ..
    ان نزل بيكون منافس حلو لسوزوكي سويفت
    الصورة الرمزية ERT
    ERT غير متصل Banned
    الشارقة
    2,441
    حلوه السياره , لكن من الداخل كأنك في سنه 2020 :D
  2. concept uae1
    بواسطة حتاوي7 في المنتدى قسم السيارات العام
    آخر مشاركة: 12-09-2010, 11:40 AM
  3. Mazda Shinari Concept
    آخر مشاركة: 08-09-2010, 11:26 PM
  4. ميتسوبيشي ASX تصل السوق البحريني
    آخر مشاركة: 06-09-2010, 05:18 PM
