    الصورة الرمزية ®Mr_Friday
    ®Mr_Friday غير متصل مشرف سابق
    30
    2,899
    افتراضي World's Fastest Production Car
    The Ultimate Aero is one of the most extreme vehicles on the road today, achieving incredible performance via its twin turbo V-8 engine. With an incredible 1,183-horsepower and 1094 ft.-lbs. of torque there is simply no other production car that can match the impressive raw power of the Ultimate Aero . Combine supreme power with its lightweight, aerodynamic body and the best handling systems available and SSC has delivered a vehicle that not only eclipses the performance of much more expensive vehicles, the Ultimate Aero is fully capable of owning the title of the World's Fastest Production Car.
    EngineType:
    Block and Heads (V-8)
    Displacement:
    387.2 cu.in.
    Bore x Stroke:
    4.125 x 3.620"
    Compression Ratio:
    8.975:1
    Horsepower:
    1183 bhp @ 6950 rpm
    Torque:
    1094 lb./ft. @ 6150 rpm
    Redline:
    7200 rpm
    Fuel Injection:
    Electronic Sequential Port
    Weight:
    422 lbs.
    Oil:
    SAE 5W/30 Fully Synthetic Racing
    Induction System:
    Sequential, multi-port fuel injection, Twin Turbo Chargers. Dual-Water to Air Intercoolers.
    Fuel:
    Premium Unleaded - 91 Pump Octane
    WarrantyBasic Warranty:
    1 Year / Unlimited Miles
    Powertrain:
    Rust-Through:
    N/A
    Chassis & BodyLayout:
    Mid-Engine/Rear Drive
    Body/Frame:
    Carbon Fiber/Composite/Steel Space Frame
    Brakes:
    Front: 14.0" Vented Slotted Discs/8-Piston Caliper.
    Rear: 14.0" Vented Slotted Discs/6-Piston Caliper.
    Wheels:
    Forged 3-Piece Alloy 19x9-1/2" Front, 20x13" Rear
    Tires:
    Michelin Pilot Sport PS2
    Front: 235 35 (YR)19.
    Rear: 335 30 (YR)20.
    Steering:
    Rack and Pinion, Assisted
    Turns, Lock to Lock:
    2.5
    Turning Circle:
    41.6 ft.
    Suspension:
    Front: Unequal Length Upper and Lower A-Arms, Coil Over Springs, Remote Reservoir-Adjustable Penske Coil-Over Shocks, Cab Controlled Air Lift, Anti-Roll Bar.
    Rear: Unequal Lengths Upper Rocker and Lower A-Arm, Adjustable Coil-Over Springs, Remote Reservoir-Adjustable Penske Coil-Over Shock, Anti-Roll Bar.
    The Ultimate Aero DynamicsCoefficient of Drag (Cd):
    0.357
    Frontal Area:
    19.0 sq. ft.
    Belly Pan:
    Complete flat belly pan with rear Venturi tunnels.
    General DataDry Weight:
    2,750 lbs.
    Weight to Horsepower
    Ratio (lbs/hp):
    2.33 - New Production Record!
    Weight Distribution F/R:
    Front: 42%
    Rear: 58%
    Wheel Base:
    105.2"
    Length:
    176.2"
    Width:
    82.7"
    Height:
    43.0"
    Ground Clearance:
    4.0"
    Trunk Space:
    2.6 cu. ft.
    AccommodationsSeating Capacity:
    2 Custom Recaro Seats
    Headroom:
    38.5"
    Seat Width:
    2 x 19"
    Leg Room:
    47.0"
    Seat Back Adjustment:
    25º
    Seat Travel:
    6.0"
    DrivetrainGear
    Ratio
    RPM
    MPH
    1st
    3.00:1
    7200
    58.517
    2nd
    2.15:1
    7200
    81.651
    3rd
    1.5:1
    7200
    117.033
    4th
    1.1304:1
    7200
    155.294
    5th
    0.8667:1
    7200
    202.557
    6th
    0.6452:1
    7200
    272.102
    Final Drive Ratio: 3.4444:1
    Engine RPM @ 60 Top Gear: 1550
    InstrumentationGauges:
    260-mph Speedometer, 8000-rpm Tachometer, Sequential Shift Lights, Horsepower Gauge, Oil Pressure, Water Temperature, Fuel Level, Volt
    Audio/Video:
    Navigation System, 10-Speaker Premium Audio/CD/DVD System, 7.5" Video/DVD Screen, Automatic Back-Up Camera
    Standard EquipmentIncludes:
    Air Conditioning, Power Windows, Power Mirrors, Tilt-Steering, Cab-Controlled Front Air Lift
    Record-Breaking Times0-60 mph:
    2.78 seconds
    1/4 Mile:
    9.90 seconds at 144 mph
    Top Speed:
    257.11 MPH / Official Average: 255.83 MPH
    Skidpad:
    1.05 g
    0-100mph-0:
    11.66
    60mph-0 (braking):
    103 feet
    Shelby Supercars - Home of the Fastest, Most Powerful Production Car Ever Made - The Ultimate Aero.
    صقر الشارجه غير متصل عضو فعّال جداً
    UAE-SHJ
    1,351
    مشكوووور يا الغالي موضوع طيب وما تقصر مواصفات ارهابية قووية ... بانتنظارها في معرض الشرق الاوسط في دبي
  2. 2005 LINCOLN TOWN CAR SIG SIGNATURE
    بواسطة nid_nj في المنتدى قسم البيع والشراء
    آخر مشاركة: 04-09-2010, 11:26 PM
