    Rashoodz غير متصل عضو نشيط
    175
    افتراضي F-Sport accessories for Lexus IS
    Las Vegas, NV
    - In one of the most widely anticipated announcements for Lexus IS enthusiasts, Lexus today unveiled F-Sport, its first-ever performance accessory line available for the IS 250, and the IS 350. The F-Sport Accessory Line includes a wide cross-section of performance enhancing products engineered by TRD and covered by the Lexus new vehicle warranty, including:
    F-Sport Front and Rear Brake Upgrade
    The Front Brake Upgrade provides a firmer pedal feel and improved fade resistance in repeated severe duty use. The Brake features six piston fixed calipers, and drilled cast iron 355mm diameter rotors with a patented internal fin design mounted on anodized aluminum hubs. Braided stainless steel brake lines and low-dust performance brake pads are included and the upgrade can be used with stock or F-Sport upgraded rear brakes. The rear brake upgrade uses four piston fixed calipers and drilled cast iron 345mm diameter rotors. The Rear Brake Upgrade may only be used in conjunction with F-Sport Front Brake Upgrade.
    The other brake upgrade unveiled was a new Continuous Carbon Ceramic Brake Upgrade. A new generation of carbon fiber-reinforced ceramic material technology maximizes high-temperature durability and system cooling in this ultimate upgrade for the IS-F. Ceramic rotors measure 380mm diameter front and 355mm diameter rear on anodized aluminum hats. They incorporate the same internal cooling vane concepts as the F-Sport cast iron rotors, while significantly reducing unsprung and rotating mass compared to the IS F stock brake system. Distinctively finished six-piston front and four-piston rear fixed calipers signify leading-edge technology and performance. Specially qualified performance brake pads and stainless steel brake lines are included.
    F-Sport 19” Forged Alloy Wheels
    This lightweight forged alloy wheel, exclusively designed in a dark graphite finish, includes a staggered fitment with 19” X 8” front wheels and 19” X 9” rear wheels.
    F-Sport Carbon-fiber engine cover
    Constructed from real carbon fibers, this very light and durable engine cover provides a high-tech appearance under the hood. This is a direct replacement for the original cover and is only available for the IS 350.
    F-Sport Air intake
    This low restriction intake and filter assembly is fully compatible with stock engine controls and is emission legal in all 50 states.
    F-Sport rear chassis member brace and F-Sport Sway Bar Set
    To improve chassis stiffness under aggressive driving conditions and provide a more responsive feel during cornering, the F-Sport Rear Chassis Member Brace joins key rear chassis and suspension mounting points through this tubular steel brace.
    The F-Sport Sway Bar Set includes a set of larger diameter, replacement front and rear sway bars that offer reduced body roll and flatter cornering. Urethane mounting brushings are also included to replace the original rubber brushings.
    F-Sport clutch
    The F-Sport Clutch increases clamping force approximately 15% to handle higher torque capacity and provide improved feel.
    F-Sport Lowering Springs and Bilstein Shock Absorbers
    The F-Sport Lowering Springs lower the vehicle approximately 1” in the front and rear for a more aggressive appearance and a lower center of gravity. The spring set is engineered to deliver lowered ride height without bottoming out or creating a harsh ride. The feature can be used with either the stock or F-Sport shock absorber set.
    Developed in cooperation with Bilstein and available exclusively through the F-Sport Performance Accessory program, the F-Sport Shock Absorber Set offers sport-tuned suspension dampening without sacrificing ride quality.
    F-Sport Quick Shifter
    Engineered and machined from billet aluminum, the F-Sport Quick Shifter decreases shift throw by approximately 30% for positive shifting.
    F-Sport Exhaust System
    This system features all stainless steel construction with fully polished mufflers and double-wall exhaust tips. In addition to an outstanding appearance, it delivers a powerful, sport-tuned exhaust sound.
    175
    175
    eL-MiSHne9 غير متصل عضو جديد
    Ya36ek El 3afia 7ajee Oo 9ara7a Hal Motaar 7adaa Dash Mazaajy ;]
  1. لكزس تقدم RX270 و IS350 F Sport.....(جديد اليابان)
    آخر مشاركة: 28-08-2010, 02:41 PM
  2. سوزوكي تضيف AWD ل Kizashi Sport
    آخر مشاركة: 25-08-2010, 03:54 PM
