    VTEC غير متصل عضو جديد
    Jeddah
    افتراضي صور انتاجية ل 2007 Chevrolet Silverado و GMC Sierra
    السلام عليكم جميعا
    صورة ل Chevrolet Silverado موديل 2007
    و صورة ل GMC Sierra موديل 2007
    ناتي للمواصفات .. و اعذروني يا شباب ما قدرت اترجمها لانها كثيرة مرة ...
    Depth and breadth of lineup:
    · Chevrolet Silverado, GMC Sierra and Sierra Denali light-duty pickups
    · Chevrolet Silverado and GMC Sierra heavy-duty pickups
    · Three cab styles: regular, extended and crew cab
    · Three box lengths - short (5 foot 8 inches), standard (6 foot 6 inches) and long (8 foot)
    · Eight diverse and efficient powertrain combinations
    · Five distinct suspension packages, including one for maximum trailering capability
    · Three Silverado trim levels; four Sierra trim levels, including exclusive Sierra Denali model
    · Light-duty payload capacities from 1,564 pounds (709 kg) to 2,160 pounds (980 kg)
    · Light-duty trailering capability from 4,300 pounds (1,948 kg) to segment-leading 10,500 pounds (4,763 kg)
    · Light-duty models arrive in fourth quarter of 2006; heavy-duty models in first quarter of 2007
    Distinctive exterior designs:
    · All-new exterior designs with strong, confident appearance
    · Brand-differentiated designs with unique front-end appearances including unique hoods, front fenders, grilles and headlamps, and differentiated taillamps and pickup box designs
    · Refined appearance with tighter tolerances and reduced body gaps including 50-percent tighter gap between cab and box
    · Sleeker, more aerodynamic 57-degree windshield angle
    · Wider and lower stance
    · New 170-degree-opening rear access doors on extended cab models
    · Improved body-to-wheel proportions
    · Family of larger 17-, 18- and 20-inch wheels
    Spacious and refined interiors:
    · Two all-new, distinct and spacious interior designs with superior craftsmanship
    · Pure pickup interior with unique instrument panel, seats, door panels, consoles, double glove boxes, trim and features on Silverado WT, LT and Sierra WT, SLE models
    · Luxury-inspired interior with unique instrument panel, seats, console, glove box, door panels, trim and features on Silverado LTZ and Sierra SLT models
    · Use of premium materials with lower gloss levels
    · Flush fits and close-outs that conceal seat hardware
    · Instrument panels positioned down and forward for increased visibility and spaciousness
    · Increased storage capacity in center consoles and glove boxes
    · Innovative underseat storage on pure pickup interior
    · Quiet interior achieved with extensive use of noise-reducing materials, spray-on damping, foam and seals
    Exceptional driving experience:
    · Segment-leading V-8 horsepower and fuel economy
    · Technically advanced Gen IV small-block Vortec V-8 family, including E85 capability, fuel-saving Active Fuel Management and variable valve timing
    · Wider front and rear tracks (3 inches front / 1 inch rear)
    · All-new, stronger and stiffer fully-boxed frames with hydroformed front section
    · New coil-over-shock front suspension
    · New rack-and-pinion steering system
    · New splayed rear shock arrangement
    · Improved brake system with new generation Bosch ABS system
    · Five uniquely tuned suspension packages, including enhanced trailering package
    · GMC Sierra Denali with exclusive 6.2L V-8 and six-speed automatic transmission
    Comprehensive safety and security:
    · Standard StabiliTrak electronic stability control system with new rollover mitigation technology on crew cab models (available on extended cab models)
    · 360-degree perimeter of safety protection, including industry-exclusive rear impact sensors
    · Dual-stage frontal air bags with passenger sensing system
    · Roof-mounted head curtain side air bags
    · Strengthened chassis and body structure for superior crashworthiness
    · Frame designed for compatibility with smaller vehicles
    · Ultrasonic Rear Parking Assist
    · Standard OnStar
    Unique features and options:
    · 170-degree-opening rear access doors on extended cab models with fully retractable rear power windows
    · Power sliding rear window (extended and crew cabs)
    · Theater-style folding rear seats for ease of loading cargo
    · Automatic locking rear axle
    · Innovative cargo management system with comprehensive array of accessories
    · Remote vehicle starting system
    · Enhanced DVD entertainment system with larger screen
    · New CD/MP3 radio family
    · Touch-screen navigation system
    · Heated windshield washer fluid
    · Rain-sensing automatic windshield wipers
    Engine offerings include:
    * 4.3L V-6 (LU3), rated at 195 hp (145 kW) and 260 lb.-ft. of torque (353 Nm).
    * 4.8L V-8 (LY2), with iron block; rated at 295 hp (220 kW) and 305 lb.-ft. of torque (414 Nm)*.
    * 5.3L FlexFuel V-8 (LMG), E85-capable with iron block and Active Fuel Management, rated at 315 hp (235 kW) and 338 lb.-ft. of torque (458 Nm)*.
    * 5.3L FlexFuel V-8 (LC9), E85-capable with aluminum block and Active Fuel Management, rated at 315 hp (235 kW) and 338 lb.-ft. of torque (458 Nm)*.
    * 5.3L V-8 (LH6), with aluminum block and Active Fuel Management, rated at 315 hp (235 kW) and 338 lb.-ft. of torque (458 Nm)*.
    * 5.3L V-8 (LY5), with iron block and Active Fuel Management, rated at 315 hp (235 kW) and 338 lb.-ft. of torque (458 Nm)*.
    * 6.0L V-8 (L76), with aluminum block, variable valve timing and Active Fuel Management, rated at 367 hp (274 kW) and 375 lb.-ft. of torque (508 Nm)*.
    * 6.2L V-8 (L92), with aluminum block and variable valve timing, rated at 400 hp (298 kW) and 417 lb.-ft. of torque (565 Nm)** - exclusive on GMC Sierra Denali.
    دمتم في حفظ الله .
    الصورة الرمزية bo_3lwaa_a
    bo_3lwaa_a غير متصل عضو متميز
    كويت الغاليه
    2,317
    ثانكيوووووووو على الصور و المواصفات
    مقارنه رااااااااائعه
    بوعلوه
    الصورة الرمزية محبكم ومغليكم
    محبكم ومغليكم غير متصل عضو نشيط جداً
    جدة - عروس البحر الأحمر
    477
    مشكور على الصور VTEC
    شكرا اخوي على الصور والمعلومات
    ننتظر جديدك
    ابداع2004 غير متصل عضو نشيط
    140
    مشكور اخوي على الموضوع واشوفها احلى من سابقتها بتحفظ 00
    تحياتي محمد الهاجري000
    الصورة الرمزية مؤيد اف1
    مؤيد اف1 غير متصل عضو فعّال
    798
    تحسن كبير الى الامام...مشكور
  1. Callaway شغاله في Chevrolet Silverado 1500
    بواسطة Patrol 5.6 VVEL في المنتدى قسم السيارات العام
    آخر مشاركة: 29-08-2010, 10:03 AM
  2. تجربة قيادة شفرولية سلفيرادو 2008 Chevrolet Silverado Test Drive
    بواسطة grandv8 في المنتدى تجارب السيارات
    مشاركات: 68
    آخر مشاركة: 19-03-2009, 06:03 PM
