الرئيسية التعليمـــات المجموعات الإجتماعية التقويم البحث مشاركات اليوم اجعل كافة الأقسام مقروءة
  منتدى الخليج للسيارات > أقسام أخرى > الكمبيوتر والتكنولوجيا الحديثة
إضافة رد   مشاركات   215   - المشاهدات   7700
LinkBack أدوات الموضوع انواع عرض الموضوع
  #21
قديم 07-12-2007, 09:46 PM
مشرف سابق
السيارة: 3.8 Genesis Coupe
مثل ماتوقعت ملفات البوت تبع فيستا تختلف عن XP
لقيت طريقة لكن الظاهر لازم تسويها قبل لاتحذف فيستا لأنك تحتاج ملفات من مجلد فيستا نفسه......
Removing Windows Vista from a dual-boot configuration
If you want to remove Windows Vista from a dual-boot environment that includes an earlier version of Windows, follow these steps.
Note You can follow these steps in the earlier version of Windows or in Windows Vista. If you follow these steps in Windows Vista, run the commands from a command-prompt that has elevated user rights. To do this, click Start, click Accessories, right-click the command-prompt shortcut, and then click Run as Administrator. 1. Use Bootsect.exe to restore the Ntldr program. To do this, type the following command: Drive:\Boot\Bootsect.exe –NT52 All
Note In this command, Drive is the drive where the Windows Vista media is located.
After the computer restarts, it does not load the Windows Boot Manager program. Instead, Netldr.exe loads and Boot.ini loads.
2. Delete or remove the partition where Windows Vista is installed.
Important You can only delete the partition where Windows Vista is installed if that partition is the non-active partition on the system. For example, consider the following scenario: • Windows Vista is installed on drive C. Drive C is partition 1 and is the active partition.
• Windows XP is installed on the drive D. Drive D is partition 2 and is the non-active partition.
In this scenario, you can run the bootsect command, but you cannot delete the partition where Windows Vista is installed. If you delete this partition, the computer is put into a non-bootable state because Windows XP boot files are deleted.
http://support.microsoft.com/kb/919529/en-us
قديم 08-12-2007, 08:56 PM
الصورة الرمزية UAE.abdullah
Thumbs up
المشاركة الأصلية كتبت بواسطة Prelude 4 Life مشاهدة المشاركة
اعتقد ملف ال Boot تبع فيستا يختلف مونفسه boot.ini
لو كان كلامي صحيح بيكون الملف ماله اي داعي وحتى لو حذفته مابيأثر
لأن الكمبيوتر اساسا مايستخدمه عندك في بداية التشغيل ويستخدم بداله ملف البوت الخاص بفيستا لما ثبتته
احاول الاقي حل لموضوعك ان شاء الله
كبداية ابحث عن ملف BCDEDIT.EXE في جهازك وشوفه موجود والا لأ وفي اي درايف؟
سؤال.. كيف حذفته الفيستا؟
-سويت بحث وما لقيت الملف.
-الفيستا حذفته بطريقه عاديه من الـ D ، كنت مسوي فولدر ومثبت الفيستا فيه، وحذفت الفولدر كله.
مشكورين شباب، الحين ما في حل الا الفورمات طبعاً، بس مب الحين!
لأني ناوي أسوي Upgrade لجهازي (مذربورد و رامات وكرت شاشه).
أول شي بغير المذربورد القديم اللي عندي Acer E61ML وبركب قيقابايت GA-P31-S3L ..
شريته بـ 400 درهم من الوكيل مع ضمان 3 سنين، وأعتقد المذربودر هذا مناسب لي ولإستخداماتي، وفي المستقبل أكيد بطوره أكثر، بس شوي شوي مب لازم اطلع فوق مره وحده.
والرامات 2GB DDR2 .. وكرت الشاشه لين الحين ما قررت.
على فكره شو رايكم في المذربورد؟ هل توفقت فيه؟
الصور المصغرة للصور المرفقة
اضغط على الصورة لعرض أكبر
الاســـم:	mb.jpg‏
المشاهدات:	175
الحجـــم:	88.3 كيلوبايت
الرقم:	20545
قديم 08-12-2007, 09:51 PM
الصورة الرمزية Silver
مشرف سابق
السيارة: جوتي مقاس 11"
أنا ما جربت الفيستا لأن الـ XP S2 ماشي تمام ... لكن جرب تشوف هذي الطريقة ممكن تنفع How to Uninstall Windows Vista easily without any hassles
خاصة هذي الفقرة ممكن تحل مشكلتك
Now in order to restore the old boot sector you will have to type “D:bootbootsect /nt52 c:” and in case of an error just select another letter, something like this “E:bootbootsect /nt52 c:”. Now type “c:” hot enter, then “cd” and enter, and then “attrib boot.ini.saved -s -h –r” and “ren “boot.ini.saved” “boot.ini”” each followed by an enter. The final command is “attrib boot.ini +s +h +r”, press enter and type exit, press enter and click restart in the System Recoveri Options window.
Your previous copy of Windows should be in place. Just delete all the files that Windows Vista has left behind.
اللوحة الأم اظن إنها جيدة إذا ماكنت لك نية كسر السرعة ... حق استخدام ولعب أي لوحة ام برقاقات جيدة و شق PCI-e 16X كافية ...
ياالله حِسن الخاتمه
قديم 08-12-2007, 11:57 PM
الصورة الرمزية الهاوي جروب
مشرف الكمبيوتر والتكنولوجيا الحديثة
السيارة: صني
ماشاء الله اللوحه جميله وفيها خاصيه في الصوت انه هاي دفنيشن
وحاول تشغل خدمة الدايل شنل بوضع رامين بنفس الحجم اعتقد انها تختار لون من الوان مد
اخل الرامات وتحطها فيه لكن تاكد من الكتلوج
قديم 27-01-2008, 11:42 AM
الصورة الرمزية بوراس
اقول في حل حق الفيستا؟ ما اقدر اشوف الفيديو عليه
قديم 01-02-2008, 12:54 AM
السيارة: صني
أخوي ركب الريل بلير 11 وركب الكودكس وكل شي بيش تغل تمام لكن لو سمحت وضح مشكلتك بالتفصيل وان شاء الله نلقالك حل
قديم 02-02-2008, 12:02 AM
الصورة الرمزية الزرعوني
مشرف الفني
السيارة: Black FJ 09
السلام عليكم
يا جماعه الكمبيوتر اللي فالبيت مخرف !!
يوم ابطل اي ملف ..
احط ع التوولز .. ماشي Folder Option !!!
دشيت على الـ Help and Support و حطيت Folder Option
و طلعلي هذا !!
الاســـم:	aasddf.jpg‏
المشاهدات:	145
الحجـــم:	124.8 كيلوبايت
الرقم:	21943
قديم 02-02-2008, 04:59 AM
المشاركة الأصلية كتبت بواسطة الهاوي جروب مشاهدة المشاركة
هيه ذكرتني الكوداكس.. نزلته و اشتغل الفيديو .... تسلم أخوي
قديم 02-02-2008, 05:09 AM
مشرف سابق
المشاركة الأصلية كتبت بواسطة الزرعوني مشاهدة المشاركة
السلام عليكم
يوم ابطل اي ملف ..
و طلعلي هذا !!
عند في الجهاز برنامج مكافح للفايروسات ؟؟؟
أذكر قبل فترة طويلة كنت أواجه نفس المشكلة ... ولقيت إن السبب هو وجود فايروس في الجهاز ... ممكن تكون هذا المشكلة عندك انت بعد
فإذا ما كان عندك برنامج مكافح للفيروسات، فركب واحد ... وإذا كان عندك فحدثه
ياالله حِسن الخاتمه
قديم 03-02-2008, 07:28 PM
السيارة: صني
هلا جهازك فيه فيروس ياعسل شفلك مكافح فيروسات لكن تقدر تفتحها بالدق على يمين اوبن
