    ينتهي الإعلان بتاريخ 2008/7/6
العودة   منتدى الخليج للسيارات > منتدى السيارات > أخبار السيارات
أخبار السيارات أخبار السيارات وجديدها و صور السيارات في طور التجارب والجديد بالأسواق .
قديم 25-04-2008, 04:01 PM
AMG AMG غير متواجد حالياً
السيارة: سيارتين
Wink شيفرولية تكشف عن قوة ZR-1 الرسمية
LS9 details
The LS9 features many unique design and manufacturing details that support its high-performance nature. They include:
Aluminum cylinder block with iron cylinder liners that are finish-bored and honed with a deck plate installed
Forged steel crankshaft with a nine-bolt flange
Titanium connecting rods and forged aluminum pistons
Stronger, rotocast cylinder heads with 2.16-inch (55 mm) titanium intake valves and 1.59-inch (40.4 mm) hollow-stem, sodium-filled exhaust valves
Camshaft with 0.555-inch (14.1 mm) lift for excellent idle and low-speed driving qualities
A dry-sump oiling system with 10.5-quart (9.9 liters) capacity
Integrated oil cooler and piston-cooling oil squirters
Intercooler cover visible through the hood window that features ZR1-unique blue accents and "LS9 SUPERCHARGED" embossed on the left and right sides
Specifications
LS9 6.2L SUPERCHARGED V-8
Displacement (cu in / cc):
376 / 6162
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
Block material:
cast aluminum
Cylinder head material:
A356-T6 rotocast aluminum
Valvetrain:
overhead valve, 2 valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
9.1:1
Horsepower / kW:
638 / 476 @ 6500 rpm
Torque (lb-ft / Nm):
604 / 819 @ 3800 rpm
Fuel shut-off (rpm):
6600
Recommended fuel:
premium required
Exhaust manifolds:
stainless steel
Main bearing caps:
forged steel
Crankshaft:
forged steel
Camshaft:
hollow steel; 0.555-in (14.1 mm) lift
Connecting rods:
forged titanium
Valves:
intake: titanium
exhaust: hollow steel
Valve lifters:
hydraulic roller
Supercharger:
R2300, four-lobe "Roots" type (2.3L)
Additional features:
piston oil-spray cooling; direct-mount ignition coils; 11-rib accessory drive
الصور المصغرة للصور المرفقة
اضغط على الصورة لعرض أكبر
الاســـم:	1.jpg‏
المشاهدات:	498
الحجـــم:	42.9 كيلوبايت
الرقم:	23961  اضغط على الصورة لعرض أكبر
الاســـم:	2.jpg‏
المشاهدات:	498
الحجـــم:	78.9 كيلوبايت
الرقم:	23962
أمحو ذنوبك في خلال دقيقتين
أخي الحبيب في الأخير أتمنى أن تدعوا لي ولوالدي بكل ما هو خير
وان تدعوا لي بالتوفيق في دنيتي وآخرتي و في دراستي
ولـ صاحب الفكرة جزاه الله ألف خير
ووفق الله ناشرها وقارئها وأدخلهم فسيح جناته
http://www.shbab1.com/2minutes.htm
التعديل الأخير تم بواسطة : uae speed بتاريخ 25-04-2008 الساعة 07:45 PM.
قديم 25-04-2008, 04:12 PM
الصورة الرمزية C A D I L L A C
المشرف المتميز لأخبار السيارات
السيارة: 2006 pajero SWB
واييييد
مع ان الاداء ماا احس انه تغير
قديم 25-04-2008, 04:15 PM
السيارة: نيسان ماكسيما 99
قوة خارقة ، عزم جبار ، اتوقع التسارع يكون اقل من 3.5 ثانية
بالفعل تحفة ميكانيكية !!
قديم 25-04-2008, 04:22 PM
عضو فعّال
السيارة: Porsche 997 Turbo, Maserati Granturismo
لكنها ماتفوقت على اليابانيه جي تي - آر
قديم 25-04-2008, 07:50 PM
الصورة الرمزية uae speed
السيارة: accord 2006
ودي أشوف مستواها ويا الـ Zo6 ، أدري ان الـ ZR1 بتتفوق بس ابا اعرف كم مستوى الفرق بينهم بالضبط.
قديم 25-04-2008, 08:22 PM
الصورة الرمزية Nasser
قوة خياليه بدون مراعاة الأمن و الثبات
قديم 25-04-2008, 09:41 PM
عضو فعّال جداً
السيارة: Accord V6
على اي اساس اخوي مافيها ثبات
بالعكس ال zo6 القديمه ثباتها والتحكم فيها روعه وتقدر تشوف تعليقات وتحليل ناس محترفين جربوها مثل برنامج توب قير وغيره وهذي مابعد تنزل عشان تحكم
اعتقد بتكون السياره خارقه وبنشوف وش تقدر تسوي مع النيسان جي تي ار اول مانزلت ال z06 الجديده قالو تسارعها 4 ثواني وجابت ارقام اقل وال zr-1 اعتقد منافسه جدا للسوبر كارز
مشكور اخوي عمر على المعلومات
M-POWER
قديم 25-04-2008, 10:12 PM
الصورة الرمزية Mr.K H A L E D
مشرف السيارات العام
السيارة: HAMMER H2 + BMW745
قوه عجيبه بهالمحرك...
ودي اشوف التسارع بينها وبين ال جي تي
سبــحآن الله وبحــمدهـ
سبحـآن الله العظيم
قديم 26-04-2008, 12:43 AM
الصورة الرمزية PORSCHE
عضو فعّال جداً
السيارة: Mitsubishi Magna
انا عاجبني شكل المحرك بس ههههههه
The Technology Of Germany Engineering
قديم 26-04-2008, 02:40 AM
عضو جديد
السيارة: هوندا civic
المشاركة الأصلية كتبت بواسطة Porsche Stuttgart مشاهدة المشاركة
كل شي بوقته حلو
