THE ULTIMATE "MOUNTAIN MOTOR" FOR TOP SPORTSMAN, TOP DRAGSTER
2007 811 CU. IN. ENGINE WITH SONNY'S DESIGN
5.00" B.S. GM HEMISPHERICAL CYLINDER HEADS.
1700 NATURALLY ASPIRATED H.P. (NO NITROUS)
Special Features:
Sonny's in-house fully CNC ported "Next Generation" Hemi cyl. heads
SAR Special Billet Aluminum 5.00" B.S. block with 1.00" raised cam
Bryant billet crank
BME 426 aluminum forged rods
Venolia pistons
Jesel keyed lifters
1.031" tool steel taper-wall pins
Federal Mogul "Hell Fire" rings
Special titanium valves & PSI springs
SAR shaft mounted rocker system with needle bearing roller tips
Jesel belt drive
Moroso 4-stage dry sump oiling
Moroso vacuum system
ATI balancer
MSD cranktrigger ignition
SAR sheetmetal 4x2 intake with linkage
SAR/BLP (4) 2 barrel split dominator carbs
Sheetmetal billet rail valve covers
Meziere hi-flow electric water pump
Pro series CSI starter
Fuel lines with 4 port regulator
وهذا رابط صورة المحرك
http://www2.0zz0.com/2008/05/20/08/906480097.jpg
