أعلن لدينا    كل عام وأنتم بخير    أعلن لدينا
قديم 03-06-2008, 09:01 AM
افتراضي خلطة لمحرك سباق سيارت الربع ميل 705 كيوبك أنش
http://www2.0zz0.com/2008/06/01/11/279967625.jpg
705 "The Hulk" Aluminum Donovan Drag Racing Engine - 1360 HP
Bore 4.600 x Stroke 5.300
1360 HP / 1125 Ft. Lbs. Torque
The Ultimate Top Sportsman Engine!
This high performance drag racing engine starts with a Donovan aluminum block with a 11.625" deck height with a +.400" raised big cam core and off-set lifter bushings. It is a 4.600" bore with a special partial solid block at the bottom to facilitate stroke clearance. A Callies crank with a 5.300" stroke starts out the bottom end and connects the GRP rods to a set of Schmidt/JE pistons using Total Seal Piston Rings.
A Comp Cams Big Cam core with the 4 & 7 firing order swap handles the timing duties and is connected to an MSD distributor made special for the 11.600" deck height. An MSD Crank trigger and wires handles the firing of this bad boy. A set of Schmidt/Pro-Filer 12° cylinder heads with Manley custom titanium valves, retainers and locks start off the top end of this monster. They are hooked up to an HRE (Schmidt Designed) sheet metal manifold and that is topped off with two Quick Fuel Pro Stock Style Dominator Carburetors. A Moroso oil pump and dry sump oil pan connected to a Stef oil tank keeps everything lubed.
* This engine was fitted with a mild cam for bracket racing (see dyno sheet
We also have a 1400 HP version and a Nitrous version at the same price. Call for Details!
ENGINE INCLUDES THE FOLLOWING COMPONENTS
• Donovan Block ( 11.625 deck Height) with Big Cam Core with off-set Lifter Bushings & + .400 Raised Cam, 4.600 Bore Special Partial Solid Block at Bottom to Facilitate Stroke Clearance
• Callies Super Magnum Crankshaft with 5.300 Stroke
• GRP Rods (7.700 long)
• Schmidt/JE Pistons
• Special.180" Wall Tool Steel Wrist Pins
• Total Seal Piston Rings
• Special Jesel Rocker with Special Roller Tip 2" Long Exhaust, 1.850" Mini Off-set Intakes.
• Special Jesel +.400" Raised Belt Drive System
• Isky .937 Pressure Fed Lifters
• Manton Pushrods (Intake Single Taper with Bullet Nose 7/16 Straight Exhaust)
• Moroso Oil Pump (4 1/2 Stage)
• Moroso Dry Sump Oil Pan • HRE Sheet Metal Manifold (Schmidt Design)
• Special Carb Shear Plates
• 2 - Quick Fuel Pro Stock Style Dominator Carburetors
• Schmidt/Pro-Filer 12° Cylinder Heads
• Manley Custom Titanium Valves, Retainers, Locks
• Comp Cams Big Core Cam with 4 & 7 Swap
• CSI Water Pump & Starter
• MSD Distributor (Special for 11.600" Deck Height)
• MSD Crank Trigger
• MSD Spark Plug Wires
• Earls Fittings & Hose Ends
• Schmidt Sheet Metal Valve Covers
• Fel-Pro Performance Gaskets
• ATI Super Damper Balancer
• Stef's Oil Tank
• Moroso Vacuum Pump Package (4 Vane)
