قديم 04-06-2008, 08:45 AM
افتراضي خلطة لمحرك سباق سيارت الربع ميل 737 كيوبك أنش
هذي صورة المحرك
http://www6.0zz0.com/2008/06/02/09/571449572.jpg
737 "Dirty Harry" Drag Racing Engine
4.750 Bore X 5.200 Stroke
up to 1360 hp
ENGINE INCLUDES THE FOLLOWING COMPONENTS
• Donovan Aluminum Block
• GRP Rods for NOS
• Bryant Crankshaft
• JE NOS Pistons
• Tool Steel Pins (1.031" Wall)
• Total Seal Piston Rings
• LSM Camshaft
• Jesel Lifters
• Jesel Rocker System
• Quick Fuel Pro Stock Style Split NOS Carbs
• Moroso Enhanced Vacuum Pump
• Jesel Belt Drive & Front Drive Distributor
• MSD Crank Trigger & Spark Plug Wires
• Schmidt 2 Piece Aluminum Dry-Sump Oil Pan
• Off-Set Bronze Lifter Bushings
• 13.5° x 5.5" Bore Schmidt Designed NOS Cylinder Heads
• Manton Push Rods
• HRE Sheet Metal Manifold with Porting & NOS Plugs & Burst Panels Installed
• Two SpeedTech Nitrous Fogger System
• 7° Special Shear Plates
• CSR Water Pump & Starter
• ATI Balancer
Engine Complete with all Nitrous Plummed, both fuel regulators and ready to run. Call for Details
The Most Powerful Nitrous Engine on the Market Today
