هذي صورة المحرك
http://www6.0zz0.com/thumbs/2008/06/01/11/901170634.jpg
http://www3.0zz0.com/2008/06/01/11/248061319.jpg
760 "Commander" Aluminum Donovan - Drag Racing Engine - 1540 HP
1540 HP / 5" Bore Spacing
The Big Dog of Top Sportsman Engines!
Steve Schmidt Racing Engines is now offering our 760 Commander High Performance Drag Racing Engine to our Pro Sportsman engine line. We have developed our own new symmetrical Olds Style Pro Stock head for this monster. We have also developed a manifold and carb combination that is second to none. This 760 drag racing engine combination is unrivaled in quality and performance. This 760 engine combination has ran a quick E.T. of 6.77 @ 206.23 MPH in a 2,400 lb. Top Sportsman Grand Am with a (1.01) 60 foot time.
Call Steve Schmidt for more details on this Ultimate High Performance Drag Racing Engine!
760 "COMMANDER" ENGINE INCLUDES THE FOLLOWING COMPONENTS
• Donovan Pro Stock Block with 5.00. Bore Spacing with 1.000 Raised Cam Core
• 2006 Olds Style Symmetrical Port 5.000" Bore Spacing Cylinder Heads, Special Water Jackets, Custom Spin-Tron Designed Valve Train, 12° x 4 Intake Valve Angle, Aerospace Aluminum with Improved Water Flow, 2006 Porting & Valve Train Technology
• Manton Push Rods
• Jesel Belt Drive
• Schmidt / Stef's Oil Pan
• MSD Distributor & Crank Trigger
• Special Split Steve Schmidt Dominator Carbs Prepared for This Combination Only
• Big Cam Core with 4 & 7 Swap Firing Order and Needle Roller Cam Bearings
• Mezier or CSI Water Pump • JE or BME Pistons with Special Coating on Piston Skirts
• 1.031" HEMI Style .180" Wall Tool Steel Pins
• Total Seal "Special" Ring Package
• GRP Custom Billet Rods
• Sonny Bryant Billet Crankshaft with Modified Counterweights
• Steve Schmidt Designed Valve Train with Jesel Rockers
• Jesel Roller Lifters with Big Wheels
• Moroso 4.5 Stage Pro Stock Dry Sump Pump with Vacuum Pump
• HRE / Schmidt Sheet Metal Intake
• Childs & Albert Coated Bearings
• Fuel Regulator & Lines
• CSI Starter
