قديم 07-06-2008, 10:51 AM
افتراضي خلطة لمحرك سباق سيارت الربع ميل سوبر ستريت وسباقات الطريق 509 كيوبك أنش
هذي صورة المحرك
http://www3.0zz0.com/2008/06/04/12/190730340.jpg
Using only the best components in its Super Series engines, Reher-Morrison has improved its entry-level Big Block Chevy racing engine. Changes from the Super Series 502 include the use of the Dart Big ‘M’ block and a larger 4.500” bore. The increased bore size assists in the breathing capability of the cylinder heads.
The changes in components and the use of the larger bore increases the power output when compared to the Super Series 502. The Super Series 509 puts out 805 HP and 675 ft/lbs of Torque. The horsepower and torque curves are extremely flat to give outstanding performance and work extremely well with throttle stops. Power, reliability and affordability are excellent reasons to put a Super Series 509 in your engine bay and make
Reher-Morrison "Your Engine & Parts Department"
.509 Options
Aluminum Rods
Jesel Belt Drive
Shaft Mount Rocker Arms
Dry Sump Oiling System
Vacuum Pump
Gas Ported Pistons
Nitrous Upgraded Pistons
Nitrous Plate System
Nitrous Fogger System
Dart Pro1 335 CNC Heads
Tunnel Ram, Carbs & Linkage
Billet Oil Pump
Super Series 509 Components Include
• Dart Big 'M' Block • Crower Cutaway Severe-Duty Roller Lifters
• Reher-Morrison/Gary Williams 1050 cfm Dominator Carburetor • Reher-Morrison Custom Roller Camshaft
• Edelbrock S4B Intake Exclusively on This Engine • Scat 4340 Forged Steel 4.00" Crankshaft
• Moroso 1" Aluminum Intake Manifold Spacer • Reher-Morrison Custom 14:1 Forged Pistons
• Reher-Morrison Die Cast Alum. Valve Covers • Reher-Morrison Custom 1/16, 1/16, 3/16 Ring Set
• Reher-Morrison Spec Dart Pro 1 345cc Alum. Heads • Reher-Morrison/Manley 4340 H-Beam Rods +.250" Lg
• Manley Stainless Steel Valves (2.250" Int & 1.880" Exh) • Childs & Albert / Clevite 'H' Series Rod & Main Bearings
• 1.640" OD PAC Double Roller Valve Springs • Manley Double Roller Timing Set w/Torrington Bearing
• Reher-Morrison Custom 10° Titanium Retainers • Reher-Morrison/Moroso Custom Drag Race Oil Pan
• Comp Cams 3/8" Pushrod Guide Plates • Reher-Morrison/Moroso Custom Hi-Vol/Press Oil Pump & Pickup
• Reher-Morrison Custom CNC Valvetrain Stabilizers • Mallory Comp 9000 Billet Ignition System
• Harland Sharp 1.7 ratio Alum Roller Rocker Arms • Reher-Morrison/Moroso Spiral Core Plug Wires
• Fel-Pro Blue Stripe Perma-Torque Head Gaskets • ATI Super Damper - SFI Approved
• Reher-Morrison Custom Chromemoly Pushrods • ARP 12 Point Head Stud Kit
