قديم 08-06-2008, 01:42 PM
افتراضي خلطة لمحرك السباق سوبر ستريت 383 كيوبك أنش
هذي صورة المحرك
http://www2.0zz0.com/2008/06/03/11/919870760.jpg
383 Performance Street Engine with Edelbrock Intake & Quick Fuel Carb
Horsepower 415 / 498 FT. LBS. Torque
Engine Completely Blueprinted & Precision Machined
ENGINE INCLUDES THE FOLLOWING COMPONENTS
• Chevy 4-Bolt Mains w/Special Fastners
• Chevy Vor-tek Cylinder Heads
with Super-Mod Porting
• Comp Cams Hydraulic Roller Cam & Lifters
• Comp Cams Steel Roller Tip Rockers
• Total Seal Piston Rings
• Clevite 77 Bearings
• Billet Timing Gears & Chain Set
with Torrington Thrust Beaing
• Edelbrock Perma-Shine Manifold
• Quick Fuel 750 CFM Carburetor
• HVH Super Sucker Carb Spacer
• MSD HEI Distributor & Wires
• Melling Hi-Volume Oil Pump & Pick-up
• Edelbrock Polished Water Pump • CAT 4340 Crankshaft
• I-Beam Custom Rods w/ARP Bolts
• Stainless Valves, Special Valve Springs, Retainers & Locks
• Comp Cams Pushrods
• Fel-Pro Performance Gaskets
• Federal-Mogul Coated Hypereutectic Pistons
• Billet Block Off Plate
• ARP Fastners
• Edelbrock Air Cleaner
• Edelbrock Valve Covers
• Steve Schmidt Valve Covers
• Stef's Special Oil Pan with Windage Screen
• Polished Front Timing Cover
• Billet Timing Pointer
• SFI Balancer
