هذي صورة المحرك
http://www2.0zz0.com/2008/06/03/11/253680082.jpg
]434 "Pro Sportsman" Drag Racing Engine - 850 HP
4.155 Bore X 4.00 Stroke - 850 HP
Here you go Small Block Chevy Racing Engines fans! Introducing our 434 cu.in. 15° high performance Chevy style head engine hot off the dyno. We start with a Dart Iron Eagle block with raised cam location, for 50 mm cam bearings and tall deck that is professionally machined and blueprinted. We install a Callies or Howards Crankshaft, JE Pistons that are connected to Oliver or Howards Billet Rods with tool steel wrist pins, Total Seal Piston Rings and Clevite 77 bearings. We use Comp Cams Big Core camshaft and roller lifters. We install a set of fully CNC ported and hand finished 15° Brodix aluminum heads with Manley Stainless valves with Comp Cams hardware, pac-alloy springs and top that off with a modified Brodix aluminum manifold and Quick Fuel 1050 CFM Dominator Carburetor with special carb spacer. Remote oil filter and AN fittings and hoses. For the best in High Performance Engines no one does it better than Steve Schmidt Racing Engines.
ENGINE INCLUDES THE FOLLOWING COMPONENTS
• Dart Iron Eagle Block - Tall Deck & Raised Cam
• Callies or Howards Crankshaft
• Clevite 77 Bearings
• Oliver or Howards Billet Rods
with ARP 2000 Bolts
• JE Pistons with Tool Steel Wrist Pins
• Total Seal Piston Rings
• Brodix 15° Aluminum Cylinder Heads
• Manley Stainless Valves
• Comp Cams Camshaft & Roller Lifters
• Comp Cams Pushrods
• Jesel Belt Drive
• Jesel Aluminum Rocker Arms • Fel-Pro Gaskets (Used Exclusively)
• Schmidt Aluminum Oil Pan & Pick-Up
• Special Modified Oil Pump
• Brodix Modified Intake Manifold
• Quick Fuel 1050 CFM Dominator Carburetor
• Special Plastic Super Sucker Carb Spacer
• ATI Super Damper
• Schmidt Fabricated Aluminum
Valve Covers
• MSD Distributor, Crank Trigger & Spark Plug Wires
• ARP Engine Hardware & Fasteners
