أعلن لدينا    كل عام وأنتم بخير    أعلن لدينا
قديم 08-06-2008, 01:49 PM
افتراضي خلطة لمحرك السباق الربع ميل سوبر ستريت 351 كيوبك أنش
هذي صورة المحرك
http://www6.0zz0.com/2008/06/03/11/485441839.jpg
http://www2.0zz0.com/2008/06/03/12/714177863.jpg
Ford 351 Windsor Cobra
398 c.i./ 425 HP
408 c.i./ 520 HP
These engines provide both the power and the sound that screams "COBRA". Using a 351 W block and mild street hydraulic roller cam profile and hydraulic roller lifters with a 10 to 1 compression ratio, it delivers the power you want and the cruising reliability you are looking for in a 93 octane pump gas street engine.
ENGINE INCLUDES THE FOLLOWING COMPONENTS
• 351 W Block + .030" Bore
• Special Forged Pistons (10 to 1 Version)
• Eagle Crankshaft
• Eagle H-Beam Rods with Special bolts
• Performance Balancer
• Fel-Pro High Performance Gaskets
• Dual Roller Timing Chain & Gears
• Comp Cams Pushrods
• Comp Cams "Street" Hydraulic Roller Cam & Lifter Set • Edelbrock 351-W Aluminum Heads with Street Porting
• Melling Oil Pump
• Moroso Oil Pan & Pick-up
• ARP Fasteners
• Edelbrock Single Four Intake Manifold
• Quick Fuel 750 CFM Carburetor
• MSD Electronic Distributor & Spark Plug Wires
• Steve Schmidt Polished Die-Cast Valve Covers with Logo
