هذي صورة المحرك
http://www4.0zz0.com/2008/06/03/11/888704544.jpg
418 Windsor Style Ford Cobra Performance Engine
Horsepower 450 / 500 FT. LBS. Torque
Engine Completely Blueprinted - Block is Bored .030" over, Decked & Block Trued, Line Honed, Torque Plate Honed, Main Cap Girdle Installed, Crankshaft Balanced within 1/2 gram, Custom Assembled.
ENGINE INCLUDES THE FOLLOWING COMPONENTS
• Ford Block
• Eagle 4340 Crankshaft / Internally Balance
• Eagle 4340 H-Beam Rods w/ Special Bolts
• JE Pistons w/ Custom Dish for 10.5 to 1 CR
• Comp Cams Hydraulic Roller Cam Lifters & Pushrods
• Stainless Steel Roller Rocker Arms
• Tru-Roller Timing Chain & Gear Set
• Milodon Oil Pan & Hi-Volume Melling Oil Pump
• SFI Neutral Balance Hi-Performance Balancer • Ford Cobra Valve Covers & Air Cleaner
• Main Cap Stud Girdle & ARP Fastners & Main Studs
• Total Seal Piston Rings
• Clivite H Bearings
• Edelbrock Polished 60cc Victor Jr. Heads
• Edelbrock Manifold w/Special Powder Coating
• Quick Fuel 750 CFM Carburetor
• ARP Head Studs & Fastners
• MSD Billet Distributor & Spark Plug Wires
