اولا:Realtek High Definition Audio Driver R1.95
The ALC882 series 7.1+2 Channel High Definition Audio codecs with UAA (Universal Audio Architecture), featuring five 24-bit stereo DACs and three 20-bit stereo ADCs, are designed for high performance multimedia PC systems.
The ALC882 series incorporates proprietary converter technology to achieve over 100dB Signal-to-Noise ratio playback quality; easily meeting PC2001 requirements and also bringing PC sound quality closer to consumer electronic devices.
The ALC882 series provide 10 channels of DAC that simultaneously support 7.1 sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the Front-Out-Left and Front-Out-Right channels. Flexible mixing, mute, and fine gain control functions provide a complete integrated audio solution for next generation multimedia PCs.
Changes in Driver Package R1.95:
1. Vista WHQL Supporting: ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VD, ALC660, ALC662, ALC663, ALC260, ALC262,ALC267, ALC268, ALC269, ALC272
2. Windows 2000/XP WHQL Supporting: ALC880, ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VC, ALC861VD, ALC660, ALC662, ALC663, ALC260, ALC262, ALC267,ALC268, ALC269, ALC272
3. HDMI Device WHQL Support: ATI HDMI Devices
4. OS Supporting: Microsoft WindowsXP, Widnows2000, Vista x86/x64
5. Pack with Microsoft High Definition Audio UAAV1.0a(5013)
6. Add/Fix
1.) Driver :
1. Customizations.
2. Fix encryption stream issue for ALC889.
3. Fix DRM issue.
لأصحاب كروت الصوت سواء المدمجه او المنفصله من ريل تيك الهاي دفنيشن وبعض العاديه منها
هذا اخر تعريف لمن يواجه تعارضات في كروت الجيجا بايت وولمن تعريفه قديم ولمن يريد التجديد فعليكم بهذا التعريف
للتنزيل
ftp://202.65.194.211/pc/audio/Vista_R195.exe
ثانياً:Intel Chipset Software Installation Utility 9.0.0.1008
The Intel(R) Chipset Software Installation Utility installs Windows INF files to the target system. The INF files inform the operating system how to properly configure the chipset for specific functionality, such as AGP, USB, Core PCI, and ISAPNP services.
This software can be installed in three modes: Interactive, Silent and Unattended Preload. Interactive Mode requires user input during installation; Silent Mode and Unattended Preload do not. This software also offers a set of command line flags, which provide additional installation choices. The command line flags are not case sensitive.
لكل مذربورد شيبست انتيل عليك بتركيب هذا التحديث له ولا خوف عليه لأنه يقوم بتحديث جزئي للبعض الدرايفرات
للتنزيل
http://downloadmirror.intel.com/1602...inst_autol.exe
ثالثاً:Creative Sound Blaster Audigy 1/2/4 2.18.0000 Beta
لبعض كروت الكريتف الخارجيه منها والداخليه
ومعروضه الموديلات في ماذكر ادناه
This download is a beta driver providing Microsoft® Windows Vista® and Windows® XP support for Creative Sound Blaster® Audigy® series audio devices. For more details, read the rest of this web release note.
This download supports the following audio devices only:
* Creative Sound Blaster Audigy including Platinum and Platinum eX series
* Creative Sound Blaster Audigy 2 including Platinum, Platinum eX, and Value series
* Creative Sound Blaster Audigy 2 ZS including Platinum and Platinum Pro series
* Creative Sound Blaster Audigy 4 Pro and Sound Blaster Audigy 4
* Creative Sound Blaster Audigy 2 ZS Notebook PCMCIA
Added Features:
To find out if your audio device supports the following features in Windows XP, click here.
For systems using Windows Vista
* Dolby® Digital and DTS® driver decode re-established for sound cards that included decoding in their Windows XP drivers.
* DVD-Audio playback re-established for sound cards that included the application in their Windows XP software suite (For Windows Vista 32-bit only).
Requires the latest Creative MediaSource DVD-Audio Player Beta software. Click here to download.
Fixes:
* Resolves issues of intermittent and random application/system crash when playing games or running applications that use EAX®, DirectSound®, OpenAL and/or ASIO features.
* Resolves issue of system crash when running DTM - Device Path Exerciser test in Windows Vista 64-bit.
* Resolves issue of volume mapping leading to very soft volume level in systems using Windows Vista with Service Pack 1.
* Resolves issue with distortion and noise occuring in systems with 4 GB of RAM or greater.
* Resolves issue with OpenAL playback of multichannel formats.
* Resolves issue of system crash when performing immediate system shutdown after exiting Battlefield 2.
* Optimizations to OpenAL to improve performance in Unreal Tournament 3, DiRT, and other games.
Notes:
* DO NOT install this driver for Sound Blaster Audigy LS, Sound Blaster Audigy SE, or Sound Blaster Audigy Value.
* To install this driver
1. Download the file onto your local hard disk.
2. Double-click the downloaded file.
3. Follow the instructions on the screen.
للتنزيل
http://ccftp.creative.com/manualdn/D...S_2_18_000.exe
رابعاً:NVIDIA Gelato for Windows 2.2 Release 1
NVIDIA Gelato rendering software brings high-quality rendering to the masses. A hardware-accelerated, non-real-time renderer, it allows you to use your NVIDIA GPU to create stunning images fast. Originally designed for the creation of 3D visual effects and animation in feature films, it can be used by anyone with NVIDIA hardware to create images of the very highest quality.
للتنزيل
http://film.download.nvidia.com/NVID...inNT-2.2R1.exe
خامساً:ATI Catalyst 8.5 WHQL Display Driver
لأصحاب كروت ati الرديون
AMD’s award-winning ATI Catalyst graphics and HD video configuration software delivers unprecedented control of performance and visual quality with ATI Radeon™ graphics processors. Certified by Microsoft® Windows® Hardware Quality Labs (WHQL), ATI Catalyst drivers for Windows Vista® and Windows® XP operating systems deliver stable performance and push the limits of innovation with advanced user-oriented features.
Precision controls for power users. Tweaks for gamers and video enthusiasts. Simple wizard-assisted setup, easy multi-monitor configuration, and ultra reliable operation for working professionals. New user or seasoned expert, ATI Catalyst puts you in charge of The Ultimate Visual Experience™.
للتنزيل
Drivers & Software
الختام
