رئيس هوندا : NSX ستكون الأسرع في نوربورينغ
الهدف القضاء على جي تي ار ولكزس LF-A خ خصوصا في حلبة نوربورينغ
NÜRBURG, Germany — The latest prototype of the 2011 Acura NSX has hit the Nürburgring, and according to our sources in Japan, it has a very specific goal. We're told that Takeo Fukui, CEO of Honda, has tasked his R&D team with building an NSX that's faster around the Nürburgring than both the Nissan GT-R and the upcoming Lexus LF-A.
It's a tall order, and one that Honda hopes it can achieve through the use of a 5.5-liter V10 expected to make 550 horses, with a torque peak expected to top 420 pound-feet. The engine is essentially a slightly larger version of the V8 that Honda will use for the next-generation, rear-wheel-drive RL sedan, and it will use cylinder deactivation under light loads for maximum efficiency. Additional gains will come from the use of an eight-speed, paddle-shifted automatic.
Getting the power to the ground will be a modified version of Honda's Super-Handling All-Wheel-Drive (SH-AWD) system. Packaging could be tight, however, as this NSX will place its V10 up front. A combination of steel and aluminum will be used for the chassis that will form the basis of this 2+2 sports car.
أمحو ذنوبك في خلال دقيقتين
أخي الحبيب في الأخير أتمنى أن تدعوا لي ولوالدي بكل ما هو خير
وان تدعوا لي بالتوفيق في دنيتي وآخرتي و في دراستي
ولـ صاحب الفكرة جزاه الله ألف خير
ووفق الله ناشرها وقارئها وأدخلهم فسيح جناته
http://www.shbab1.com/2minutes.htm
