صفحة 2 من 2 الأولىالأولى 12
النتائج 7 إلى 11 من 11
  1. #7
    Prelude 4 Life غير متصل مشرف سابق
    30
    2,771
    260 hp twelve-cylinder engine and accelerates from 0-62.1 mph in 9.5 seconds. Top speed is limited electronically to 143 mph.
  2. #8
    HaMaD12 غير متصل عضو فعّال
    671
    "بخصوص القوة أكيد قصدك 620 مب 260 حصان "
    السياره بس 260 حصان
    بخصوص " الهديروجين البنزين العادي "
    يعني السياره فيها خزان بترول و خزان حق الهيدروجين و تقدر تبدل من الهيدروجين للبترول في اي وقت
    The Hydrogen 7 is powered by a 260 horsepower, 12-cylinder engine and accelerates from 0-60 mph in 9.5 seconds. The top speed is limited electronically to 140 mph.
    BMW has said it intends to build a few hundred such cars at first. They will be able to switch between burning standard gasoline and hydrogen so that drivers will not be left stranded while the infrastructure to deliver hydrogen is built up.
    That means both hydrogen and gasoline tanks — the former allowing a 125-mile driving range and the latter 300 miles. Drivers can switch back and forth with a button on the steering wheel.
    "Because engine power and torque remain exactly the same regardless of the mode of operation," BMW said, "switching from one mode to another has no effect on the driving behavior and performance of the BMW Hydrogen 7."
    Most carmakers experimenting with hydrogen are doing so with fuel cells that would use the energy carrier to create an electric power system. But BMW's path is to use liquid hydrogen in existing internal combustion engines since the infrastructure for fuel cells and refueling hydrogen is so limited.
    The space that two fuel tanks take up means only the 7-Series will offer the hydrogen package at first. BMW’s long-term goal is to offer hydrogen motors in all its cars.
  3. #9
    الصورة الرمزية Jaguar R
    Jaguar R غير متصل مشرف سابق
    U-A-E
    6,304
    بالنسبة للهيدروجين... فاضن انه بيحل مكان البنزين مستقبلا....
    في الامارات و بالاخص الشارجة .. بداؤ باستعمال الغاز في سيارات الاجرة كتجربة اولية... يعني اذا نفع بيتطبق واذا مانفع يبقى البنزين قيد الاستعمال, حال مايظهر وقود جديد كالهيدروجين..
    لاكن بالنسبة كوتر بــ 12 سلندر ينزل بقوة 260 حصان؟؟ فهذا شي مب حلو.. عيل الــ 8 او الــ 6 سلندر..كم بتكون قوتهم؟؟؟ 100 او 120 حصان (للهيدروجين)؟؟
  4. #10
    الصورة الرمزية مؤيد اف1
    مؤيد اف1 غير متصل عضو فعّال
    798
    اقتباس المشاركة الأصلية كتبت بواسطة Jaguar R
    طريقة الاحتراق كلها تختلف...يبي لك محرك مافيه كمبرشن الا قليييييييييييييييييل جداًَ....الهيدروجين مافيه اوكتين المفروض
    وغاز خفيف جداً وسريع جداً جداً في الاشتعال...يعني تصميم المكينه يختلف..لو كان كمبيريشن المكينه مثل البنزين راح تروح المكينه من ال Detonation
  5. #11
    الصورة الرمزية ابوعدي
    ابوعدي غير متصل عضو نشيط جداً
    في قلبي
    285
    انشاء الله ماتنزل السوق وتاخر عشان ماناكلها بعدين ( مين بيشتري البترول)
  1. إنفينيتي IPL G المكشوفة الإختبارية........(جديد باريس)
    آخر مشاركة: 30-03-2011, 10:20 PM
  2. بي أم دبليو X5 بتعديل Mansory......(جديد باريس)
    مشاركات: 11
    آخر مشاركة: 24-09-2010, 12:47 AM
  3. بي أم دبليو تقدم الفئة السادسة الإختبارية...(جديد باريس)
    مشاركات: 24
    آخر مشاركة: 21-09-2010, 11:06 AM
  4. أنباء عن موديل جديد من لامبورغيني في باريس
    آخر مشاركة: 18-09-2010, 11:04 AM
  5. شيفرولية أفيو الجديدة كليا........(جديد باريس)
    آخر مشاركة: 13-09-2010, 10:37 AM
