    نيسان حياتي غير متصل عضو نشيط جداً
    320
    افتراضي SUBARU IMPREZA vs MITSUBISHI LAN. EVO.
    [SUBARO (IMPERZA 2009)
    LEFT]
    Type
    2.5-liter DOHC intercooled, turbocharged aluminum-alloy 16-valve 4-cylinder horizontally opposed SUBARU BOXER® engine .
    Horsepower
    305 hp @ 6,000 rpm
    Torque (lb.-ft.)
    290 lb-ft @ 4,000 rpm
    Fuel and Ignition system
    Sequential multiport fuel injection. Electronic Throttle Control (ETC). Engine management with integrated self-diagnostics adaptive driving habits capability. Direct ignition.
    Fuel Tank Capacity
    16.9 gallons
    Fuel Economy (city/highway)
    Manual: 17/23 mpg
    Fuel Requirement
    Premium unleaded gasoline (91 octane) required. 93 octane recommended.
    Steering
    Engine-speed-sensing variable power-assisted rack-and-pinion.
    Turning Circle, curb-to-curb
    36.1 ft.
    SI-DRIVE performance management system
    Subaru Intelligent Drive (SI-DRIVE ) enables three distinctively different modes of vehicle performance characteristics by regulating the engine control unit (ECU) and by fine-tuning the electronically controlled throttle.
    Suspension
    High-performance sport-tuned 4-wheel independent suspension. Front: Inverted-strut-type with aluminum-alloy lower L-arm. Rear: Double wishbone. Front and rear stabilizer bars.
    Brakes
    Brembo® performance brake system. 4-wheel disc, ventilated front and rear. 4-piston front and dual-piston rear calipers. 4-channel, 4-sensor Super Sport ABS with Electronic Brake-force Distribution (EBD). Brake discs Front: 12.8 in./Rear: 12.4 in.
    Wheels
    18 x 8.5-inch 5-spoke aluminum-alloy. High-luster silver finish.
    Optional 18 x 8.5-inch 18-spoke BBS® aluminum-alloy. Silver or Gold color.
    Tires
    245/40 R18 93W ultra high-performance
    Manual Transmission (Standard)
    Fully synchronized close-ratio 6-speed manual with Incline Start Assist
    Symmetrical All-Wheel Drive (AWD)
    Driver Controlled Center Differential (DCCD) All-Wheel Drive: Driver Controlled Center Differential (DCCD) All-Wheel Drive uses an electronically managed multi-plate transfer clutch and a mechanical limited-slip differential in conjunction with a planetary-gear-type center differential to control power distribution between the front and rear wheels. Featuring manual and three automatic modes, DCCD splits power 41% front and 59% rear. Sensors monitor parameters such as wheel slippage, steering angle, throttle position and braking to help determine torque distribution and direct it to the wheels with optimum traction. DCCD also features a limited-slip helical front and Torsen® rear differential.
    MITSBISHI (LAN. EVOLUTION 2009)
    Engine
    GSR MR
    Engine Type: 2.0L MIVEC I4 turbocharged/intercooled 2.0L MIVEC I4 turbocharged/intercooled
    Engine Code: 4B11 T/C 4B11 T/C
    Valve Train: DOHC, 16-valve, Mitsubishi Innovative Valve-timing Electronic Control system (MIVEC) DOHC, 16-valve, Mitsubishi Innovative Valve-timing Electronic Control system (MIVEC)
    Displacement (cu in./cc): 122 / 1998 122 / 1998
    Bore x Stroke (in./mm): 3.4 x 3.4 / 86.0 x 86.0 3.4 x 3.4 / 86.0 x 86.0
    Compression Ratio: 9.0:1 9.0:1
    Horsepower @ RPM (BHP) (Fed./Cal.): [email protected] [email protected]
    Torque @ RPM (lb-ft.) (Fed./Cal.): [email protected] [email protected]
    Engine Block: Aluminum Aluminum
    Cylinder Heads: Aluminum Aluminum
    Redline RPM: 7,000 7,000
    Fuel System: MPI MPI
    Emissions: Fed: Tier 2 bin 5 Fed: Tier 2 bin 5
    Recommended Fuel: Premium Unleaded, 91 AKI min. Premium Unleaded, 91 AKI min.
    Radiator Core size (mm): 700 x 408 x 27 700 x 408 x 27
    Engine Oil Type: 5W-30 5W-30
    Engine Oil Capacity (qt./l): 5.0 / 4.8 (filter + 0.3 qt; cooler + 0.5 qt.) 5.0 / 4.8 (filter + 0.3 qt; cooler + 0.5 qt.)
    Battery: 65D26L 65D26L
    Alternator (Amps): 130A 130A
    Transmission
    GSR MR
    Type: 5-speed manual 6-speed TC-SST
    1st: 2.857 3.655
    2nd: 1.950 2.368
    3rd: 1.444 1.754
    4th: 1.096 1.322
    5th: 0.761 1.008
    6th: -- 0.775
    Reverse: 2.892 4.011
    Final Drive: 4.687 4.062
    Body/Suspension/Chassis
    [/LEFT
    وسامحونا على القصور]
    ايفو و بس
    ههههههههههههههههههههههه
    الصورة الرمزية K H A L E D
    K H A L E D غير متصل مشرف عام
    KSA-buraydah
    6,508
    الافيو وووووووووووووحش
    UAEmonster غير متصل عضو فائق النشاط
    4,181
    الايفو اقوى واحلى واحسن !!
    ايفو وبس والباقي خس
    الصورة الرمزية Saloo7
    Saloo7 غير متصل عضو فعّال جداً
    21
    1,469
    Talking
    عاش الإيفو عاش
    مب شي السوبارو الموديل السابق أفضل عن اليديد ..
