النتائج 1 إلى 6 من 11
    Wink أستون مارتن V12 Vantage........(جديد جنيف)
    12 اسطوانة بقوة 510 حصان وانطلاق في 4.1 ثواني
    Aston Martin V12 Vantage: Specifications
    Body:
    Two door, two seat coupe body
    Bonded aluminium structure
    Aluminium, magnesium alloy, composite and steel body
    Extruded aluminium door side impact beams
    High Intensity Discharge Headlamps (dipped beam)
    Halogen projector headlamps (main beam)
    LED rear lamps
    Engine:
    All alloy quad overhead cam 48 valve 5935cc V12
    Compression ratio 10.9:1
    Front mid-mounted engine, rear wheel drive
    Fully catalysed stainless steel exhaust system with active bypass valves
    Maximum Power:
    510 bhp (380 kW / 517 PS) at 6500 rpm
    Maximum Torque:
    570 Nm (420 lb.ft) at 5750 rpm
    Acceleration:
    0-62 mph (100 km/h) in 4.2 seconds
    0-60 mph in 4.1 seconds
    Maximum Speed:
    190 mph (305 km/h)
    Fuel Economy:
    Urban 11.64 mpg 24.26 l/100km
    Extra Urban 24.05 mpg 11.74 l/100km
    Combined 17.28 mpg 16.35 l/100km
    CO2 388 g/km
    Transmission:
    Rear mid-mounted six speed manual gearbox. Alloy torque tube with carbon fibre propeller shaft
    Limited slip differential
    Final Drive Ratio 3.71:1
    Steering:
    Rack and pinion
    Column tilt and reach adjustment
    Suspension:
    Front: Independent double wishbone incorporating anti-dive geometry, coil springs, anti-roll bar and monotube dampers
    Rear: Independent double wishbones with anti-squat and anti-lift geometry, dual-rate coil springs, anti-roll bar and monotube dampers
    Wheels:
    Front: 9″ x 19″
    Rear: 11″ x 19″
    Tyres:
    Front: Pirelli P Zero Corsa 255/35 ZR19
    Rear: Pirelli P Zero Corsa 295/30 ZR19
    Brakes:
    Front: Ventilated Carbon Ceramic discs 398 mm diameter with six piston callipers
    Rear: Ventilated Carbon Ceramic discs 360 mm diameter with four piston callipers
    Dynamic Stability Control (DSC) with Track mode
    Anti-lock braking system (ABS)
    Electronic Brakeforce Distribution (EBD)
    Emergency Brake Assist (EBA)
    Traction Control
    Length: 4380 mm (172.5″)
    Width: 1865 mm (73.5″) (excluding door mirrors)
    2025 mm (80″) (including door mirrors)
    Height: 1241 mm (49″)
    Wheelbase: 2600 mm (107.9″)
    Fuel tank capacity: 80 litres (17.6 Imp. Gal. / 21.1 US Gal)
    Weight: 1680 kgs (3704 lb)
    Interior:
    Carbon fibre door pulls
    Memory seats and exterior mirrors (3 positions)
    Sports seats with 10 way electric adjustment, including height, tilt and lumbar
    adjustment
    Dual stage driver and passenger front airbags
    Side airbags (Sports seats only)
    Heated rear screen
    Automatic temperature control
    Organic Electroluminescent (OEL) displays
    Trip computer
    Cruise control
    Hard Disk Drive (HDD) satellite navigation system*
    Bluetooth telephone preparation*
    Powerfold exterior mirrors
    Rear parking sensors
    Auto dimming interior rear view mirror
    Tyre pressure monitoring*
    Alarm and immobiliser
    Remote-control central door locking and boot release
    Battery disconnect switch
    Tracking device (UK only)
    In Car Entertainment:
    160W Aston Martin Audio System
    MP3 player connectivity
    Options:
    Lightweight seats with 6 way adjustment, including front and rear height adjust. (Does not include side airbags or Passenger Airbag Cut-Off Switch)
    700W Aston Martin Premium Audio System with Dolby® Pro Logic II®
    Piano Black facia trim
    Graphite Alloy facia trim
    Personalised sill plaques
    Garage door opener (Europe only)
    Tracking device**
    First aid kit
    Ashtray and cigar lighter
    Boot mounted umbrella
    Front parking sensors
    Heated seats (Sports seats only)
    ISOFIX and fixed-height passenger seat (Sports seat only)
    الصورة الرمزية 760
    760
    760 غير متصل عضو فعّال
    929
    المفروض اقل شي تجيب الميه قي 3.5 لان البورش كاريرا 6 سلندر تجيب اسرع من هالوقت
    نيسان حياتي غير متصل عضو نشيط جداً
    320
    المكينه غلط جبارة
    بس اتوقع في عندهم شي غلط بنسبه حق التوقيت
    نفس ما قال اخوي 760 على البورش
    وانا بعد اقولك على GTR بعد اقل من هلون
    وايد صار في منافسه على اسرع وقت
    اصلا الي يشترون استن مارتن ما ياخذونها عشان سرعتها
    ياخذونها لانها استن مارتن
    الصورة الرمزية PORSCHE
    PORSCHE غير متصل عضو فعّال جداً
    1,696
    الاستون مارتن
    دايما محركاتهم كبيره وادائها احس انه ضايع بالفاضي مدري ليش
    Aug 2007
    3,790
    سيارات الانجليزيه كلها جذي حتى الجاكوار
  1. بيجو EX1 الإختبارية.........(جديد جنيف)
    آخر مشاركة: 22-09-2010, 01:52 AM
