النتائج 1 إلى 6 من 14
    Cool لامبورغيني تقدم مورشيلاغو LP670-4 SuperVeloce ...(جديد جنيف)
    12 اسطوانة 670 حصان وانطلاق في 3.2 ثواني وسرعة قصوى تبلغ 342 كم/سا و 350 نسخة فقط
    Technical data - Lamborghini Murciélago LP670-4 SuperVeloce
    Frame: High strength tubular steel structure with carbon fiber components
    Bodywork: In carbon fiber, except roof and door external panels (steel)
    • Steering
    • Type: Mechanical (rack and pinion) power-assisted
    • Right-hand turning circle: 12.55 m (41.17 ft)
    • Wheels and tires
    • Front: 245/35 ZR 18"
    • Rear: 335/30 ZR 18"
    • Engine
    • Type: 12 cylinders at 60°
    • Bore and stroke: 88mm x 89 mm (3.46 in x 3.50 in)
    • Displacement: 6496 cc. (396.41 in³)
    • Compression ratio: (11 ± 0.2):1
    • Maximum power: 670 hp (493 kW) at 8000 rpm
    • Maximum torque: 660 Nm (487 lb-ft)at 6500 rpm
    • Engine position in vehicle: Longitudinal central-rear
    • Cylinder heads and engine block: Aluminum
    • Intake system: Variable geometry with 3 operating modes
    • Timing
    • 4 valves per cylinder, 4 overhead camshafts
    • Timing gear transmission: 2 chains
    • Continuous timing variator (int. and ex.): Electronically controlled
    • Ignition system
    • Static type ignition system with individual coils (one for each spark plug).
    • Firing sequence: 1-7-4-10-2-8-6-12-3-9-5-11
    • Fuel system/injection
    • Lamborghini LIE electronic engine control unit, multipoint, sequential timed, DRIVE BY WIRE
    • Lubrication system
    • Type: Dry sump
    • Recovery pumps: 2 gear pumps
    • Delivery pump (high pressure): 1 gear pump
    • Cooling system
    • Type: Liquid cooled, with pressurized circuit
    • Transmission
    • Type of transmission: Permanent all-wheel drive with Viscous Traction system
    • Gearbox: 6-speed e-gear
    • Clutch: Dry single disc
    • Clutch disc diameter: 272 mm (10.7 in)
    • Transmission ratios
    • Traction Control System: T.C.S.
    • Gearbox - E-Gear & Manual
    • 1st: 1:3.091
    • 2nd: 1:2.105
    • 3rd: 1:1.565
    • 4th: 1:1.241
    • 5th: 1:1.065
    • 6th: 1:0.939
    • Reverse: 1:2.692
    • Brakes
    • 4 self-ventilated rotors with pedal control, hydraulic transmission with dual independent circuits, one for each axle with vacuum servo.
    • ABS antilock device + DRP function
    • Carbo ceramic brakes (CCB)
    • Handbrake: Mechanical, acting on rear wheels
    • Front rotor: Ø 380 x 38 mm (Ø 14.96 in x 1.5 in)
    • Front caliper cylinders: n.6 (32-36-38 mm) (1.26 in -1.42 in-1.5 in)
    • Rear rotor: Ø 380 x 38 mm (Ø 14.96 in x 1.5 in)
    • Rear caliper cylinders: n.6 (32-36-38 mm) (1.26 in -1.42 in-1.5 in)
    • Suspension
    • 4-wheel independent articulated quadrilateral system. Hydraulic shock absorbers and coaxial coil springs. Suspension with dual front and rear struts, anti-roll, anti-dive and anti-squat bar.
    • Dimensions
    • Wheelbase: 2665 mm (104.92 in)
    • Total length: 4705 mm (185.23 in)
    • Total width: 2058 mm (81.02 in)
    • Total height: 1135 mm (44.69 in)
    • Dry weight: 1565 Kg (3450.2 lb)
    • Front track width: 1635 mm (64.37 in)
    • Rear track width: 1695 mm (66.73 in)
    • Front overhang: 1090 mm (42.91 in)
    • Rear overhang: 950 mm (37.40 in)
    • Maximum overall width with external rear-view mirrors: 2240mm (88.19 in)
    • Weight distribution front/rear: 42% - 58%
    • Liquid capacities
    • Fuel tank: 100 Liters (26.4 gal)
    • Engine oil: 12 Liters (3.17 gal)
    • Gearbox oil: 3,5 Liters (0.92 gal)
    • Front differential oil: 1 Liter (0.26 gal)
    • Rear differential oil: 2,5 Liters (0.66 gal)
    • Cooling circuit: 15 Liters (3.96 gal)
    • Performance
    • Top speed with small spoiler: 342 km/h (212.5 mph)
    • Top speed with big wing: 337 km/h (209,4 mph)
    • Acceleration 0-100km/h: 3.2 s
    • Fuel Consumption (according with DIR 1999/100/CE)
    • City: 32 L/100km
    • Highway: 13.7 L/100
    • Combined: 20.6 L/100
    • CO2 Emission: 480 g/km
    • Fuel Consumption USA (according with US EPA guidelines)
    • Manual
    • City cycle: 8 mpg
    • Highway cycle: 13 mpg
    • Combined: 10 mpg
    • E-Gear
    • City cycle: 9 mpg
    • Highway cycle: 14 mpg
    • Combined: 11 mpg
    معشوقة الشباب وصلت الحين.
    ماشاء الله حلوة
    ZSpeed غير متصل عضو نشيط جداً
    Qatar
    271
    السلام عليكم ورحمة الله
    يالله يالله يالله على السيارة من زمان وانا منتظرها - مرشيلاغو SV -
    هالحين عرفت ايش يعني SV اللي تمثل Super Velocity يعني سرعة خارقة
    و670 حصان
    واجمل من هذا كله انه لامبورجيني دخلت فكرة التصميم المثلثي نفس اللي في السيدان الكونسبت ( استيكيه )
    مثل الكراسي و غطاء المحرك اللي ورا
    اخ نفسي اشوف هالسيارة قدامي و اسمع صوتها لما يكون عليها Tubi Exhaust ( اللي يخليك تسمع صوت السيارة وهيا واقفة من مسافة بعيدة)
    يعطيك الف الف الف عافية مشرفنا والله لا يحرمنا من جديدك
    الصورة الرمزية the stig
    the stig غير متصل عضو فعّال
    Jan 2009
    19
    677
    الله روووووووووعة سيارة روعة بمعنى الكلمة جميلة سريعة و خطيرة
    مشكور اخي ننتظر جديدك
    الصورة الرمزية @bdull@
    @bdull@ غير متصل عضو فعّال
    938
    شكلها صاااارووووخ
    ابدعت فيها لمبرجيني
    حلوه بس الخلفيه ماعجبتني والجناح
    العاديه احلى
    بس تبقى مورسيلاجو حلم كل شخص عاشق للسيارات
  1. أنباء عن موديل جديد من لامبورغيني في باريس
    آخر مشاركة: 18-09-2010, 11:04 AM
