النتائج 1 إلى 6 من 11
    افتراضي صور متوقعة ل 2010 BMW 5-Series
    شكلها جميل ..
    The new 5-Series Sedan is set to arrive in late 2009 for the 2010 model year and heavily disguised prototypes have already been seen testing around the streets of Munich. While those prototypes revealed few details, these latest computer generated rendering gives us a clear indication as to what to expect for the new executive wagon.
    Most of the planned changes are skin-deep. Under the new sheet metal, BMW will continue with its new found love of turbocharging. The new 4.4L twin-turbo V8 from the recently revealed X6 is expected to appear in a range topping model, while more turbo-diesel variants are expected to join the lineup as well. BMW is currently developing its second generation common rail system for its diesel powerplants, which will operate at greater pressure for improved performance. The transmission systems will include a six-speed manual and a six-speed Steptronic semi-auto gearbox, however a new eight-speed unit from ZF is also expected to be available.
    Performance will also be improved thanks to the extensive use of lightweight materials including carbon-fiber and aluminum. The car’s construction will be a hybrid of an aluminum spaceframe for the front section, and a traditional steel monocoque for the passenger compartment and rear. This will ensure a favorable front-to-rear weight distribution and improved handling. Up front will be an independent suspension with MacPherson struts, with a multi-link layout for the rear. High-performance models will include carbon-fiber body panels to shed even more weight.
    الصراحة قام مخي يخربط ويقولي هذا فوتوشوب للفئة السابعة ...بس اشوف ان الانوار الحالية اجمل واتمنى تظل على حالها بشوية تعديل
    May 2007
    5,600
    السلام عليكم
    والله احسها الفئه السابعه مصغره ...
    البي ام دائماً تتميز في تصميم الانوار ، مالنا غير ننتظر نزولها
    الصورة الرمزية 911turboS
    911turboS غير متصل عضو فعّال
    650
    الفئة السابعه بشكل مصغر ...
    UAEmonster غير متصل عضو فائق النشاط
    4,181
    الصراحه
    جمييييله ... مع انها مبينه فوتوشوب
    لكن صور البمبر المسربه للسياره ماكانت بعيده من فتحات وخطوط هالتصميم
    لو هذا صدق شكلها ..
    الصراحه المرسدس E-Class نقدر نقولها باي باي
    يعني الحين الاودي A6 والبي ام احلى ثنين
  1. مشاركات: 12
    آخر مشاركة: 04-10-2010, 09:40 PM
  2. صور وفديو تطعيس واستعراض بطل الدروب نيسان باترول 2010 .
    بواسطة bbb في المنتدى قسم السيارات العام
    مشاركات: 16
    آخر مشاركة: 19-09-2010, 08:59 AM
  3. هولدن تقدم كومودور (شيفرولية لومينا) 2011
    آخر مشاركة: 14-09-2010, 09:35 AM
