    الصورة الرمزية alboss777
    alboss777 غير متصل عضو نشيط جداً
    Oct 2008
    300
    افتراضي للبيع دراجه بولارس ريزر 2009
    السلام عليكم و رحمة الله و بركاته
    للبيــــــــع
    دراجه
    Polaris RZR 2009
    السعر 75 ألف درهم
    الدراجه موجوده بابوظبي
    الدراجه جديده لم تستعمل
    لطلب الدراجه يرجى الاتصال على الارقام ادناه
    00971504444879
    00971553255551
    00971504414457
    البريد الالكتروني [email protected]
    Polaris RZR 2009
    السعر 75 ألف درهم
    المواصفات
    • Displacement: 760 cc
    • Cooling Type: Liquid
    • Engine Type: Twin Cylinder
    • Top Speed: 55 mph (88.5 km/h)
    • Lubrication: Wet Sump
    • Oil Capacity: 2 qt. (1.9 l)
    • Carburetion: Electronic Fuel Injection
    • Fuel Capacity: 7.25 gal. (27.4 l)
    • Coolant Capacity: 4.8 qt. (4.5 l)
    • Alternator: 500 Watts
    50" Razor Sharp Performance for Trail, Hunt, and Sport. It's the only Side x Side that's trail-capable. Its has true AWD traction and incredible agility.
    • 800 Twin EFI Engine: Industry-leading big bore 800 Twin EFI engine has the fastest acceleration of any Side x Side
    • On-Demand True AWD: Senses when the rear wheels slip to engage both front wheels with full torque, maximizing traction with true 4-wheel drive
    • Lowest Center of gravity: With the engine positioned behind the seat, the center-of-gravity is lowest in class for razor sharp handling and performance
    • Speed & Fastes Acceleration: Blazing 55 mph (88.5 km/h) top speed makes all other Side x Sides in its class eat dust
    • Independent Rear Suspension: Rolled independent rear suspension with an anti-sway bar and 9.5 in. (24.1 cm) or travel for a smooth ride
    • Ground Clearance: 10 in. (25.4 cm) of ground clearance keeps you off boulders and other trail obstacles
    • Adjustable seats & More: Adjustable seats, tilt steering and an adjustable passenger grab bar and a new heel pocket to lock in comfort
    • Lock & Ride cargo System: Exclusive cargo system lets you add or change accessories in less than a minute with no tools
    • 50-inch Width: A 50-inch Width makes it the only trail-capable SXS on the market
    • All the Utility You Need: With 300 lbs. box capacity, underseat storage, and Exclusive Lock & Ride® Accessories, RANGER RZR works hard
    المواصفات الاضافيه
    . مقبض للكير من الالمنيوم
    . حزانه جانبيه للاغراض
    . مسجل مع راديو و دي في دي مع سي دي و ام بي 3
    . 4 سماعات كبيره وتر بروف بالسقف
    . حافظة خزان احتياطي للبترول مع الخزان
    . حامل للاطار الاحتياطي مع حدائد امان اضافيه
    . اطار احتياط مع رنك المنيوم
    . ونش كهربائي مع سحب عالى
    . دعاميه كروم مع حمايه لاسفل الدراجه من الامام
    . دعاميه كروم خلفيه
    . حاجب هواء امامي كامل من البلاستيك المقوى المضاد للكسر
    . 3 كاشافت باعلى الدراجه
    . 2 كشافان على المدعميه من امام الدراجه
    الصورة الرمزية K H A L E D
    K H A L E D غير متصل مشرف عام
    KSA-buraydah
    6,508
    ماشاء الله
    صناعة الدراجه اخوي؟
    اله يرزقكم بالبيعه
    بالتوفيق لك اخي الكريم بالبيعه ان شاء الله
    حياك الله
  1. للبيع سيارة سوزوكي سويفت 2009
    بواسطة حسن غريب في المنتدى قسم البيع والشراء
    آخر مشاركة: 16-09-2010, 02:26 PM
  2. دراجه راينو للبيع
    بواسطة راهي الامارات في المنتدى قسم البيع والشراء
    آخر مشاركة: 04-09-2010, 08:09 PM
  3. للبيع BMW X5 4.8i 2009
    بواسطة albloushi في المنتدى قسم البيع والشراء
    آخر مشاركة: 01-09-2010, 10:26 PM
