النتائج 1 إلى 6 من 14
الموضوع: Lingenfelter 2010 camaro
    zr1_ls9 غير متصل عضو نشيط
    105
    افتراضي Lingenfelter 2010 camaro
    يا ساتر
    Lingenfelter 2010 Camaro Engine Packages:
    550 BHP / 550 lbs-ft of torque
    When Lingenfelter installs the Magnuson supercharger system we upgrade many components from the base Magnuson kit for better performance and reliability. Each car also gets Lingenfelter PCM programming that lets you benefit from the experience LPE has gained from installing hundreds supercharger systems since 2001 when we first started offering the Magnuson superchargers as a package.
    Package includes:
    - TVS2300 intercooled supercharger system- silver painted finish
    - Based on OEM Eaton supercharger unit
    - Properly sized fuel injectors
    - Fuel system upgrades
    - 160 Degree thermostat
    - Boost bypass controller
    - Lingenfelter High Flow Air Intake
    - Professional installation, testing and calibration
    - Corsa stainless steel cat back exhaust
    - Chassis dyno report before & after installation
    - Excellent drivability, highway mileage not adversely affected
    - Lingenfelter 3 year/ 36,000 mile warranty
    - Lingenfelter fender badges
    - Lingenfelter certificate of authenticity
    570 BHP / 570 lbs-ft of torque
    Package includes:
    650 BHP / 600 lbs-ft of torque
    - Engine removal, disassembly and inspection
    - Lingenfelter CNC porting of LS3 cylinder heads
    - Lingenfelter multi-angle valve job, cc, surfacing & assembly
    - Stainless steel intake valves and heavy duty Inconnel exhaust valves
    - Competition Cams dual valve springs, titanium spring retainers, 10 degree locks
    - JE Forged aluminum pistons and tool steel pins
    - Manley 4340 forged steel "I" beam connecting rods
    - Computer balanced LS7 forged steel crankshaft & rotating assembly
    - File fit rings, heavy duty rod & main bearings, head gaskets, head bolts
    - Fuel system upgrades and properly sized fuel injectors
    - Ported & polished LS3 throttle body
    - Boost by pass system
    - Professional engine installation, testing & tuning
    750 BHP / 685 lbs-ft of torque
    - Chevrolet LS7 7.0 L aluminum block
    - Chevrolet LS7 aluminum heads
    - Chevrolet LS7 titanium connecting rods
    - Chevrolet LS7 forged steel crankshaft - 4.000" stroke
    - Heavy duty inconnel exhaust valves
    - Professional assembly and blueprinting of engine
    800 BHP 800 lbs-ft of torque
    - Callies 4340 forged steel crankshaft - 4.000" stroke
    - Lingenfelter CNC porting of LS7 cylinder heads
    - Computer balanced crankshaft & rotating assembly
    - Properly sized fuel injectors and high capacity fuel system
    - Twin Garrett oil lubricated & liquid cooled true ball bearing turbochargers
    - Lingenfelter turbo compressor housings & exhaust housings with integral waste gates
    - Lingenfelter super high efficiency air to air charge coolers
    - Lingenfelter 304 Stainless steel 4 into 1 custom exhaust manifolds & turbo outlets
    - Lingenfelter belt driven turbocharger scavenge pump & turbo oil drain reservoir
    - Lingenfelter custom molded silicone air ducts
    - Two S&B 360 degree conical air filters
    - Stainless steel / ceramic heat shields & stainless clamps
    - Port matched LS7 intake manifold
    Lingenfelter 2010 Camaro Body Kit
    Lingenfelter will be offering body enhancements for the new 2010 Camaro later this summer.
    Enhancement package will include:
    Front Fascia & Rocker Extension
    Front Splitter
    Grille Bar Insert with Wire Mesh Texture
    Hood with Air Extractors
    Rear Deck Lip Spoiler
    Rear Fascia Extension with Exhaust Tips
    Rear Tail Lamp Panel
    ماسوت شي جديد طبقت تعديلاتها اللي على الــ ZO6 على الكومارو بالتعديلات اللي فوق ال600 حصان وحتى 800 حصان محرك الـ7 لتر والتيربوات عليه والباكج كامل
    بس شكله طالع حلو والسعر بيكون فوق
    باختصار السيارة طالعة وايد حلوة
    بس اليناح يمكن شوي مخرب
    الصورة الرمزية hazard
    hazard غير متصل عضو فعّال
    Feb 2008
    943
    تعديل خطييييير .. و النظره شرسه ..
    الصورة الرمزية GMC LoveR
    GMC LoveR غير متصل مميز
    2,004
    التعديل خطييييير ..
    بس أعتقد لو الجناح كان أصغر بتطلع احلى من الخلف ..!
    مثل ماقال جمس لوفر لو اليناح اصغر احسن و بيخلي السياره احلا
  1. مشاركات: 2
    آخر مشاركة: 24-09-2010, 09:37 PM
  2. جديد موستنق شلبي ستوك VS كامارو اس اس 2010 معدل ....... (( الرياض ))
    آخر مشاركة: 14-09-2010, 06:14 AM
  3. جديد : 2010 كاديلاك CTS-V مع جاكور XFR مع كامارو 2010 مع كامارو Z28 (( السعودية ))
    آخر مشاركة: 05-09-2010, 06:18 AM
