صفحة 1 من 4 1234 الأخيرةالأخيرة
النتائج 1 إلى 6 من 20
    Cool أستون مارتن رابيد في صور جديدة + المواصفات
    Aston Martin Rapide Specifications
    Body
    Four door body style with 4 individual seats
    Extruded bonded aluminium VH body structure
    Aluminium, magnesium alloy and composite body
    Extruded aluminium door side impact beams
    Single bi-xenon headlamps with integrated LED side lights and direction indicators
    LED rear lamps and side repeaters
    Engine
    All alloy quad overhead cam 48 valve 5935cc V12
    Front mid-mounted engine, rear-wheel drive
    Fully catalysed stainless steel exhaust system with active bypass valves
    Compression ratio 10.9:1
    Max Power 350 kW (470 bhp / 477 PS) at 6000 rpm
    Max Torque 600 Nm (443 lb ft) at 5000 rpm
    Acceleration 0-60 mph in 5.1 seconds; 0-62 mph (0-100 km/h) in 5.3 seconds (predicted)
    Max Speed 188 mph (303 km/h) (predicted)
    Transmission
    Rear mid-mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system
    Alloy torque tube with carbon fibre propeller shaft
    Limited slip differential
    Final Drive Ratio 3.46:1
    Steering
    Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock-to-lock
    Column tilt and reach adjustment
    Wheels & Tyres
    20" alloy wheels
    Front Bridgestone Potenza 245/40 R20
    Rear Bridgestone Potenza 295/35 R20
    Suspension
    Front Independent double wishbone incorporating anti-dive geometry, coil springs, anti-roll bar and monotube adaptive dampers
    Rear Independent double wishbones with anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube adaptive dampers
    Adaptive Damping System (ADS)
    Brakes
    Front Dual cast brake discs 390mm diameter with six piston calipers
    Rear Dual cast brake discs 360mm diameter with four piston calipers
    Dynamic Stability Control (DSC)
    Anti-lock braking system (ABS)
    Electronic Brakeforce Distribution (EBD)
    Emergency Brake Assist (EBA)
    Traction Control
    Hydraulic Brake Assist (HBA)
    Positive Torque Control (PTC)
    Electronic Park Brake (EPB)
    Dimensions
    Length 5019 mm (197.6")
    Width (including mirrors) 2140 mm (84.3")
    Height 1360 mm (53.5")
    Fuel Capacity 90.5 litres
    Kerb Weight 1950 kg (target) (4299 lb)
    Interior
    Full grain leather interior
    Walnut facia trim
    Iridium Silver centre console outer finish and Graphite inner finish
    Auto-dimming interior rear-view mirror
    Auto-dimming interior rear-view mirror with garage door opener (USA and Canada only) *1
    Electrically operated front seats
    Memory front seats and exterior mirrors (three positions)
    Dual stage driver and passenger front airbags
    Front occupant side airbags
    Head protection airbags for front and rear occupants
    Heated front and rear seats
    Heated rear screen
    Automatic front and rear temperature control
    Organic Electroluminescent (OEL) displays
    LED map lamps and ambient lighting
    Trip computer
    Cruise control
    Hard Disk Drive (HDD) satellite navigation system *1,2
    Bluetooth telephone preparation *1
    Satellite radio system (USA only)
    Powerfold exterior mirrors
    Front and rear parking sensors
    Tyre pressure monitoring *1
    Alarm and immobiliser
    Remote-control central door locking and boot release
    Battery conditioner
    Tracking device (UK only) *3
    Boot mounted umbrella
    In Car Entertainment
    1000W Bang & Olufsen BeoSound audio system with ICEpower® technology
    Integrated Apple iPod® connector *4
    USB connector with Windows Media Audio (WMA) and MP3 audio file compatibility
    3.5 mm auxiliary input socket
    Options
    Cooled front and rear seats
    Twin screen rear seat entertainment system with 6-disc DVD player, auxiliary input, wireless headphones and remote control
    Alternative facia trim finishes – Mahogany, Piano Black, Bamboo, Tamo Ash, Double Apex Alloy, Nexus Alloy
    Matching wood door trim
    Colour-keyed steering wheel
    Second glass key
    Magnum silver rear lamp infills
    Delete model badging
    Delete protective tape
    20" alloy wheels with graphite finish
    20" alloy wheels with polished finish
    Alternative brake calliper finish – black, red, silver
    Personalised sill plaques
    Auto dimming interior rear view mirror with garage door opener (Europe only)
    Alarm upgrade (volumetric and tilt sensor)
    Tracking device *1,3
    First aid kit
    Ashtray and Cigar Lighter
    احسها من داخل عالم ثاني !!
    الصورة الرمزية DONmannai
    DONmannai غير متصل عضو متميز
    الله يا عمري قطر
    2,907
    متالقه كعادتها أستون........... سلملي على الباناميرا هذي احلا
    يعطيك العافيه على الصور
    الصورة الرمزية K H A L E D
    K H A L E D غير متصل مشرف عام
    KSA-buraydah
    6,508
    تصميمها افضل من البورش الباناميرا
    بس الباناميرا فيها شئ يعجبني ماادري وشو
    تسلم
    الصورة الرمزية بوخليفة
    بوخليفة غير متصل عضو فعّال
    Jun 2009
    675
    ما شالله ................. بصراحه هالموتر غير.......... روعه من الخارج ومن الداخل......سياره كامله والكامل الله سبحانه
    الصورة الرمزية horas3000
    horas3000 غير متصل عضو جديد
    May 2009
    10
    من الخارج بالفعل احسن من البانيميرا
    و ان كانت البانيميرا علي الطبيعة احلي من الصور
    لكن دواخل البانيميرا احلي
    صورة لداخل البانيميرا من تصويري
  1. مرسيدس CLS 2012 في صور جديدة.......(جديد باريس)
    مشاركات: 23
    آخر مشاركة: 30-06-2012, 02:46 PM
  2. أول حادث لأستون مارتن رابيد
    آخر مشاركة: 14-09-2010, 07:50 PM
  3. رينو لاتيتيود في صور جديدة
    آخر مشاركة: 27-08-2010, 04:18 PM
