    افتراضي شيء يديد في السوق للسيارات
    يتغير الرقم مع تبديل الجير إلى الغيار السادس!
    Indy-Cator shiftknobs, Type 1
    A revolutionary product! This universal shiftknob with LCD display is not only good for looks: it also increases driving safety and helps reduce fuel consumption by up to 15 percent by means of an adapted driving style.
    This shiftknob fits all cars with manual transmissions up to 6 speeds (i.e. will work with 2sp, 3sp, 4sp, 5sp 6sp etc.)and is designed to work with every gearshift pattern.
    (Does not work with cars that have gear levers with reverse gear locking mechanism). If you have to push down for reverse that is fine, what this means is that you just cannot have any type of switch that is part of your current OEM shift knob that must be switched/engaged etc. to get into the reverse gear.
    A light sensor in the Indy-Cator adapts the brightness of the digital display to the surrounding light by means of an automatic dimming function, ensuring optimal readability at all times.
    The connection to the cars power supply and gear assignment programming is very simple, and of course the shiftknob comes with detailed instructions for installation. It does not require wiring into the transmission, ECU or any other module of the car!
    Available with red, blue or green display.
    y-Cator ype 1 shiftkno red US $ 179.00 / set order no.: SB-345 Indy-Cator Type 1 shiftknob, blue US $ 179.00 / set order no.: SB-346 Indy-Cator Type 1 shiftknob, green US $ 179.00 / pc order no.: SB-355
    It's yet another clever application of LED technology, lighting up your car's decor while saving energy in a unique way.
    الصورة الرمزية الامير الاحمر
    الامير الاحمر غير متصل عضو نشيط جداً
    O.M.A.N
    496
    ياسلااااااام
    هذي الأشياء الجديدة ولا بـلاش
    حركة حلوة
    بس ما اعتقد منها فايدة يعني منو المتفيج اللي بيغيره للسادس وبيتم يطالع الجير
    هذا للقير العادي والاتوماتيك
    بس شي حلو في السوق
    تسلم
    الصورة الرمزية DONmannai
    DONmannai غير متصل عضو متميز
    الله يا عمري قطر
    2,907
    حركه حلوه لكن أنا أشوفها غير عمليه
    إذا كان الهدف منها الشكل والزينه .........أوكي
    إذا كان الهدف منها تنبيه السائق على الغيارات حركة قير الرالي أفضل .............. السائق بيشوف الشارع ولا القير
    والله اشوف الحركه حلوه كزينه بس ابد مب عمليه
  1. لكزس تحافظ على مكانتها كأكثر الماركات الفاخرة بيعا للسيارات
    آخر مشاركة: 09-09-2010, 01:46 PM
  2. مشاركات: 0
    آخر مشاركة: 08-09-2010, 01:27 AM
  3. عقود الشراء الموحّدة للسيارات في يناير
    بواسطة روح زايد في المنتدى أخبار السيارات
    آخر مشاركة: 07-09-2010, 05:12 AM
  4. مشاركات: 8
    آخر مشاركة: 05-09-2010, 05:10 AM
