صفحة 4 من 4 الأولىالأولى 1234
النتائج 19 إلى 21 من 21
  1. #19
    loolicpolic غير متصل عضو نشيط جداً
    قطر
    283
    اقتباس المشاركة الأصلية كتبت بواسطة AMG
    داخلية السيارة سيئة :(
    هي غير معتادة من مرسيدس.. بس في إنتظارها على الطبيعة..
    تحياتي..
  2. #20
    The announcement of the new C-class sedan is in January 07. He is delivered starting from March. But already series production started. Mercedes pays attention to highest quality.
    Classic: An oval exhaust pipe left, painted door handles without chrome, no chrome around the car, no LED rear lights, no chrome shroud around the Zierteile, the TAC hone aristocracy is larger than with the others and goes from the center of the combination instrument out (probably only if no Comand were ordered). With avant-garde and Elegance the small pointer at the exteriors of the Tachos goes along. The star is on the hood. Radio not in series, then also no operating sectors available. Tire: 16 tariff light alloy wheels.
    Elegance: LED rear lights, chrome shroud of the Zierteile, leather steering wheel and shift lever, two oval final pipes one on the left of the other one right (probably also dependent on motorizing), Tacho with chrome rings, small aerodynamic spoilers on the left and on the right at the front apron; 17 " light alloy wheels
    Avant-garde: LED rear lights sounded, two oval final pipes one left (probably also dependent on motorizing), the other one right, star in the radiator grille, set lower, 17 " rims, outside chrome and in the interior also the shrouds, as well as the Tacho as with Elegance.
    The outside mirrors some little like sail ears are away, fulfill new law guidelines. The mirror turn signals became also larger.
    New equipment: Keyless Go, Linguatronic, large panorama roof as subdivided in E-class (with the T-model the panorama roof is somewhat shorter, DVD change-over switch, Bluetooth mobile phone, Knieairbag. With Thermotronic the climatic mechanism also an operating sector in the rear has.
    Comand: Be under a cover, if one presses a small button on the cover drives these upward/in the back away and the screen folds out. At a switch at the screen one can stop still the inclination of the screen, which air conditioning system served over the completely normal switches. If the Comand screen is away-folded can one still completely normally radio and CD hear and this over the buttons in the center console serve. Otherwise the operation of the Comand and the menu are identical to that the S-class.
    Seat heating and Heckfensterrollo are steered completely normally via a switch panel over the air conditioning system.
    The T-model starts in the autumn. C 63 AMG with approx. 450 HP is pointed to the IAA 07 and delivered starting from first quarter 2008. Also a Black Series model is angedacht.
  3. #21
    الصورة الرمزية that me
    that me غير متصل مشرف سابق
    الرياض
    2,438
    ما شاء الله الموتر روووووعه واكثر من ممتازة .... وهذا يعتبر هامور الفقراء
    غريب السيف ننتظرها بسعر تعجيزي كالعادة
    فعلا للاسف وكلاء مرسيدس بدوؤ يلعبون ويبتزون المواطنيين يسيروون على خطى وكلاء لكزس
  1. مرسيدس CLS 2012 في صور جديدة.......(جديد باريس)
    مشاركات: 23
    آخر مشاركة: 30-06-2012, 02:46 PM
  2. رينو لاتيتيود في صور جديدة
    آخر مشاركة: 27-08-2010, 04:18 PM
