النتائج 1 إلى 6 من 12
    افتراضي فقط لاصحاب ال FJ موديل 2007 -2009
    يزيد 27 حصان على قوة المحرك
    2009 Toyota FJ Cruiser 4.0L with TRD Supercharger (TRD reflashed ECU)
    • The Plug 'n Play kit that comes pre-mapped to optimize your bolt-on accessories
    • Installs in minutes , ready to roll!
    $595.00 USD
    Share This: click to share
    • Applications
    • Features
    • Dyno Sheets
    • Instructions
    • See The Difference
    • All models '07 , '08 ,'09 FJ Cruiser
    • Normally aspirated as well as TRD Supercharged models supported
    • ROADSPEED-LIMIT Removal now available on demand , see FEATURES tab for details.
    • Add's up to 27hp & 26ft-lb .
    • Easily plugs into the stock ECU & ECU harness in minutes , no programming necessary .
    • Realizes the full potential of Aftermarket add-on's like Cold-Air-Intakes & exhaust systems , as each kit comes pre-mapped for the exact set-up of each car or truck.
    • No end-user tuning necessary , just plug the kit into the car & you're ready to go.
    • Easily upgradeable for future add-on's.
    • Each kit comes with two maps : a low octane performance map & a high octane performance map, switchable from within the vehicle.
    • Fully tuneable by a Unichip Custom Tuner for customized add-on's . This basically means that the Engine Management System in your ride is now as tuner friendly as the most advanced Standalone systems in the world , without sacrificing any of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
    • Plug 'n Play harnesses are fully Flux capable - purchase Flux when you purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
    • Plug 'n Play kits are removed from the vehicle in minutes , returning the vehicle to stock tuning , without leaving a footprint of ever having been modified (a feature which reflash-tuning cannot match).
    • ROADSPEED-LIMIT Removal now available . Write : "Remove roadspeed limiter" in the comments section of the checkout . This feature is only available on this website.
    Dyno Results 2007-2009 models
    Click on the dyno sheet for larger view or to print.
    Installation Instructions for FJ Cruiser
    " I ordered a Unichip Plug 'n Play kit for my Toyota . When I opened the box I was shocked ! I expected a micro chip , what I got was a fully functional engine management computer , together with a top quality wiring harness to connect it to my vehicle . I called the guys at Unichip & they explained the whole system to me . The Unichip comes pre-mapped to optimize my Cold Air Intake , Headers & Catback exhaust . Two maps ensure optimal timing settings with standard & premium octane fuels , as well as the best possible mixture settings. I switch between maps via a special switch . On top of all of this I can have the system re-programmed for different bolt-on configurations . I can even have the system custom-tuned ! Installation was a breeze! Now that I have the Unichip system & I understand how it works I realize that all the other so-called tuning products advertised on the internet for Toyota's are all just gimmicks ! They're either small resistors which connect to the MAF sensor (with no power gain) or shady "ECU reprograms" which void your ECU warranty & provide no gains whatsoever . I recommend the Unichip to anyone who prefers quality parts on their Toyota & if you don't believe me , do your homework & compare the Unichip to anything else out there , it beats anything hands down!" Jose F , Florida .
    Become A Unichip Certified Tuner
    Boost your business by providing service for the Unichip
    Plug & Play Kits
    Easily add power and torque to your vehicle in minutes!
    Tune your alternative fuel project!
    Big tuning power in a small package!
    Latest Blogs
    Ask Jack
    Ask Jack. Eng...
    New product
    The FJ & Tundra are almost done!
    New blank harnesses
    Latest Blank Harness arrival
    Quick Navigation
    Contact Us
    Unichip North America
    1-866-UNICHIP
    2615 SE 39th Loop, Suite B,
    Hillsboro, OR 97123
    Copyright © Unichip USA
    * All manufacturer's names, numbers, symbols & de******ions are for reference purposes only.
    It is not implied that any part, conversion or modification is the product of these manufacturers.
    Site By:
    الصورة الرمزية الزرعوني
    الزرعوني غير متصل مشرف عام
    25
    5,781
    مشكور اخوي حاجوني .. و هذا يباله برمجه و يمدحون بن عمر :)
    التنين غير متصل عضو فعّال جداً
    Apr 2009
    1,410
    محرك الاف جي مره غبي
    وبالقوه تزيد احصنه
    على عكس المحركات الامريكيه الي بس شوية لعب تلقاها زادت الاحصنه كثير
    بس 27!!!
    الكورفت شوف بسوبر تشارجر قوها من 505 الى 639
    السر هوا ان المحركات الامريكية فيها قوة بس محددة..
    لما تركبها وطبعا يفكوا البرمجة يعطوها المكاسيموم باور ^^
    -X-
    -X- غير متصل عضو نشيط جداً
    314
    شي طبيعي انها بتعطيك هالقوة لانها تشب كمبيوتر مو سوبر تشارج
    كل تشبات الكمبيوتر للسيارات الالمانية واليابانية تعطيك تقريبا من 25-30 حصان (التشب هو شريحة تركبها على كمبيوتر السيارة وتغير لك في البرمجة حقت الكمبيوتر بس الميزة فيها انك تقدر تفكها خلال ثواني مو مثل اللي يبرمج لك الكمبيوتر كامل لازم يروح عند اللي برمج على شان يرجع البرمجة القديمة )
    فية سوبر تشارج للأف جي من TRD يعطي فوق ال 70 حصان على ضغط منخفض مايزيد عن 10psi ويمديك ترفع الضغط على شان تحصل على اكثر من هالقوة
    هيه والله غير الامريكي ماشي .. بسهوله تزوده ويعطيك دبل الي تحصله من الياباني او الالماني
  1. للبيع دراجة رابتر 450 موديل 2007
    بواسطة سفير في المنتدى قسم البيع والشراء
    آخر مشاركة: 18-09-2010, 07:24 AM
