النتائج 1 إلى 5 من 5
    افتراضي إختراع جديد من ميشلان ...
    عندما تموت البطاريه هل من الصعب أن تصل الكيبل الاحمر بالأحمر و الأسود
    بالأسود! أعتقد إنه ما يحتاج ذكاء (إختراع جيد للحريم)
    القطعه الالكترونيه في النصف هي التي سوف تحدد الموجب أو السالب، فقط عليك
    توصيل الكيبل.
    السعر من 30-40 دولار
    Never blow up your battery with Michelin Smart Jumper Cables
    Mar 20th 2010 at 5:01PM
    شوف الرابط للفيديو
    Pylon Manufacturing Corporation
    Virtually every driver will, at some point, get that sinking feeling that comes when your car doesn't start. Digging out a set of jumper cables to boost a battery is a rite of passage. Jump-starting a car can be a slightly tricky process, though. The positive and negative terminals of the booster and "boostee" need to be connected properly or the battery can be blown up. Which is, you know, sub-optimal. Over the past decade, a number of devices have come out to help ease the battery-jumping process, including portable booster batteries and even jumper cables that plug into a 12V outlet inside the car. Those plug-in cables will never be connected with reverse polarity, but they might not be able to carry enough current to actually crank your engine.
    Enter the Michelin Smart Jumper Cable. Instead of the usual color-coded clamps for your battery's positive and negative terminals, the cables are all Michelin blue. Halfway down the cable is a box of electronic smarts. Just put one clamp on the positive terminal of the battery and the other on any piece of bare metal and the electronics will detect whether you've made a complete circuit and illuminate an LED on the central box. When the second battery is connected, the electronics automatically determine the polarity and switch it as needed. A set of these smart jumper cables runs about $30 to $40.
    الرجاء نقل الموضوع إلى قسم السيارات العام
    اختراع للحرمة اللي مب متفيجة للسيارة بس ما ادري على اي اساس هي خذتها
    ولا يوم بتشوف هذا بتقول اكيد هذا ينفخ التواير
    اعتقد هذا الجهاز لازم ينشحن!!!
    الصورة الرمزية KID
    KID
    KID غير متصل عضو فعّال
    Feb 2009
    535
    ليه من متى الحريم تفكر بها الشي
    اصلن لو قلت لوحده بطاريه السياره بتقول (هاي في كل السيارات موجوده ولا) لاء انا تشتغل على البتروووول
    خخخخخخخخخخخخخخ <<< بايخ
    لا مو بايخ ولا شي من جد حاصل
    الحريم الله يعلم وين موديهم بس وظيفتها يشغلوا السيارة ويمشوا بس...
    لو جبت لهم تاتا وقلتلهم هاي بورش يحسبوها من جد بورش هههههههههههههههه
  1. مشاركات: 3
    آخر مشاركة: 25-10-2011, 05:51 PM
  2. مازيراتي جران توريزمو MC Stradale.......(جديد باريس)
    آخر مشاركة: 22-09-2010, 03:36 AM
  3. لوتس ايليت 2014........(جديد باريس)
    آخر مشاركة: 21-09-2010, 08:53 AM
  4. بنتلي تكشف عن كونتينينتال GT........(جديد باريس)
    آخر مشاركة: 08-09-2010, 09:39 AM
  5. جديد : كــامـارو اس اس vs ls3 مــوســتنق شــلبـي .... (( الرياض ))
    آخر مشاركة: 07-09-2010, 09:06 AM
