النتائج 1 إلى 6 من 12
    افتراضي تقنية BMW الجديده للدخول في الاماكن الضيقه
    تقنية Narrow-passage Assistant من BMW التي سوف تكون متوفره في المستقبل القريب
    تتيح لك الدخول إلى الاماكن الضيقه و التي قد يراودك الشك بأن تخدش أو أن تضر بسيارتك...
    السؤال: هل سوف نثق بهذه التقنيه ... أو بالأحرى هل نحن بحاجه إليها من الاصل؟
    The range of useful, high-tech gadgets for automobiles to be made available in the near future expands at an exponential rate, with more and more "toys for boys" being made available for the masses. The latest entry in this category is the BMW Narrow-passage Assistant, a technology to be used to navigate the car through narrow spots, regardless of the manner in which they manifest.
    The technology behind the Narrow-passage Assistant is somewhat simple: a computer system uses various sensors to determine whether the car can fit into a narrow spot without grazing the paint or crashing the car. Its application, however, may be controversial, as it may spawn "should we trust tech so much?" debates.
    Regardless, we set out here to shed some light on how this technology is supposed to work.
    preSite
    The preSite reading coming from the system is intended to display the effectively available width of the road, prior to a passing maneuver. It displays the lateral clearance on both the left and right sides, sending three types of readings back to the driver. One circle means much space (0.5 – 1 meters), 2 circles means little space (0.2 – 0.5 meters), while 3 circles means it's gonna be a tight squeeze (under 0.2 meters). Should the distance go below the safety clearance, the system will send an additional warning via the HUD.
    inSite
    Once a driver assesses he has enough room to squeeze through, the inSite monitoring system kicks in. It keeps the driver on track throughout the maneuver, by monitoring the lateral distance. Using data coming from the lasers, the system sends back information directly via the steering wheel, as well as through the HUD.
    SENSORS
    The two types of sensor used by the BMW Narrow-passage Assistant are, as said, laser- and ultrasonic-based. The lasers are used by the system to monitor the space in front of the vehicle, scanning for other cars, barriers and safety fences. The lasers work at a horizontal beam angle of 160 degrees and a vertical one of 3.2 degrees, They can scan the road ahead for a distance of up to 100 meters.
    شي حلو
    واحسها تنفع بالسيارات الكبيره خصوصا بالطرق في المدن المزدحمه :)
    يازين هالحركة لو جت مع الاكسبديشن !!!!!!! على الاقل ادخل في المواقف الارضية للمراكز التجارية بثقة وبدون ما احسب خطوتي مليون مرة
    يازينها لو جت بالتاهو بعد ههههههههههههه^^
    -X-
    -X- غير متصل عضو نشيط جداً
    314
    يازينها لو جات عالهمر اتش 1
    1100R غير متصل عضو فعّال جداً
    1,031
    وين هالأختراع عننا,,,راح يفك ازماااات كثيررررررر
    فعلا هذا الي اسمية ابتكار بلا هايبرد وخرابيط..
    ارفع القبعة تحية لــBMW ..
  1. فقط للسوق الاستراليه BMW M3 Pure Edition
    آخر مشاركة: 20-09-2010, 12:26 PM
