موضوعكم حلو وكاميرتي هي
كانون 350D
8 ميجابكسل
اليكم صورتها
مواصفاتها بالتفصيل
Eight megapixel CMOS sensor (not same as EOS 20D)
Second generation CMOS (same generation as rest of current range)
DIGIC II image processor (better image quality, faster processing, less power consumption)
Instant power-on time, faster shutter release, shorter blackout time
Continuous shooting speed increased (3.0 fps vs. 2.5 fps)
Buffer increased (14 JPEG frames vs. 4 JPEG frames)
Image processing time decreased (thanks to DIGIC II)
Compact Flash write speed increased
Smaller body (15 x 5 x 8 mm smaller)
Lighter weight (17% lighter including battery)
Matte plastic finish, standard body color to be black, sliver will also be available
Re-designed control layout (drive mode button, new metering mode & AF buttons)
****l mode dial
Harder rubber finish on hand grip (doesn't feel much like rubber)
Smaller and lighter NB-2LH battery (same as PowerShot S60 / S70) which is 48% lighter
Rear LCD panel changed
Flash pop-up slightly higher (just 5 mm)
E-TTL II flash
