النتائج 1 إلى 6 من 16
    افتراضي اليابانيين متخبلين على نيسان Juke
    مبروك على اليابانيين و الاوروبيين ....
    YouTube - Nissan Juke Small Crossover SUV
    مبيعات خياليه للسياره في اليابان و طلبيات أكثر من 10,900 في الشهر و اللون الاحمر
    Radiant Red هو اللون المرغوب أكثر و المحركات المتوفره هي 1.6l MR16DDT turbocharged
    engine, و التي تشبعك بقوة 2.5 لتر و صرفية 1.8 لتر
    A Newly Developed 1.6-liter Direct Injection Gasoline Turbocharged Engine
    Based on the downsizing concept, a new 1.6-liter 4-cylinder MR16DDT engine with Direct Injection Gasoline technology has been developed - combining a turbocharger with a low displacement engine to achieve both higher power output and lower fuel consumption. It also adopts inlet and exhaustion CVTC and hydrogen-free DLC(Diamond Like Carbon) coating, as well as other new technologies such as the new friction-reduced valve spring.
    MR16DDT engine
    The MR16DDT engine achieves power equivalent to that of a 2.5-liter engine, along with the fuel efficiency equivalent to a 1.8-liter engine. The new engine will be available in the Nissan JUKE in the second half of FY2010.
    Nissan continues promoting the "Nissan Green Program 2010" by introducing effective technologies, products and services into the market.
    1 1.0-1.5L Class not including Hybrid vehicles.(as of July 2010 based on current Nissan studies)
    2 With an angle of 6% or less.
    و الجديد أن شركة نيسان اعلنت أنها ستزود السياره
    بمحرك جديد بقوة HR15DE 1.5-liter engine ثنائي الحقن و هذا الاول من نوعه تجاريا...
    The World's First Mass-Produced 1.5-liter Engine with Dual Injectors
    Another advanced fuel-efficient technology to be launched in FY2010 is Nissan's new 1.5-liter engine (HR15DE), the world's first mass-produced 1.5-liter engine with dual injectors (2 compact injectors per each cylinder).
    HR15DE engine
    The dual injectors stabilize combustion by reducing the size of the particles sprayed in the form of a mist by approximately 60%. Improved thermal efficiency and reduced inhalation resistance have been achieved by combining the injectors with Continuously Variable valve Timing Control (CVTC), which continuously changes the opening-closing timing of the inlet and exhaust valves. As a result, fuel economy has been improved by approximately 4% compared to Nissan's conventional engines in the same class. In addition, more efficient burning helps to control the hydrocarbons in the exhaust gas and reduces the amount of noble metals needed for exhaust purification. The engine is mounted on the Nissan JUKE, which was launched in Japan in June 2010.
    التعديل الأخير تم بواسطة Patrol 5.6 VVEL ; 06-07-2010 الساعة 07:23 PM
    genes power غير متصل Banned
    Jun 2010
    K.S.A - Tokyo
    570
    كان قلت اليابانيين وانا
    والله شكلها خطييييييييير من جميع النواحي باستثناء الاسطب المعوق اللي في الكبوت
    وانا اعتبرها نيسان z جيب
    وان شاء الله تنجح عندنا
    ولاتنسو سعرها اللي هو السبب في كثرة الطلب عليها
    شكرا على الخبر الرائع^^"
    هذا اول ماينزل عندنا اول الناس بيشترونه الهنود
    خخخخخخخخخ مادري احس خبل اللي يشتريها مع احترامي للجميع <<<عشان لاتهاوشوني :)
    وحدة اضاءتها زي الزفت ههههههههه !
    مع احترامي لك اخوي genes power تقارن هاي القبيحه بزد الله يعز الزد تصميم و اناقه مب قبح و دفاشه في هاي السياره
    بصراحه هاي موضه و بتنتهي
    هذي احس ان محد بياخذها الا الجالية الأسيوية
    بنظري قبيحة واتمنى اشوفها بالشارع عسب احكم لها حكم نهائي
  1. الموضوع الخاص بأجهزة ANDROID
    بواسطة بو علي في المنتدى استراحة شباب الخليج
    مشاركات: 434
    آخر مشاركة: 09-12-2011, 11:01 PM
  2. لكزس تطرح في المنطقة LS 600hL أول سيارة هجينة بالكامل فاخرة
  3. «العروض الرمضانية» تنعش مبـيعات السيارات
    بواسطة روح زايد في المنتدى قسم السيارات العام
    آخر مشاركة: 09-09-2010, 09:13 AM
  4. هيونداي تستعد لافتراس نيسان
    مشاركات: 18
    آخر مشاركة: 06-09-2010, 10:07 AM
  5. الملخص الكامل والتحليل لحدث آبل للموسيقى
    بواسطة Brhoom في المنتدى استراحة شباب الخليج
    آخر مشاركة: 05-09-2010, 05:23 AM
