    افتراضي لمحبي التزويد الان فورد توفر محرك Ford Mustang GT 5.0 V8 في صندوق
    فقط ب 6999 دولار
    Ford Offering Mustang GT 5.0 V8 as Crate Engine
    Ford Mustang GT 5.0 V8 engineThe return of the 5.0 Mustang has made it to the automotive history books as one of the greatest events in the history of modern pony cars.
    In other words, both the public and the media were more than happy to become friends with the new 5.0 liter four-valve Twin Independent Variable Camshaft Timing (Ti-VCT) V8 powerplant that delivers 412 hp and a maximum torque of 390 lb-ft
    Now, Ford Racing is offering automotive enthusiasts the opportunity to enjoy the engine without the whole package. The company is offering the Mustang GT’s 5.0 l V8 as a crate engine on its website.
    If you feel like this is the right V8 for your project, you can see more details on the Ford Racing website. Don’t forget to prepare $6,999 if you’re willing to buy one.
    Let’s see what exactly do you get for that money:
    • <LI itxtvisited="1">11.0:1 Compression ratio <LI itxtvisited="1">Lightweight aluminum cylinder block features cross-bolted main bearing caps and thick main bearing bulkheads for bottom-end strength <LI itxtvisited="1">Piston-cooling jets, optimized oil drainback and windage control improve high-rpm performance <LI itxtvisited="1">Deep sump oil pan with 8qt capacity <LI itxtvisited="1">Tuned composite intake manifold provides efficient air delivery and weight savings <LI itxtvisited="1">80 mm single bore "drive by wire" throttlebody <LI itxtvisited="1">Four-valve-per-cylinder aluminum heads with roller-finger followers reduce friction <LI itxtvisited="1">Includes manual transmission engine harness and flywheel <LI itxtvisited="1">Vehicle harness and PCM not included <LI itxtvisited="1">Use our NEW wiring, PCM and installation kit M-6017-A504V designed for street rod/project car installation. <LI itxtvisited="1">Does not include alternator, for alternator kit see M-8600-M50ALT <LI itxtvisited="1">2011 5.0L Mustang engine cover kit available, see M-9680-M50 <LI itxtvisited="1">Engine mount bosses and bellhousing mount pattern common to 4.6L modular engines. <LI itxtvisited="1">Direct replacement for 2011 Mustangs with engine code BG-397-AA <LI itxtvisited="1">Photo and specs may vary. These features apply for engine code BG-397-AA. Engines are this build code or newer while supplies last.
    • Engine weight: 444 lbs
    التنين غير متصل عضو فعّال جداً
    Apr 2009
    1,410
    كان كتبو 7 الاف وريحو نفسهم
    Sep 2009
    السعودية / المدينة المنورة
    97
    لا يا رجال , عشان في يصير بحر الـ6 الاف و يقولوا رخيص :P
    الصورة الرمزية E_TYPE
    E_TYPE غير متصل عضو فعّال
    800
    تعوووويض يعني مال الي اشترى 2010 .. بس شئ حلوو
    Dr.90490 غير متصل عضو نشيط
    UAE, RAK
    139
    Stang Net مزهب مشروع حلو و عقبال شباب الخليج.
    زين حق اللي موستنج جديم ....وزين بعد حق اللى عنده نيسان باترول ربع ...بدال ما يحط مكينة لكزس 4,3 لتر او مكينة لومينا
  1. فورد فوكس ST 2012..........(جديد باريس)
    آخر مشاركة: 15-09-2010, 10:47 PM
