النتائج 1 إلى 6 من 12
    Smile G-Power M5 Hurricane RR أسرع صالون في العالم
    372 km/h - The World's Fastest Sedan
    G-POWER HURRICANE RR based on the BMW M5
    G-POWER M5 HURRICANE RR
    800 hp / 588 kW at 7.500 r/min (+ 293 hp / 215 kW)
    800 Nm at 5.000 r/min (+ 180 Nm)
    Top speed: 372 km/h
    0-100 km/h: 4,35s
    0-200 km/h: 9,5s
    0-100 km/h: 25,8s
    Vehicle complete with accessories: starting at € 252.100,00,-- (net)
    Following up on the G-POWER M5 HURRICANE RS powered by a G-POWER twin-supercharger engine with 750 hp/551 kW, which has set the record for the ‘world's fastest sedan' at 367,4 km/h in early 2010, G-POWER did it again. But this time with 372 km/h! With this target in mind, the development for the new evolutionary HURRICANE RR with 800 hp began.
    A few weeks ago, the air is tight with tension when the G-POWER engineers give their "go" for the M5 HURRICANE RR to manage the ultimate test: High Speed. It takes only a few minutes to change the standard 20 inch G-POWER forged wheels to 19 inch ones. The wheels, especially fitted with Michelin Pilot Sport tires that Michelin are certified for top speeds of more than 370 km/h. The HURRICANE RR is ready to go, the test track as well. Apart from the swop of the wheels the HURRICANE RR is completely standard and relies predominantly on its power of the bi-supercharger engine. And just a few laps later it is done. The analysis of the engineers states a top speed of 372,1 km/h. World record! Once again...
    To achieve this extreme performance, the twin supercharger system of the high-revving V10 has been redesigned. The two superchargers named ASA T1-313 have been replaced by larger ASA T1-316 units. They are both driven by a belt and do provide each cylinder bank with supercharged air. This means more space for the supercharged air by up to 25 percent. The air volume being transported by these modified superchargers is able to generate a theoretical power output of more than 900 hp.
    The pre-compressed air from the superchargers is cooled for a maximum power output. A complicated aluminium casting - painted in G-POWER orange - replaces the standard air box on top of the engine, and its direct inlet is responsible for the spontaneous response characteristics which give the G-POWER motor its incomparable response and also much more torque.
    The inner workings of the 10-cylinder, four-valve engine are optimised by light, precisely balanced MAHLE high-performance forged pistons with lower compression and increased mechanical strength. As the standard connecting rods and piston pins were equally not up to the considerably increased forces, here too, recourse was had to special parts.
    An optimized mapping of the engine electronics also contributes to the increased power output of 800 hp / 588 kW, available between 7,500 and 8,000 rpm. The engine delivers its peak of torque of 800 Nm at 5,000 rpm.
    But the G-POWER HURRICANE RR does not only set new performance standards for top speed. With an acceleration of just 4.35 seconds from nought to 100 km/h, 9.5 seconds up to 200 km/h and 25,8 seconds up to 300 km/h the two-ton sedan is also leading his class.
    The G-POWER technology is available for all current M5 and M6 models. The G-POWER SK III bi-supercharger engine conversion with 750 hp / 551 kW starts at 56,000 Euros (net).
    In addition to the most powerful BMW engine ever being fitted to a street-legal BMW M5 a new aerodynamic for maximum efficiency was key. The HURRICANE RR is equipped with the G-POWER "HIGHLINE" body kit. In addition to provide the necessary downforce the body kit is also designed to provide significant more air flow to cool the engine. The body kit consists of front and rear skirts and spoilers, doors render and the rear spoiler.
    Two tons of weight and a top speed of 372.1 km/h naturally require extreme demands on the tires, being fitted on special G-POWER forged wheels. Our technology partner Michelin provided high-performance Pilot Sport tires in the dimensions 255/35 ZR 19 at the front axle and 305/30 ZR 19 at the rear axle for this reason. For every day use the G-POWER HURRICANE RR runs on 20-inch Silverstone CLUBSPORT wheels with the dimensions 245/35 ZR 20 and 285/30 ZR 20 front and rear.
    Even more contributions to the HURRICANE RR's high-speed talents are coming from a G-POWER high-performance brake system and the height-adjustable G-POWER RS coilover suspension that is adjustable for both compression and rebound in nine settings.
    The interior of the record car features a tachometer reading up to 400 km/h, clear-coated carbon-fiber panels for the dashboard, center console and door panels. An ergonomically shaped G-POWER sports steering wheel with especially perforated Kjerba Nappa leather is completing this package.
    The G-POWER HURRICANE RR can be ordered as a complete car starting at 251,100 Euros. Any current M5 model - sedan or station wagon - can also be equipped with the individual G-POWER components of the world record holder.
    The company G-POWER:
    G-POWER was established in 1983 and has ever since exclusively focused on tuning BMW automobiles and producing exclusive one-of-a-kinds. In 2008, the brand celebrated its 25-year anniversary and today, it is one of the most renowned providers on the global market. By developing the world-wide strongest versions of the most important BMW engines in-house, G-POWER significantly stands out from its competitors. G-POWER holds various world records and its 800 hp strong BMW M5 Hurricane RR is the fastest limousine in the world. G-POWER is holding the High-Speed record for over two years now.
    Nov 2007
    1,463
    عـــــــجـــــيــــب مرررره
    ماشاء الله طيارة
    السرعه جنونية
    تسلم اخوي عمر
    الصورة الرمزية 911turboS
    911turboS غير متصل عضو فعّال
    650
    750 وهذي تسارعاتها !!! ... وش رايكم نيجبها ل 700 هنسي مش 750 بعد :)
    700 هنسي تجيب الربع ميل خلال 10.8 وعلى سرعه 126 ميل ....
    الصورة الرمزية Capt
    Capt غير متصل عضو نشيط
    May 2010
    128
    اتوقع اسرع سياره في التوب سبيد 372.1
    1100R غير متصل عضو فعّال جداً
    1,031
    اممم فعلا الاسرع في التوب سبيد لكن التسارع دايماَ خفضة شبة مستحيل في السيارات
    من هذا الحجم.
    حتى مرسيدس تعاني من نفس المشكلة!!
