    افتراضي Renault Megane or an Opel/Vauxhall Corsa لا تصلحان بعد ثلاثة سنوات من الاستخدام
    فشلت كل من رينو ميجاني و أوبل كورسا في إختبارات MOT البريطانيه
    (لتسجيل السياره) التي تختبر السيارات بعد ثلاثة سنوات من الاستعمال
    أن 25% من سيارات رينو ميجاني(341 سياره) فشلت في الاختبار لسبب
    أو آخر أما بالنسبه لسيارة أوبل كورسا ( 576 سياره) 20% من السيارات
    فشلت في الاختبار..
    Renault Megane
    Owning a Renault Megane or an Opel/Vauxhall Corsa might be a good idea in the short term, but may turn into something of a nightmare after say three years of operation. This is at least the conclusion of a chart which shows what models have the bad habit of failing their first Ministry of Transport test (MOT - vehicle check compulsory for all vehicles over 3 years old and registered in the UK).
    The winner of this unwanted title is, as you've figured it out by now, the French built Megane. The research, conducted by one of UK's largest MOTs, Nationwide Autocentres, found that 25 percent of all Meganes brought in last year (341 units came in for testing) failed for one reason or another.
    The second place in this chart belongs to the Vauxhall Corsa, which ranks in with a 20 percent failure rate (a lot more models tested though, 576). The best performing three year old model, if it can be called that, is the BMW 3 Series, with only 7 percent of the 304 units tested having failed.
    For the five year MOT, the car which stands out as the worst performer is the Vauxhall Corsa. In its case, the five year MOT test showed that 39 percent of these cars fail. The Megane switches places with the Corsa and follows closely behind with 35 percent failure rate.
    The research has been conducted as part of the 50th anniversary celebration of the MOT. It's conclusions? Regularly maintenance can help avoid a MOT failure.
    Soud alshaiba غير متصل عضو فعّال
    Nov 2007
    636
    من يومها ها المواتر تخترب عقب فتره
    osamaFXX غير متصل Banned
    Aug 2010
    66
    بصراحة السيارات الفرنسية بشكل عام مشهورة بقلة الإعتمادية لكن فوكسهول غريبة لأنو بالأصل الفوكسهول هل أوبل يعني المفروض تكون عملية وتخدم... أستغرب من التصنيف عدم وجو اي سيارة أمريكية لأنو اعتقد اسوأ سيارات من ناحية الإعتمادية والأعطال والجودة هي الأمريكي.... لو انسألت قبل 5 سنوات اقول الكوري لكن بعد الثورة الي حصلت مؤخرا عند كيا وهونداي اقول الأمريكي اسوأ.
    التنين غير متصل عضو فعّال جداً
    Apr 2009
    1,410
    جربت الامريكي ولا بس كلام
    لانه كان عندنا كابرس 14 سنه ماعمره وقف علينا في الخط او انخرب
    وحاليا عندنا جمس موديل 2004 ونفس الشي مااشتكينا الا من مشاكل بسيطه في الفرامل وغيرها
    والكوري اهو السوناتا 2009 و2008 ماليه الورش!!
    الصورة الرمزية GMC LoveR
    GMC LoveR غير متصل مميز
    2,004
    صدقت مجرد كلام لا اكثر ..
    عندنا جمس 2001 الحين بيكمل عندنا 10 سنين تقريبا .. و كارفينه كرف بالخطوط .. تقريبا رايح السعودية اكثر من 12 مرة .. غير روحات دبي و راس الخيمة اللي كل اسبوعين مرة تقريبا ..
    ما شاء الله تبارك الله زي الفل .. تجييكاته كلها في الوكالة و ما نبدل فيه اي شيء إلا القطع الاستهلاكية ..!
    و بخصوص الخبر انصدمت الصراحة لأن الميغان من السيارات اللي يعشقها الاوروبيين عامة و الفرنسيين خاصة و تحصل موديلات قديمة منها تمشي عندهم ولا فيها شيء ..
    يمكن الموديل اليديد مب بنفس جودة القديم لكن 25% نسبة كبيرة الصراحة ..
    على فكرة مذكور في الخبر شي يمكن ما انتبهتوا له :
    [ The best performing three year old model, if it can be called that, is the BMW 3 Series, with only 7 percent of the 304 units tested having failed ]
    ردا على من يتهم سيارات بي ام دبليو بقلة الاعتمادية .. :)
    genes power غير متصل Banned
    Jun 2010
    K.S.A - Tokyo
    570
    اوبل؟؟؟؟؟؟
    غريبة!!
    اعتماديتها جدا قوية حتى الهاتشباك اللي كان ينزل عندنا رغم انها صغير وضعيف لكن ماشاء الله تتحمل كرررف
