    Wink Gumpert Tornante...........(جديد جنيف)
    TECHNICAL DATA
    2-seater sports car with a mid-engine arrangement, chrome-molybdenum steel chassis with an integrated safety cell, doors and the boot lid open with gullwings, carbon body, 100 l stainless steel tank behind the passenger cell with integrated catch tank, long and pushrod-operated double transverse control arm suspension with fully adjustable dampers front and rear and anti roll bar in front, ground clearance adjustable between 60 and 140 mm, two circuit ABS brake system with six piston callipers, inside ventilated discs (378 x 32 mm) at front and rear.
    Dimensions and Weight
    Length - 4,475 mm
    Width - 1,971 mm
    Height - 1,215 mm
    Wheelbase - 2,700 mm
    Track front / back - 1,648 / 1,600 mm
    Boot volume - ca. 200 liters
    Kerb weight (depending on equipment components) - 1,300 – 1,400 kg
    Engine
    V8-cylinder-Biturboengine with 90° cylinder angle, Closed-Deck light metal crankcase, light metal cylinder heads with five valves per cylinder, four overhead camshafts, variable time of ignition (Vario Cam direct) on the intake, hydraulic valve clearance compensation, dry sump lubrication, double-flow exhaust system with 3-way catalytic converter, four Lambda probes for gas mixture and diagnostics, On-board diagnostic system, 2 Intercoolers, electronic ignition with a rested ignition distribution (eight ignition coils), sequential multipoint fuel injection, electronic accelerator system (drive-by-wire)
    Cylinder / type / valves per cylinder - 8 / 90°-V/5
    Cubic capacity - 4,163 cm³
    Stroke – Bore - 93 / 84,5 mm
    Nominal output (kW / HP at rev / min) - 515/700 at 6,500
    Max. torque (Nm / lb ft at rev / min) - 900/663.7 at 4,000
    Maximum rev – 7,400 rpm
    Litre performance (kW/l / HP/l) - 123.7 / 168.1
    Compression / recommended fuel type - 9.3 / 98 ROZ / 88 MOZ
    Emission standard - Euro 5
    Gearbox - Automatic six-speed gear box TT40e with synchronization and oil cooling, operated with paddle shift controls, twin plate clutch configuration (diameter 240 mm), Torsen differential lock
    Wheels/Tires - Michelin Pilot Super Sport front 265/35 ZR19, back 345/30 ZR20
    Wheel dimension- front 10 J, back 13 J
    Wheel rim type - Aluminum cast or forged wheels with centre lock
    Performance Figures
    Top speed (est.) - above 300 km/h (186 mph)
    ابعاد السيارة ووزنها وقوة محركها تؤهلها للوصول لتسارع 3,7 ثانية في المئة كم !!!!!!!
    ومع هذا التصميم الجميل ربما يكون لهذه السيارة كلمة صعبة ولكن من الافضل مشاعدة فيديو لها ومعرفة كيفية اداءها مقارنة مع سيارة هالفئة
  1. Gumpert Tornante...........(جديد جنيف)
    آخر مشاركة: 13-02-2011, 06:37 PM
  2. Gumpert Apollo Speed قريبا في جنيف
    آخر مشاركة: 16-02-2009, 08:26 AM
  3. ABT KTM X-Bow.........(جديد جنيف)
    آخر مشاركة: 14-02-2009, 03:14 AM
  4. Gumpert autoshow Geneva Motor Show 2007 Super Cars
    بواسطة MC-F1 في المنتدى قسم السيارات العام
    آخر مشاركة: 04-03-2007, 06:16 PM
  5. 2006 Gumpert Apollo
    بواسطة FuLL MoOoN في المنتدى قسم السيارات العام
    آخر مشاركة: 20-08-2006, 08:38 PM
