النتائج 1 إلى 6 من 7
    MR.JAT غير متصل عضو فعّال
    677
    افتراضي نيسان تعلن عن GT-R موديل 2012 (2013) بقوة 550 حصان وتسارع لـ 100 كيلو خلال 2.8 ثانية
    Nissan Releases the 2012 Model Year Nissan GT-R
    YOKOHAMA, Japan (November 7, 2011) - Nissan Motor Co., Ltd. today announced the launch of the 2012 model year Nissan GT-R, which goes on sale in Japan on November 24 at Nissan dealers nationwide.
    Nissan GT-R Pure edition equipped with "For Track Pack" options
    The Nissan GT-R is an icon of Nissan's pioneer spirit; it invented the concept of the "multi-performance super car" and made high-performance vehicles accessible to anyone, anytime, anywhere. Today, the Nissan GT-R continues to evolve; this latest version has improved features in terms of performance, efficiency and refinement to provide further excitement to drivers and passengers.
    The 2012 model year GT-R has improved maximum engine output and fuel efficiency (thereby reducing CO2 emissions) by enhancing the car's engine efficiency. The 2012 MY model comes equipped with asymmetric suspension, multi-performance speed, and highly responsive driving performance which provide a stable, high-quality driving experience for passengers. Additionally, the custom option, "For TRACK PACK", inherits the driving DNA of the Spec V model to provide an alternative, more Spartan driving option for potential customers.
    The 2012 model year Nissan GT-R will be released in North America, Europe and other regions from January 2012 onward.
    2012 MY Nissan GT-R Overview
    1. Mechanical Features
    Engine
    By improving the GT-R's engine efficiency, its fuel economy has been raised to 8.6km/L (tested under Japan's 10-15 mode) or 8.7km/L (in JC08 mode), while engine output has been significantly improved to 404kW (550ps)/6,400rpm with maximum torque of 632N·m(64.5kgf·m) from 3,200 to 5,800 rpm. Engine response and torque at mid- and low-speeds, and power at high revolutions, has been significantly improved, mainly due to:
    Improved intake efficiency - Air flow resistance has been reduced by adding an intake manifold fitted to the head of each unit and the use of resin in the enlarged air intake duct for the intercooler, and
    Improved exhaust emissions efficiency and enhanced control - Air flow resistance has been reduced through a more compact underfloor catalyzer which improves emissions efficiency and reduces weight. For improved exhaust valve cooling performance, a newly-designed metallic sodium-filled valve has been adopted. Valve control timing, the air mixture ratio and ignition timing have been improved as well.
    Transmission
    Shift feel and quietness have been refined through a strengthened design of the shift fork arm and a firmer fixing bearing for the flywheel housing.
    A high-performance differential oil R35 COMPETITION type 2189E (75W140), which has been used in motorsports, is now provided as a standard feature for every grade.
    Body
    By reinforcing areas mainly around the rear part of the engine compartment and dash panel, together with increased engine output, more responsive handling and a greater sense of the vehicle's grip on the road are transmitted to the driver.
    More precise production methods, accompanied by advancements made in the vehicle body, have improved the inter-vehicle detection capability. This was achieved by changes in the positioning of the sensor and more rigid, highly-damped vehicle body, and by adding a more accurate acceleration sensor in areas with higher sensitivity in the vibration testing of each vehicle body.
    Suspension and brakes
    Considering the added weight of the driver on the right side in a right-hand drive vehicle and that the propeller shaft for front wheels is located on the right side of the vehicle, the GT-R's suspension has been set asymmetrically for the left and right sides. For the front suspension, a harder spring rate on the left side has been set. For the rear, the suspension arm has been installed upward on the left side and downward on the right for an imbalanced wheel load when the car is stationary, but is equalized during driving, providing improved responsiveness and smoothness which the driver feels when steering, as well as enhanced cornering stability and riding comfort.
    NCCB (Nissan Carbon Ceramic Brakes) are available as a factory-installed option for the GT-R Premium Edition and EGOIST grade. These brakes accentuate the car's agile road hold and supple ride feel through a dramatically-reduced spring weight and refined, sharp braking performance unique to carbon ceramics. (In addition, service parts prices for the rotors and pads have been reduced.)
    2. Interior
    The quality feel of the meters placed in front of the driver have been enhanced for a more sophisticated atmosphere in the cockpit by adding blue lighting inside the tachometer ring to match the shift position indicator light.
    The Bose® sound system woofers have been changed to Bose® Precision Sound System woofers that were developed for the EGOIST grade to further enhance sound quality.
    3. For TRACK PACK
    "For TRACK PACK" is a custom option for the Pure Edition designed for customers who want to enjoy a more Spartan-feel driving experience in their Nissan GT-R. Jointly developed with NordRing company in Japan, it features the suspension, air guide for brake cooling (front and rear), and aluminum-alloy wheels made by Rays (with black quartz chrome color coating). The front spoiler with carbon air duct has been exclusively made for this edition and is installed as a set. For reducing the car's weight, this edition is made in a two-seat configuration (without rear seats, with quilted fabric mats). Also adopted are combination seats made with genuine leather and high-grip fabric, newly developed for the "For TRACK PACK" option, which firmly holds the driver through the grip of the seat cloth.
    غير الناس غير متصل عضو جديد
    Aug 2009
    6
    WoooooW WooooooooooooooooooooooooooooooooooooooooWWWWW
    2.8 تسارع للـ 100كم
    شي خيااالي
    شكرا على الخبر بس يا ليته بالعربي لو سمحت
    السباق مع بورش لا ينتهي !!!! هذي السيارة فرضت احترامها على ملاك البورش !!!
    الوحش الياباني جاد جدا ولا يتوقف عن الابداع .......اكيد راح نشوف رقم جديد في حلبة نوربيرجنج
    الصورة الرمزية rfee3 el mestwa
    rfee3 el mestwa غير متصل عضو متميز
    25
    2,683
    اكيد طبعاً و لكن لا نحكم على بورش تراهم لين الحين ما أعلنوا عن الوحش القادم 911 turbo الجديد بالكامل بس أعلنوا عن S و العاديه ... لكن كل أحترام لل جي تي آر الصراحه سيارة ولا أروع ...
    الصورة الرمزية F.H.A
    F.H.A غير متصل عضو نشيط جداً
    Apr 2007
    أثنين وعشرين عام - Twenty-two year
    220
    واللهي كلام كبير من جي تي أر
    بس ما تدري من المنافسين شنو راح يسون
    أنتم كذا حلوين
    الصورة الرمزية rami-z
    rami-z غير متصل عضو نشيط جداً
    ٢٧
    236
    لا تنسون السعر المنافس
    ٩٠ الف دولار فقط
    لسوبر كار تحت ال٣ ثواني مخصصة للإستخدام اليومي
    2012 Nissan GT-R | Nissan USA Official Site
    كم سعر البورش 911 تيربو؟
  1. نيسان تعلن عن تسارع طراز GT-R موديل 2012
    بواسطة MR.JAT في المنتدى أخبار السيارات
    آخر مشاركة: 08-12-2010, 01:02 AM
  2. فورد تبدأ تجارب توروس 2012 بقوة 400 حصان
    بواسطة غريب السيف في المنتدى أخبار السيارات
    مشاركات: 11
    آخر مشاركة: 13-08-2010, 06:52 PM
  3. نيسان بترول بقوة 1400 حصان و توب سبيد 397 كلم
    بواسطة GS430 في المنتدى قسم السيارات العام
    مشاركات: 13
    آخر مشاركة: 17-03-2009, 03:36 PM
  4. نيسان 350z موديل 2006 بقوة 310 حصان .
    بواسطة bbb في المنتدى قسم السيارات العام
    مشاركات: 38
    آخر مشاركة: 26-08-2006, 02:44 AM
