    Cool فورد تقدم موستانغ 2013
    Design wise, the new 2013 Ford Mustang gets a bunch of changes that you may not notice at a first glance. On the list of changes are:
    Functional heat extractors on the hood of the GT that help move hot air out of the engine compartment and cool the engine.
    Rocker panels running along the car are now body-color.
    The rear has been updated with a high-gloss black panel that connects the tail lamps.
    Standard high-intensity discharge (HID) headlamps on both V6 and GT models.
    A revamped wheels lineup with standard 17-inch wheels for V6 all the way up to 19-inch optional wheels on the GT and V6 Performance Package. Two different finishes on the 17-inch wheel – machined-aluminum and painted. Three optional V6 wheels – an 18-inch polished aluminum set, an updated 18-inch painted aluminum and a 19-inch painted wheel design and a new theme for the V6 Performance Package. Standard 18-inch painted aluminum wheel on both GT and premium GT. 19-inch optional GT wheel with a gloss-black finish.
    Mirrors with pony projection light, which show the image of Mustang’s famous pony emblem on the ground.
    New colors – Deep Impact Blue and Gotta Have It Green (really?).
    V6 and GT get optional leather-trimmed or cloth Recaro seats that are available on the Shelby GT500 and Boss 302.
    Inside you get an optional Ford Track Apps, which delivers performance metrics through a 4.2-inch LCD. The system measures g forces, acceleration times in quarter-mile and 0-60 increments, and displays braking times complete with automatic and countdown starts.
    The 2013 Ford Mustang GT’s 5.0 liter engine will now develop 420-hp – up from 412-hp. Those that select an automatic-equipped Mustang (don’t know why you would) will be able to shift own gears with new SelectShift Automatic transmission, which is now standard.
    The 2013 Ford Mustang GT also gets the new GT Track Package, which is only available on the manual GT Mustangs with a 3.73 axle. It gives buyers an engine cooler, upgraded radiator, performance friction brake pads and the same Torsen differential that’s on Mustang Boss 302. The package also adds the current Brembo Brake Package, with 14-inch vented front discs, 19-inch alloy wheels and summer performance tires.
    What else? The V6 Performance Package is now available for automatic models for the first time.
    The 2013 Ford Mustang will be built at AutoAlliance International Plant in Flat Rock, Mich. and will go on sale early next year.
    The 2013 Ford Mustang Boss 302 gets the same design upgrades as the base models with a sportier appeal with a body kit. It is features a reflective hockey stick graphics package – first modern application on a production car – paying homage to the 1970 Boss 302. Also new for 2013 is heritage-inspired School Bus Yellow paint and Sterling Gray accents on Boss Laguna Seca.
    “Everything we did for 2013 is consistent with and links directly back to our 1970 heritage. The reflective stripes and hockey stick graphic in particular mean something to Mustang enthusiasts,” said Dave Pericak, Mustang chief engineer. “Last year, we proved the car had what it takes to perform, and this year we focused on enhancing its eye-catching looks and celebrating its history.”
    Also for 2013, the Ford SYNC system becomes standard for the Boss 302.
    Power for the 2013 Ford Mustang Boss 302 has been upgraded to 444-hp with a maximum torque of 380 lb-ft of torque. A race-inspired clutch with upgraded friction materials transmits power, with a short-throw, close-ratio six-speed manual.
    Topping off the 2013 Ford Mustang lineup is the new Shelby GT500. The model gets a bunch of design changes for the 2013 model year to keep it uniform with the rest of the lineup but what’s most interesting is what’s under the hood – and that’s about to put the upcoming 580-hp Chevrolet Camaro ZL1 to shame.
    “SVT keeps the Shelby GT500 on the cutting edge of technology and takes muscle car performance to new heights,” said Jost Capito, director of Global Performance Vehicles and Motorsport Business Development. “We encapsulated every aspect of performance in this car – whether it’s 0-60, top speed, racetrack or quarter-mile times. Beyond that, the daily driver also will find this car perfectly fits his or her needs.”
    Ready for the specs? We don’t think you are but here we go. Power for the 3,850 pound 2013 Ford Shelby GT500 comes from a 5.8 liter supercharged V8 making an outstanding 650-hp with a peak torque of 600 lb-ft. That makes the engine the most powerful production V8 in the world..
    While no 0 to 60 mph times have been released, Ford says that the 2013 Shelby GT500 will hit a top speed of more than 200 mph. That’s supercar territory. To keep things stable, Ford engineers optimized nearly every part of the powertrain for producing additional horses. The model also gets an upgraded cooling system with a larger cooling fan, fan shroud with high-speed pressure-relief doors, a more efficient charge air cooler, a higher-flow intercooler pump and an intercooler heat exchanger with volume increased 36 percent.
    For the 6-speed manual transmission, nearly every gear was revised to manage the torque. Engineers went through 35 gearing combinations until deciding on one that delivers less torque all the way through the wheels.
    “It might just seem like we’re putting a bigger engine into the car. But it’s been a balanced approach through and through,” said Jamal Hameedi, SVT chief engineer. “We’ve completely redone the car to be even more sophisticated in terms of handling and control than the prior model.”
    Sales of the 2013 Ford Shelby GT500 will start early next year.
    آآآآآآآآآآآآآآآآخ يا جرح الزمن ههههههههههههههههههههههههه ههه
    بصراحه خشم الشلبي طالع اجراااااااااااام عالجي تي
    طبعا ترجمه لبعض المعلومات التعييرات صارت في الليتات و الشبك و البمبر و الرنقات و لون جديد و الجي تي صار 420 حصان بدل 412
    و الشلبي 5.8 قوته 650 حصان و سرعته تصل 320
    و الله دمار شامل صراحه لا توقولوي كمارو بعد اليوم لا اس اس ولا زد ال ون ههههههههههههههههههههههههه ههههههههههههههههههههههههه هههه
    الصورة الرمزية Bu Saif
    Bu Saif غير متصل عضو فعّال جداً
    18
    1,063
    اي واللهجرح الزمان
    الموستنغ غييييييير ، رنج الجي تي فنااان و اللون روعه رمادي ميت
    بوعلي ...السيارة توصل بكل سهولة 320 كم !!!!!! ياخرابي على قولتك !!!
    اقولك بس حسون من الحين سير للوكالة واحجز اول موديل بيوصل الامارات !!! ههههههههههههههه
    بصراحه انا قريب المقال بالكامل كلمة كلمة حرف حرف سطر سطر .......زنقة زنقة<<< اشدخلها هذي هههههههه
    ومحاولة مني لترجمه بعض السطور :
    الانوار الظاهرة في الصور اصبحت مواصفات قياسية على كل من ال6 اسطوانات ونوع الجي تي
    الرنجات لل6 اسطوانات قياسية من 17 انش ويوجد خيار 19 انش بنوعين وايضا تتوفر رنجات 18 انش ....والرنجات نوعين بجحميع الاحجام ..الالومينوم المصبوغ واللمسة السوداء الللامعه
    مرايا مضاف اليها انوار بروجكشن تعكس شكل حصان الموسنتج على الارض عند انارتها !!!!!
    لونين جدد : ازرق الاعماق (اتصور انه كحلي) وايضا لون اخضر
    ال6 سلندر والجي تي يتوفر لهما خيار مقاعد جلديه او مقاعد ريكارو المتوفرة قياسيا على بوس وشلبي ....وايضا تتوفر جميع الموديلات بشاشة جديدة بين العدادت حجم 4.2 انش وفيها خيار لمعرفة التسارع من ال0 الى 60 ميل وايضا الربع ميل !!!! ويوضح ايضا مدى كفاءة المكابح ووقت التوقف ......طبعا الاوبشن بيخليكم مثل سائقي مجلات تجارب السيارات ...حسون يباله الاوبشن عشان كل يوم يعطينا ارقام جديدة
    القوة ارتفعت من 412 حصان الى 420 حصان مع جير جديد بخيار سلكت شفت (نفس نظام التبترونيك)
    نوع الجي تي سوف يضاف له بكج جديد ..لموديل الجير العادي اكسل جديد .يعطي تبريد افضل للمحرك ,راديتر محسن , مكابح وسفايف نفس الموجود على نوع بوس 302 ، وايضا بكج بريكات من برمبو 14 انش امامية و19 انش للرنجات مع اطارات صيفية
    نوع ال6 اسطوانات الجير الاوتو سوف يتوفر له بكج الاداء للمرة الاولى
    ستتوفر السيارة في وقت مبكر من العام القادم !!!
    نوع البوس 302 سوف تصبح قوته 444 حصان مع ويضاف اليه كلتش رياضي جديد يحسن من نقل القوة في نسب اقل مع الجير السداسي الجديد
    الشلبي الجديد سوف يصل الى سرعه 321 كيلو (سوبر كار )
    مهندسي فورد وضعوا كل اجزاء نقل القوة لاضافة احصنة اضافية للمحرك الجديد ...
    الموديل الجديد اصبح يحمل نظام تبريد جديد ومحسن ومروحه بحجم اكبر وتشارجر هوائي مبرد اكثر فعالية , وانتركولر عالي الاداء ....
    وطبعا القوة اصبحت ...650 حصان بمحرك ال5,8 الجديد ....
    باختصار : فورد في الصدارة بين الامريكيات والان لاتزال فيها الصدارة والقمة ويبدو انها لاتنوي التخلي عنها وايضا في 2013 سوف تصبح سيارة عالمية وسوف تكون للشلبي كلمة عليا بين سيارات السوبر كارز ....وسوف تناطح السيارات الالمانية والايطالية ايضا .....
    اتمنى اشوف رد قوي من شيفروليه ودودج لان بصراحه المنافسة حلوة بين الثلاثي الامريكي ... خصوصا دودج المتأخرة دائما في هذه المنافسة!!!
    ماشاء الله تصميم وتعديلات روعة وجميلة.
    يبالنا نشرتي موستنج ان شاء الله.
    فـوزان غير متصل عضو نشيط
    Mar 2010
    كبير بما فيه الكفاية
    83
    كشفت فورد مؤخرا النقاب عن تحفتها الاسطوريه 2013 فورد شيلبي موستنج GT500 بمواصفات مذهله وخصوصا من الناحيه الميكانيكيه . فورد ارادت بهذا التحديث للموديل 2013 ان تعلم جميع منافسيها وخصوصا 2012 شفروليه ZL1 بقوة 580 حصان التي اعلنت التحدي العام الماضي بان فورد لن تتيح اي فرصه للمنافسيها للتفوق في هذه الفئه من السيارات .
    من الناحيه الخارجيه وخصوصا المقدمه الاماميه تم اضافة تعديلات جديده ومنها : اضافة انوار LED جانبيه في الاسطبات الاماميه . ايضا تم تغيير شكل الشبك الامامي العلوي والسفلي للادخال كمية هواء اكبر للمحرك السياره . من ناحية مؤخرة السياره تم تغيير شكل الاسطبات الخلفيه بشكل بسيط ولكن تم استبدال الاضائه باضائه LED مميزه . ايضا تم تزويد مؤخرة الشيلبي موستنج GT500 باربعة عوادم للتكون مميزه عن اخواتها واعطائها شكلا مهيبا .
    التغيير الكبير حصل في محرك السياره اذا تم استبدال المحرك السابق ( 8 سلندر سعة 5.4 لتر بشاحن هوائي بقوة 550 حصان ) بمحرك اقوى 8 سلندر سعة 5.8 لتر مشحون هوائيا بقوة 650 حصان وعزم 600 رطل لليصبح اقوى محرك 8 سلندر في العالم والفضل يعود الى اضافة شاحن هوائي اكبر ويعمل بكافئه اعلى من الموديل السابق . ايضا تم رفع السرعه القصوى الى اكثر 200 ميل اي 320 كيلو . ايضا تم اضافة ميزة Launch control التي تساعد السائق على الحصول على الانظلاق المثالي وخصوصا عند السباقات . ايضا تم تغيير نظام المكابح بنظام اكثر كفائه من شركة بريمو الشهيره Brembo . ايضا اضافة دفرنس من نوع Torsen limited-slip differential الذي يساعد نظام التعليق الخلفي للسياره للاعطاء قوة دوران عاليه مع ثبات عالي وللمدة اطول على الحلبه . ايضا تم تزويد السياره بعمود كردان مصنوع من الكاريبون فيبر للتحمل عالي في السرعات العاليه . ايضا تم تقوية الكرونه 3.31 للتحمل القوه الهائله الذي ينتجها المحرك . ايضا تم تعزيز نظام بمروحه اكبر بفتحات تهويه مع مبردات للناقل الحركه اليدوي المكون من 6 سرعات .
    ( منقول )
    تعليقي :
    مفروض يسمونه GT600
    وحش ذا مب موتر !!
    عموماً أنتظر نتائج إختبار السيارة وعدد الأحصنه الفعلي
    اللي اعجبني فالفورد الجديد
    اني شفت صورة للداخلية وفيها شاشة فورد الجديدة .. بنظام ماي فورد تتْش ^_^
    فعلاً الفورد في تطوّر  ....
  1. فورد تقدم موستانغ Boss 302
    آخر مشاركة: 16-08-2010, 04:31 AM
  2. فورد تقدم موستانغ GT 2011
    مشاركات: 23
    آخر مشاركة: 29-12-2009, 03:30 AM
  3. فورد تقدم موستانغ Bullitt 2008
    آخر مشاركة: 10-11-2007, 05:20 PM
  4. فورد موستانغ U69
    مشاركات: 13
    آخر مشاركة: 04-08-2007, 04:24 PM
  5. عطر فورد موستانغ ...........
    بواسطة AMG في المنتدى استراحة شباب الخليج
    آخر مشاركة: 09-05-2007, 02:12 PM
