النتائج 1 إلى 6 من 13
    Smile كاديلاك XTS......(جديد لوس انجلس)
    بديلة دي تي اس و اس تي اس بقوة 300 حصان وتعتبر منافسة للأوروبيات امثال الفئة E والفئة الخامسة
    Highlights include:
    • Advanced Haldex all-wheel-drive system with electronically controlled limited-slip differential
    • Magnetic Ride Control, rear air suspension, HiPer Strut front suspension and Brembo brakes – all standard
    • Standard 19-inch wheels and available 20-inch wheels
    • Direct-injected 3.6L V-6 with lightweight features, including integrated cylinder heads/exhaust manifolds
    • Capless fuel tank filler for easier, cleaner refueling
    • Folding rear-seat headrests that enhance rear visibility
    • Safety Alert Seat that vibrates to alert the driver
    • Intervening braking system that lessens or avoids potential collisions
    • Short- and long-range radar systems that support:
    • Adaptive Cruise Control
    • Front and Rear Automatic Brakes
    • Rear Cross Traffic Alert.
    Safety features and benefits include:
    • Front and Rear Automatic Brakes – Using “virtual bumpers” that rely on short-range radar technology and ultrasonic sensors, this feature helps prevent front and rear low-speed collisions via a progression of alerts that extends to complete braking if necessary. For example: If the vehicle is headed toward a small pillar inside a garage or a lamppost on a city street, the system will alert about the hard-to-spot item and stop the vehicle to help prevent an impact.
    • Adaptive Cruise Control – Using radar technology, this feature can apply limited braking or acceleration to maintain a selected following distance to the vehicle ahead.
    • Intelligent Brake Assist – Detects a panic-braking situation and assists the driver by applying brake force more quickly to help stop sooner.
    • Forward Collision Alert – Radar and camera technology detects a possible collision threat and alerts the driver, giving him or her time to stop and/or change course.
    • Safety Alert Seat – A vibration on either the left or right side of the driver’s seat cushion, depending on the location of the impending concern, alerts the driver to a potential collision threat.
    • Automatic Collision Preparation – When the XTS senses a collision is imminent, braking is applied to lessen the severity or perhaps even enable the driver to avoid the incident.
    • Lane Departure Warning – A camera-based lane detection system that warns the driver of unsignaled lane changes. The camera, mounted near the inside rearview mirror, identifies traffic lane markings and provides audible alerts or activates the Safety Alert Seat.
    • Side Blind Zone Alert – Using radar sensors on both sides of the vehicle, the system “looks” for other vehicles in the blind zone areas of the XTS and indicates their presence with LED-lit symbols in the outside mirrors.
    • Rear Cross Traffic Alert – Using radar sensors of the side blind zone alert system, it warns the driver of oncoming traffic when backing out of a parking spot – including angled parking. Visual and audible alerts are triggered if moving vehicles are detected.
    • Adaptive Forward Lighting – With adaptive forward lighting, the headlamps swivel with direction of the front wheels to maintain forward lighting in concert with vehicle steering.
    • Rear Vision Camera With Dynamic Guidelines – With a display in the center stack, the camera provides a view of objects directly behind the XTS, with dynamic guide lines laid over the video image to assist in parking maneuvers.
    2013 CADILLAC XTS PRELIMINARY SPECIFICATIONS:
    Overview
    Model: 2013 XTS FWD/AWD
    Body style / driveline: front-drive/all-wheel-drive, front-engine, four-door, five- passenger sedan
    Construction: integral
    EPA vehicle class: full-size sedan
    Manufacturing location: Oshawa, Ontario
    Engines
    Type: 3.6L V-6 VVT DI
    Displacement (cu in / cc): 217 / 3564
    Bore & stroke (in / mm): 3.7 x 3.37 / 94 x 85.6
    Block material: aluminum
    Cylinder head material: cast aluminum
    Valvetrain: DOHC with four valves per cylinder; continuously variable valve timing
    Ignition system: individual coil-on-plug; individual cylinder knock control
    Fuel delivery: direct injection
    Compression ratio: 11.5:1
    Horsepower
    (hp / kW @ rpm): 300 / 224 @ 6800 (est.)
    Torque (lb.-ft. / Nm @ rpm): 264 / 358 @ 5300 (est.)
    Recommended fuel: regular unleaded
    Emissions controls: dual close-coupled catalysts and single underfloor catalyst; variable valve timing, evaporative system
    Estimated fuel economy (city / hwy): FWD: 17/28, AWD: 17/27
    Transmission
    Type: Hydra-Matic 6T70 six-speed automatic
    Application: 3.6L V-6
    Gear ratios: (:1):
    First: 4.48
    Second: 2.87
    Third: 1.84
    Fourth 1.41
    Fifth: 1.00
    Sixth: 0.74
    Reverse: 2.88
    Final drive ratio: 2.77
    Chassis / Suspension
    Suspension (front): Hi Per strut coil-over-spring; twin-tube dampers with gas-charged valving; hollow direct-acting stabilizer bar
    Suspension (rear): Linked “H”-arm with air shocks and Magnetic Ride Control
    Steering type: hydraulic power; variable-effort rack-and-pinion
    Steering ratio: 15.3
    Steering wheel turns, lock-to-lock: 2.64
    Turning circle (ft / m): 38.7/11.8
    Brakes
    Type: split, dual-circuit four-wheel-disc with power assist
    Rotor diameter x thickness (in / mm): front: 13.6 x 1.2 / 345 x 20 (vented)
    rear: 12.4 x 0.9 / 315 x 23 (solid)
    Wheels / Tires
    Wheel size and type: 19-inch painted aluminum with chrome inserts
    19-inch polished aluminum
    20-inch premium-painted aluminum
    20-inch polished aluminum with chrome inserts
    Tires: P245/45R19 all-season blackwall
    P245/40R20 all-season blackwall
    Dimensions
    Exterior
    Wheelbase (in / mm): 111.7 / 2837
    Overall length (in / mm): 202 / 5131
    Overall width (in / mm): 72.9 / 1851
    Overall height (in / mm): 59.1 / 1501
    Track (in / mm): front: 61.7 / 1567
    rear: 62 / 1576
    Curb weight (lb / kg): FWD: 3995/1812, AWD: 4180/1896
    I nt erior
    Seating capacity: 5 (2 front / 3 rear)
    Headroom (in / mm): front: 39 / 990
    rear: 37.8 / 960
    Legroom (in / mm): front: 42.1 / 1069
    rear: 40 / 1016
    Shoulder room (in / mm): front: 57.9 / 1470
    rear: 56.3 / 1430
    Hip room (in / mm): front: 55.1 / 1400
    rear: 54.3 / 1379
    Capacities
    EPA interior volume (cu ft / L): 122.2 / 3458
    Passenger volume (cu ft / L): 104.2 / 2949
    Cargo volume (cu ft / L): 18 / 509
    Trailer towing maximum (lb / kg): 1000 / 454
    Fuel capacity (gal / L): 18.6 / 70.5 (FWD)
    19.5 / 74.0 (AWD)
    Engine oil (qt / L): 5.5 / 5.2
    MR.JAT غير متصل عضو فعّال
    677
    دفع امامي!
    واضح من قصر المقدمة ولكن كان بالامكان افضل مما كان
    الصورة الرمزية Call of Duty
    1,103
    كتصميم .. روووووووووووعه ..
    زين كدلك طلعت من تصاميمها الحاده اللي بالمصطره ..
    ولو تبنى باقى تصاميمها على هالشكل اتوقع تكون من اجمل التصماميم من بين المنافسين ( بعد المرسيدس وقبل بي ام طبعا ) خخخ
    أبو محمد غير متصل مراقب عام
    الإمارات
    5,398
    التصميم الاختباري كان اكثر روعة .. لكن احس فيها شبه الكابريس لما اشوفها من الجنب
    الإمــارات
    7,079
    من الامام معقوله لكن الجوانب ومن الخلف ممكن يتعدل الشكل ويصير افضل بكثير
    اما من الداخل فأصبح احسن بكثيييييييييييييييير
    الشكل اقصر او انحف شوي عن الاخرى.
    من الداخل حلوة..
  1. كاديلاك Urban Luxury......(جديد لوس انجلس)
    آخر مشاركة: 18-11-2010, 10:31 AM
  2. كاديلاك تقدم إيسكاليد هايبريد.......(جديد لوس انجلس)
    آخر مشاركة: 13-11-2007, 06:14 PM
  3. كاديلاك تقدم ايسكاليد بلاتينيوم........(جديد لوس انجلس)
    آخر مشاركة: 10-11-2007, 06:22 PM
  4. كاديلاك تقدم مجموعة بلاتينيوم..........(جديد لوس انجلس)
    آخر مشاركة: 11-12-2006, 02:32 PM
  5. ساتورن فيو.........(جديد لوس انجلس)
    آخر مشاركة: 30-11-2006, 03:35 PM
