    Smile بورش باناميرا GTS......(جديد لوس انجلس)
    تقع بين توربو و 4 اس وبقوة 430 حصان
    To provide driver’s with a sportier experience, Porsche started with the 4S and dropped the body 10mm, tightened the damping system, and tuned the chassis with Porsche Active Suspension Management (PASM), and air suspension. The two systems connect the body and chassis, and regulate height, leveling, and spring rate. Stability is also further enhanced with wheel spacers that widen the rear axle track.
    The appearance of the Panamera GTS was only slightly altered, but features black highlights and subtle distinguishing characteristics around the body. Sitting on the inside, the Panamera welcomes you with adaptive sports seats, a limited GTS leather interior, Alcantara surfaces, and a SportDesign steering wheel with shift paddles.
    Porsche modified the S/4S 4.8-liter naturally aspirated V8 engine to give the GTS an additional 30-hp, putting the power output to 430-hp at 6,700 rpm. Torque has been increased from 360 lb-ft to 384 lb-ft, as well. The motor is coupled with a 7-speed Porsche Doppelkupplungsgetriebe (PDK) transmission in the Sport Chrono package, which comes standard. This transmission is designed to transfer power seamlessly to the all-wheel drive system. These systems combine to move the GTS from 0-60mph in just 4.3 seconds, with speeds topping out at 178 mph.
    A set of 255/40 tires up front and 285/40 in the rear stick the Panamera GTS to the pavement. Stopping power is provided by the bigger-diameter Panamera Turbo system, with Porsche Ceramic Composite Breaks (PCCB) still an option.
    This is awesome blend of function and form, and was topped off in the Panamera GTS with the raw power of its naturally aspirated motor.
    ماشاء الله بورش شادين حليهم بشكل كبير.
    تسلم اخوي عمر
    الظاهر ان بورش ناوية تعمم فئة جي تي اس على جميع موديلاتها ...واكيد راح نشوف نسخة كايين قريبا
    May 2007
    5,600
    السلام عليكم
    والله بورش مسوين شغل والكل الحين متوجه للكايين والبانميرا ولكن يحب يتميز واشوف بورش صارت تقدم خيارات كثيره وفئات متعدده تلبي كل الرغبات
    فئة جي تي اس زادوها ٣٠ حصان وتسارع افضل وكت خاص شيئ جميل
    الصورة الرمزية rami-z
    rami-z غير متصل عضو نشيط جداً
    ٢٧
    236
    الرادار اسفل البمبر مشوة الشكل نسبيا
    كان ممكن ان يتم دمجة مع اسفل البمبر بطريقة فنية .. مثل المرسيدس او اللكزس
    الصورة الرمزية يوسف الشيباني
    يوسف الشيباني غير متصل عضو نشيط جداً
    Oct 2010
    43 سنة
    472
    رعة بصراحة وجميلة الخطوط لكن القوة ليس بالمطلوب لأن الفئة إس أقوى منها بمئة حصان حيث أنها تولد 550 حصان مقابل 480 حصان للفئة جي تي إس
  1. بورش باناميرا توربو اس..........(جديد نيويورك)
    مشاركات: 11
    آخر مشاركة: 01-04-2011, 05:21 PM
  2. بورش كايمان R..........(جديد لوس انجلس)
    آخر مشاركة: 22-11-2010, 12:46 AM
  3. بورش تخطط من جديد إنتاج باناميرا كشف
    آخر مشاركة: 28-03-2010, 02:40 PM
  4. بورش باناميرا في فيديو جديد
    آخر مشاركة: 19-06-2009, 08:42 PM
  5. بورش باناميرا في فيديو جديد
    آخر مشاركة: 01-06-2009, 08:41 PM
