    Lightbulb فولفو S60 Polestar performance الإختبارية
    Technical specification
    Performance
    0-100 km/h 3.9s
    Top speed more than 300km/h
    Engine
    Volvo T6 inline six (B6304T4)
    508 hp @ 6500rpm
    575Nm @ 5500rpm
    Max rpm: 7100
    Modified cylinder head and combustion chambers
    Modified inlet manifold and air intake
    Special manufactured conrods
    Garret 3171 turbo
    Ferrita 3.5” stainless steel exhaust system
    Drive train
    Reinforced M66C (close ratio) manual 6-speed gear box.
    Haldex E-LSD in rear
    Haldex Gen4 XWD
    Chassis
    Tires 265/30R19
    Rims Polestar 9,5X19”
    Chassis lowered 30mm
    Öhlins 3- way shock absorbers
    Reinforced anti-roll bar front and rear
    Track width increased 20 mm front and 40 mm rear
    Polestar-tuned EHPAS steering
    Stabilising X- members, front and rear.
    Modified control-arms with uniballs front and rear.
    Reinforced bushings in sub-frame and control-arms
    Modified engine mounts
    Weight
    Total weight 1640kg and optimized weight distribution
    Brakes
    Front Polestar-Brembo 6 piston calipers, 380 mm ventilated discs
    Rear Polestar-Volvo calipers, 302 mm ventilated discs
    Brake cooling air intakes from front
    Aerodynamics
    Based on tests in Volvo’s wind-tunnel
    Lowered front splitter and larger rear spoiler to reduce high speed lift
    Carbon fiber diffusor
    Body 20 mm widened front and rear
    Interior
    Polestar designed seats with increased support. Alcantara on all functional areas steering wheel, gear knob, and seats to ensure maximum grip.
    Centre console lowered for optimised gear-lever ergonomics.
    May 2007
    5,600
    عجيبه سبورتيه بحته
    لكن المشكله سمعة وكلاء فولفو سيئه وغالباً الوانها الداخليه سوداء
    508 حصان !!!!!!!!!!!
    و تسارع اثل من 4 ثواني
    و الله خطيره
  1. فولفو You الإختبارية........(جديد فرانكفورت)
    آخر مشاركة: 18-09-2011, 06:50 PM
  2. فولفو You الإختبارية........(جديد فرانكفورت)
    آخر مشاركة: 14-09-2011, 10:34 AM
  3. إنفينيتي FX50 Performance الإختبارية......(جديد فرانكفورت)
    آخر مشاركة: 04-09-2011, 07:55 AM
  4. فولفو V60 و XC100 جديد فولفو المنتظر
    بواسطة بو علي في المنتدى أخبار السيارات
    آخر مشاركة: 01-05-2007, 11:32 PM
